Lifted '16 Tacomas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Letsgoplaces, Sep 24, 2015.
  1. Dec 13, 2015 at 1:14 PM
    #1581
    fonzy
    fonzy Well-Known Member
    Fonzy
    Madera, CA
    2016 Tacoma SR5 4x4
    None
  2. Dec 13, 2015 at 1:20 PM
    #1582
    la0d0g
    running for the hills
    For crawling not hauling
    That's not stupid on their part. You're lifting the truck which changes the geometry of the suspension which subsequently leads to shorter CV life. That's not Toyota's responsibility to fix.
  3. Dec 13, 2015 at 1:29 PM
    #1583
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    You do understand that the dealership gets paid from toyota to do repairs right?
    It's a money making job for the dealership and the tech. The tech gets paid 2 hours and it takes him 30 min. The service department bills for 2 hours at an average of 80$ per hour to toyota.
    Also the service writer gets paid 2% on warranty work also.
  4. Dec 13, 2015 at 1:33 PM
    #1584
    la0d0g
    Did you miss the part about it not being their responsibility?
  5. Dec 13, 2015 at 1:41 PM
    #1585
    gsxxr
    No but making money is. It's an easy fix and good paying. Try having them chase down a rattle and see where u get. It's a business bro they are there to make bank.
  6. Dec 13, 2015 at 1:53 PM
    #1586
    la0d0g
    So you expect them to fix non-warrantied items on Toyota's dime because they make money on it? If dealers did that consistently they would be out of business because toyota would be too.
  7. Dec 13, 2015 at 2:09 PM
    #1587
    gsxxr
    Your right, but how many of them do you think they see with bad cv joints? It's not enought to raise a concern with toyota. Keep in mind thay also need to keep happy customers and support the product. If you get a service manager that won't help you out go to another dealer that will.
    If your doing all your service with them they are also more likely to work with you.
    Fyi I was a service manager for toyota for 5 years.
  8. Dec 13, 2015 at 2:22 PM
    #1588
    Chasin Tail
    Chasin Tail Well-Known Member
    Olympia, WA
    2016 Tacoma DCSB 4x Sport MGM
    If you were a Service Manager for Toyota, you should be able to articulate that Toyota has to prove the part failed specifically because of the Lift. Which is hard to do.
    The Magnuson-Moss Warranty Act prevents them from voiding warrantys based solely off of lifts or other mods.
  9. Dec 13, 2015 at 2:28 PM
    #1589
    gsxxr
    It would never even get that far because it wouldn't even be an issue. Mma is there for the customers sense of security and to up hold the warranty.
    Any good dealership wouldn't even question the repair. If someone got a dick head manager then they can contact toyota and for it. That's where the Mma act comes in effect.
  10. Dec 13, 2015 at 6:43 PM
    #1590
    Bumrush
    Bumrush Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    Can anyone suggest what to trim with for rubbing?
  11. Dec 13, 2015 at 6:46 PM
    #1591
    gsxxr
    You can use a dremel.
  12. Dec 13, 2015 at 6:47 PM
    #1592
    Bumrush
    Brian
    Middle TN
    Any particular bit? I'm not much of a handy man lol. Scares the crap out me to start cutting on a $40000 truck.
  13. Dec 13, 2015 at 6:55 PM
    #1593
    Sandtaco
    Sandtaco Well-Known Member
    Henderson NV
    2016 TRD Offroad Access cab
    I had this dude do the cmc and fender cut. I will clean it up myself with fine sandpaper and paint.
    https://www.tacomaworld.com/members/glorifiedwelder.148647/
  14. Dec 13, 2015 at 6:55 PM
    #1594
    gsxxr
    Lol I just used the thin cutoff wheel. Only need to do a little spot. I also used it on my air dam to trim it so my tires wouldn't rub.
  15. Dec 13, 2015 at 6:58 PM
    #1595
    Bumrush
    Brian
    Middle TN
    Love to see some pics when your done. I'm guessing I may not need to trim as much as you did since my wheels are 2 sizes narrower?
  16. Dec 13, 2015 at 7:00 PM
    #1596
    Sandtaco
    Henderson NV
    If you are just doing a small portion of the plastic a utility knife with a fresh blade works fine. I suggest taping off the cuts so you get the cuts straight.
  17. Dec 13, 2015 at 7:02 PM
    #1597
    gsxxr
    I did not have to do much because of my lift. I was going to take pics today but it rained. I will try again tomorrow.
  18. Dec 13, 2015 at 7:02 PM
    #1598
    gsxxr
    And keep your fingers out of the way.
  19. Dec 14, 2015 at 12:14 PM
    #1599
    aweddle14
    aweddle14 Well-Known Member
    Anthony
    Phoenix, AZ
    16 Quicksand DCSB SR5
    What was the labor for the install on this if you don;t mind me asking?
  20. Dec 14, 2015 at 1:24 PM
    #1600
    Taco2k16
    Taco2k16 TRD_ShoreTrooper
    Danny
    Los Fresnos, Texas
    2017 TRD OffRoad 4x4 QuickSand DCSB
    Stock Tow Package Bed LEDs
    for a 3inch bilstein lift what do i need? front and rear shocks( 5100?? ) can i use my stock springs? or what aftermarket springs do i need to acquire the 3 inches. thanks
    any links for the best prices are welcome
