Lifted '16 Tacomas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Letsgoplaces, Sep 24, 2015.
  1. Oct 23, 2016 at 9:35 PM
    #3681
    Filthy13
    Filthy13 Well-Known Member
    2016 DCSB 4x4
    Fits fine on my truck. No cutting.
  2. Oct 24, 2016 at 11:34 AM
    #3682
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    This is the kit I've been looking at just wasn't sure on the 887's or the 888's. Do you have any extra weight up front? I plan on doing skids and possibly sliders later on. I'd like to see the final numbers once she settles because she sits pretty good now. How do you like the ride with removing the long overload in the Dakars? This is the other thing I've been debating on is whether or not to remove it. She looks really good.
  3. Oct 24, 2016 at 12:30 PM
    #3683
    ProfessorX
    ProfessorX Well-Known Member
    Jimmy
    Menifee, Ca.
    2001 4DR TRD 4x4(sold) 2016 DC SB TRD OR 4x4(totaled)
    As of right now, I do not have any extra weight. I do have skids that I have not installed yet. I also have sliders being built right now. I plan on winch and bumper as well, but when that time comes I'm sure I'll change up the setup up front. The ride is great without the long overload, I only removed it to eliminate the extra half inch of lift. I've heard a lot of people saying that without any weight in the bed, that the dakars ride rough or stiff. But the ride to me is awesome. Nice firm ride compared to the mushy oem suspension. Just my opinion as I came from an old 2001 Tacoma and before that a 2001 xterra. So obviously a big time upgrade.
  4. Oct 24, 2016 at 1:28 PM
    #3684
    Age315
    AJ
    Castle Rock, CO
    I may just take out that overload leaf too as long as there is no bro lean. One more question, do you have any drive line vibes and did you use the carrier bearing drop or shims? I came from a Jeep LJ and I had OME springs and 5100's on that. I loved it and that is why I'm going that route with the Taco. I fought drive line vibes on that for over a year before I got rid of it so it's something I worry about lifting the Taco. Thanks for all your help.
  5. Oct 24, 2016 at 1:52 PM
    #3685
    ProfessorX
    Jimmy
    Menifee, Ca.
    No vibrations and no cb drop. You definitely will not have any bro lean. You'll still have a little rake actually. That's why I removed the long overload, otherwise it would have too much rake for my personal taste.
    Age315[QUOTED] likes this.
  6. Oct 24, 2016 at 1:56 PM
    #3686
    Age315
    AJ
    Castle Rock, CO
    That is the best news I've heard all month! Hahaha! I wanted a little rake but not as much as factory. I'm still saving for my lift and the $1000 bonus I will get in December should get me there so I can get UCA's too. Thanks again!
  7. Oct 24, 2016 at 2:46 PM
    #3687
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    @Panduh you still have the 2.75 spacer kit from pro comp still? Or the Ready Lift?
  8. Oct 24, 2016 at 2:56 PM
    #3688
    Leo4x2
    Leo
    San Antonio, Tx
    Best spacer kit for 4x2 w/o having to replace UCAs? I know everyone will say "spacers on a 30k dollar truck whyyyy?" blah blah blah
    I DONT CARE.
    This is a street truck and daily driver and don't care about ride quality comments, just looking for best one to go with. I've seen people with spacer lifts and rear shocks and everything turned out fine. Let me know!
    2016 Tacoma SR likes this.
  9. Oct 24, 2016 at 3:23 PM
    #3689
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Spacer lifts are all really going to be about the same. Either choose between something made of metal or a poly/plastic lift depending on the height. Just find the height you want.
    Some people are able to run 3" with the stock UCAs but your caster will probably fall below 1 degree at that height. You'll notice more bump steer and may have some rubbing on the back to the wheel well.
  10. Oct 24, 2016 at 3:26 PM
    #3690
    elduder
    Van WA
    Don't mean to deter you but vibes are kind of hit and miss from what I've read. I have 887s which netted about 2" of lift and I have very faint vibes at about 40 mph. I've been in stock trucks that already had those vibes too, one was so bad it vibrated the steering wheel. So just cross your fingers.
  11. Oct 24, 2016 at 4:06 PM
    #3691
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    OME 888 and Dakar with Total Chaos Uniball. Now for rims and tires.
  12. Oct 24, 2016 at 4:16 PM
    #3692
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    I'm running a 3" bolt on spacer up front and a 2.5" block out back. Alignment is fine, 285/75/16 clears fine on stock 16x7 rims with a 1.25" Spidertrax spacer, no rubbing at all anywhere. You will need longer rear shocks if you lift more than 1.5" though so keep that in mind.
