Lifted '16 Tacomas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Letsgoplaces, Sep 24, 2015.
  1. Dec 11, 2015 at 11:01 AM
    #1541
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Yeah it had to be. Because I hit by 1"
  2. Dec 11, 2015 at 11:02 AM
    #1542
    gsxxr
    It's not bad at all with the diff drop.
    Yes 4x4 sport
  3. Dec 11, 2015 at 12:02 PM
    #1543
    veranthros
    veranthros Give a little,take a little
    Ray
    future 2016 trd offroad (manual) 5' bed
    Thanks for the info. I am debating now if I should just stick some 32 tires on and negate the lift all together for this truck,save the headache of having to worry about it 40,000 miles down the road (I like the ideal of not having to do heavy maintenance of a new truck,within the first 90,000 miles).
    la0d0g[QUOTED] likes this.
  4. Dec 11, 2015 at 12:21 PM
    #1544
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    I'm new to trucks, what are CV's? lol
  5. Dec 11, 2015 at 12:24 PM
    #1545
    highwhey
    highwhey Well-Known Member
    Alan
    Phoenix
    2016 Tacoma OR m/t
    Axles. I believe they become strained when you lift your truck because they are no longer level, rather they are at an angle.
    Tacoma2GR[QUOTED] likes this.
  6. Dec 11, 2015 at 12:29 PM
    #1546
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    oh okay, so CV's stand for anything specific?
  7. Dec 11, 2015 at 12:44 PM
    #1547
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    https://en.m.wikipedia.org/wiki/Constant-velocity_joint
    Take note that these things are specifically designed to transmit power *at varying angles* to accommodate for the full suspension stroke. With a lift you increase the angle a bit because the inner axle connection is pulled up away from the wheel.
    CV axles aren't very expensive... ~$100/each. I figure it's no big deal, if one breaks replace it.
  8. Dec 11, 2015 at 3:36 PM
    #1548
    2016TacomaDCLB
    2016TacomaDCLB Active Member
    2016 DCSB TRD Off-Road
    So, I'm about to put 275/70R17's on my '16 Tacoma like PJC1183 and \000/, but I have a long bed that I plan on putting a cap on.
    How much more lift should I add to the rear considering the additional weight?
  9. Dec 11, 2015 at 3:53 PM
    #1549
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I'm running 285/70/17's no rub
  10. Dec 11, 2015 at 3:58 PM
    #1550
    2016TacomaDCLB
    I would love to maintain the same rake. Curious if I should add a little more in the back for a long bed with a cap.
  11. Dec 11, 2015 at 4:01 PM
    #1551
    2016TacomaDCLB
    Grill looks niiiiccce!
    proven21 likes this.
  12. Dec 11, 2015 at 4:24 PM
    #1552
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    So it can become a problem for 2wd's too or more common for 4x4?
  13. Dec 11, 2015 at 4:26 PM
    #1553
    Doggman
    Alabama
    2017 TRD OR MT
    2wd's do not have CV axles. There are only 2 CV axles on a 4wd truck. One going to each of the front wheels.
    EDIT: well... it looks like I'm wrong... you can buy CV axles for a prerunner although I'm not sure why.
    EDIT2: actually, I think I was right in the first place. the reason I second guessed myself is because some websites I checked that sell cv axles claim they will fit on 2wd tacoma's...
  14. Dec 11, 2015 at 5:45 PM
    #1554
    gsxxr
    Cv joints are part of the power train and have a 60k warranty.
  15. Dec 11, 2015 at 6:02 PM
    #1555
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Thanks for clearing that up for me!
    So there's obviously less to worry about when lifting a 2wd right? Unless blocks are used, then there's possible damage?
  16. Dec 11, 2015 at 6:24 PM
    #1556
    gsxxr
    Doing strut top spacers and rear blocks don't effect any thing different then an over sized shock does. The only difference is that you need to do the bump stops.
    As for a rear leaf spring to add an inch that worse. It make the rear way to stiff when compressing.
  17. Dec 11, 2015 at 6:28 PM
    #1557
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    your right that it is covered but most dealers will tell you that it was damaged due to your lift and will not cover it.
  18. Dec 11, 2015 at 6:31 PM
    #1558
    gsxxr
    I disagree now a days. They get paid from toyota yo replace them and they know this truck goes to guys who offroad. I know my dealer wouldn't think twice.
    Plus if you just have a over sized shock calling it a lift I don't think they will question it.
  19. Dec 11, 2015 at 6:38 PM
    #1559
    pngo121
    Phi
    Pittsburg, CA
    Both my dealers nearby declined to fix my tundra under warranty. Both my cv boots were kicking out grease. They were even trying to blame it on the shop doing the lift.
    So with that said, it'll just depend on the dealership you go to.
  20. Dec 11, 2015 at 6:44 PM
    #1560
    gsxxr
    You need to argue that. That's really stupid on their behalf. They get paid to do the job anyway. Just take it another dealership.
