Lifted '16 Tacomas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Letsgoplaces, Sep 24, 2015.
  1. Nov 13, 2015 at 3:36 PM
    #1261
    \000/
    \000/ Well-Known Member
    Waimanalo, HI
    2016 DCSB 4x4 TRD Sport
    Hope this helps a little...
    Here's mine with 275\70\17 KO2's, TRD wheels (11mm offset and gives me 0.9" more than stock), stock UCA's and no lift (installing lift next week). Tons of clearance all around.
    mistah, Doggman, littlechilds and 3 others like this.
  2. Nov 13, 2015 at 3:45 PM
    #1262
    JerryTaco
    JerryTaco Well-Known Member
    Thanks for chiming in! Your truck looks great! I figured that the 275's would work with the 5100's and you just confirmed that. Make sure to post pics when the lift goes on
    \000/[QUOTED] likes this.
  3. Nov 13, 2015 at 3:46 PM
    #1263
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    Thats helps a ton! Thank you and your truck looks great! That answered my question then and now I'm not so worried about pulling the trigger on them. Any rubbing at all?
    Edit: Do you have the 5100s on or is it completely stock suspension?
  4. Nov 13, 2015 at 3:48 PM
    #1264
    NV_Tacoma
    Paul
    Northern Nevada
    Thanks for the help Jerry! Looks like you were right the whole time. :cheers:
  5. Nov 13, 2015 at 4:03 PM
    #1265
    \000/
    Waimanalo, HI
    Thanks guys!! So far it's stock and no lift whatsoever. OME lift (885's) coming next Saturday and i'll post pics and full specs of what i've done once it's complete. I just took these pics so you have an idea. I didn't measure but the closest it gets is about 0.75" or 1"? I should have shot straight on but atleast you get to see that it clears.
    DGOTRD and NV_Tacoma[QUOTED] like this.
  6. Nov 13, 2015 at 4:14 PM
    #1266
    NV_Tacoma
    Paul
    Northern Nevada
    Thanks man, keep us posted on how the lift goes and post some pics when its done! Based off of what you said and the photos I should be fine with the 5100 set at .85 to level it out:yay:
  7. Nov 13, 2015 at 4:17 PM
    #1267
    \000/
    Waimanalo, HI
    Will do brotha. I wouldn't even sweat it, you should be golden with that setup!
    NV_Tacoma likes this.
  8. Nov 13, 2015 at 4:50 PM
    #1268
    BD2016TACO
    BD2016TACO Active Member
    2016 Black Tacoma TRD
    OME lift with BF KO2's 285 70r17 and Mickey Thompson Classic III's
  9. Nov 13, 2015 at 7:43 PM
    #1269
    NV_Tacoma
    Paul
    Northern Nevada
    Sorry to bother you man but whenever you have a chance can you try to lock the front wheels and flex them to see if it rubs before you lift it? Thanks man in advance I appreciate it!
  10. Nov 13, 2015 at 8:37 PM
    #1270
    \000/
    Waimanalo, HI
    Sure no worries. I'll try to take some this weekend if I get a chance.
    NV_Tacoma[QUOTED] likes this.
  11. Nov 13, 2015 at 9:03 PM
    #1271
    NV_Tacoma
    Paul
    Northern Nevada
    I really appreciate all the help. Thank you
  12. Nov 14, 2015 at 8:00 AM
    #1272
    littlechilds
    littlechilds skyhawk
    Cowtown
    16 trd sport Upgrade package DCLB
    KO2 tires, TRD pro rims. BP skid plate, Extang 2.0 cover, dipped grill and badges
    This is exactly what I'm wanting, but I really want to avoid the 11 ply tire…the 265 is a bit more realistic for me being 6 ply…a bit better o fuel Im guessing…hmmm, decisions decisions.
  13. Nov 14, 2015 at 1:44 PM
    #1273
    Taco2k16
    Taco2k16 TRD_ShoreTrooper
    Danny
    Los Fresnos, Texas
    2017 TRD OffRoad 4x4 QuickSand DCSB
    Stock Tow Package Bed LEDs
    Would 17x9 0 offset with 265/70/17 fit without any modifications? On stock suspension
    *not a 4x4 model
  14. Nov 14, 2015 at 8:53 PM
    #1274
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    Did the front mud flap rub or did you just remove it because you like the look?
  15. Nov 15, 2015 at 3:24 PM
    #1275
    la0d0g
    running for the hills
    For crawling not hauling
    If he stuffs that tire at all it'll rub. You can see that from his picture.
    ChadsPride and 0uTkAsT like this.
  16. Nov 15, 2015 at 5:20 PM
    #1276
    NV_Tacoma
    Paul
    Northern Nevada
    Even with 5100s installed? I know 265s will fit no problem just trying to get something bigger.
  17. Nov 15, 2015 at 5:57 PM
    #1277
    JerryTaco
    You'll be fine with the 5100s
  18. Nov 15, 2015 at 5:59 PM
    #1278
    knhorn
    knhorn Well-Known Member
    San Diego
    2016 TRD Sport DCSB Quicksand
    Icon Stage 5 set at 3", Toyo ATII, Fuel Throttle
    The front muds rubbed. I have since however removed the front dam and rear muds, although those don't rub.
    TRDPro4x4[QUOTED] likes this.
  19. Nov 15, 2015 at 7:11 PM
    #1279
    texasnavy05
    texasnavy05 Well-Known Member
    2016 White TRD Sport Double cab 4WD short bed
  20. Nov 15, 2015 at 8:55 PM
    #1280
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Don't even bother. Aluminum rear spacer? Not even worth the waste of time.