  13. Oct 24, 2016 at 5:57 PM
    #3693
    Wdhigh
    Wdhigh Well-Known Member
    Ridgeville, SC
    2021 Trd OR dcsb
    Ordered the same but with spc UCA's. Will be here tomorrow.
    How's it ride? Any idea on how much lift after it settled? Looks pretty high in the pic.
    I'm trying to determine rim and tire combo now. Was going to do the trd 17's until I saw 120 pages of those already mounted. Sadly I think they look great!!
  14. Oct 24, 2016 at 6:03 PM
    #3694
    LadyRed
    Leah
    Florida/Mississippi
    It rides great, a little stiffer than the stock suspension but nothing I don't mind. I have to tweak it a bit tomorrow (leveling) so I'll have a better idea of lift by then. Also, I got two positive leaf packs so I think the rear got a bit of extra lift. I'll see if I can grab some measurements this week.
    I went back and forth over tires and decided to be a little different. Planning on having 255/85/16 mounted on Thursday with my 16" SCS Ray 10s. I'll post when it's all done.
    Wdhigh[QUOTED] likes this.
  15. Oct 24, 2016 at 7:22 PM
    #3695
    MrSmithsTaco
    MrSmithsTaco Well-Known Member
    Oklahoma City, OK
    2016 Super White Tacoma TRD OR
    Me in the driver seat.
    Where did you get your bedside decal? Is that factory?
    ISAN_TACO likes this.
  16. Oct 24, 2016 at 7:59 PM
    #3696
    Panduh
    Panduh Member
    Michael
    Columbus/Nashville
    05 E55, 16 Tacoma DCSB Off-Road, 17 4R TRDP Sement
    Ready Lift 3/2 18x9 Pro Comp Rockwells 285/60/18
    Its the Ready Lift kit
  17. Oct 25, 2016 at 12:51 PM
    #3697
    Swiftks
    Swiftks Well-Known Member
    Spring, TX
    2016 TRD OR
    Bilstein 6112 (front) Bilstein 5160 (rear) Headstrong Progressive AAL ShiftSense Pro SumoSprings BakFlip F1 Tonneau Cover BAMF Grille aFe intake w/ scoop Custom Exhaust - URD Y-Pipe, Vibrant Ultra Quite Resonator & MagnaFlow Muffler 4Runner TRD Pro 17" Wheels Wrangler DuraTracs - 265/70R-17 Redline Hood Struts OPT7 LED Headlights (Highs & Lows) Baja Designs Squadron Pro Fog Lights LED Interior Lights Total Chaos Bed Stiffeners TRD Pro Skid Plate TRD Pro Tail Lights TRD Pro Shift Knob @CBoy808 Custom Bedside Decals FormulaOne Pinnacle Window Tint OEM Tacoma Bed Mat OEM Tacoma All Weather Floor Mats Fumoto Valve Amsoil Fluids
    Quick question... So a couple months ago, I put on the Bilstein 6112 w/ springs & 5160's in the rear. I set the height to the 3rd notch, and got approximately 1.5" - 1.6" of lift in the front. I am looking at getting some new tires & wheels in the next month or so, and was wondering if I should upgrade my UCA's as well? As I don't have much experience with Tacomas, I wasn't sure if this is needed. I get that yes, technically it is needed, if you want to be back within factory specs for alignment purposes, but with only a 1.5" lift, is it practical to spend $650 on UCA's for this setup? Only looking at going to the 17" Sema Wheels and 265/70/17 tires, so nothing to crazy.
    Was looking at going with the Total Chaos UCA's, if I did decide to get upgraded parts. But if I don't really need them, I'd much rather get a baja designs light bar for that money. Just looking for a little input.
    Here is my alignment specs I had done after the Bilstein install. You're thoughts or opinions are welcome. Thanks.
  18. Oct 25, 2016 at 1:41 PM
    #3698
    tacothai
    tacothai Well-Known Member
    Thai
    SoCal
    16 TRD Sport 4x4 DCSB
    King 2.5, Baja Kit UCA
    King 2.5 and Baja Kits UCA
  19. Oct 26, 2016 at 9:57 AM
    #3699
    andyboyd102
    andyboyd102 Member
    2016 sport
    3 inch's in the front, 2 in the rear, Pro Comp 7033 , Toyo Open Country 275/65/18, Plasti Dipped emblems, Tacoma insert letters in tailgate, Custom Grill, reused Toyota emblem off factory grill, added TRD emblem to grill , orange inlays on glove box and door sill gaurds, Lund Tri-fold bed cover, IBoard running boards......
    Trdpro2017, Street Taco and ISAN_TACO like this.
  20. Oct 26, 2016 at 10:04 AM
    #3700
    Filthy13
    2016 DCSB 4x4
    Looks great. Nice work
