Lifted 1st gens let's see em
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota4Ever, Sep 23, 2013.
  1. Jun 2, 2021 at 4:52 PM
    #1601
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I have the 882s!
    98_3RZ_NIC[QUOTED] likes this.
  2. Jun 2, 2021 at 4:54 PM
    #1602
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    that’s the coil I want! But with the bilstein 5100 shock. So it’ll give me quite a bit of lift since I’m a little lighter than yours. I might wanna go with 881’s huh??
  3. Jun 2, 2021 at 4:55 PM
    #1603
    98_3RZ_NIC
    what size wheels and tires you running?
  4. Jun 2, 2021 at 4:56 PM
    #1604
    98_3RZ_NIC
    Here’s my set up now. 5100’s with 880 coils on 0 and stock rear.
  5. Jun 2, 2021 at 5:21 PM
    #1605
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I think if you had a single cab the 881s could probably get you where you want to be but since you’re extended I don’t think the 882s would be too much? Other members probably have better experience than me regarding what to go with for single/extended cabs and v4/v6 motors. Also depends how much lift you want. I have 285/70/17r on Toyo AT 2s
  6. Jun 2, 2021 at 5:51 PM
    #1606
    98_3RZ_NIC
    I have JBA uppers so as much lift as I can get and still be in spec for alignment. Thanks for the info!
  7. Jun 3, 2021 at 6:04 AM
    #1607
    sjohns24
    sjohns24 New Member
    1999 Taco 4x4 xtended cab
    3” lift, 265/75R16, fender flares, tinted windows
    Hi everyone, newbie to the group here. I had my ‘99 Taco lifted 3” several years ago and replaced the original 15” wheels with 16” Ultras and Mickey Thompson’s. I wasn’t aware that going up 1” would affect the power as much as it did. I see lots of posts on here where some folks have done this (some increased by 2”). Did any of you do anything to increase the power or do you just live with it? On most steeper highway grades, it have to go into 4th gear since it won’t hold cruise speed in 5th. I’m going to need new tires eventually and was hoping for a cheaper workaround than buying new 15” wheels. I thought of going with a lower profile tire (such as 225’s), but think it would look pretty bad with doughnut tires. I also don’t need a tread as aggressive as the Mickeys since I don’t do any muddin’, but also don’t want regular street tires, leaning toward BFG’s. Any advice you guys can offer is greatly appreciated.
    Here are pics of the pre/post lift.
    E55F6057-650F-4F24-AAD6-50A8F69F5F8D.jpgB8FE9D02-AC5E-4889-921F-C1A5D4B278C9.jpg1BD5CC8F-DD8E-4423-8A37-167B857D8BA9.jpg
  8. Jun 3, 2021 at 7:40 AM
    #1608
    98_3RZ_NIC
    what lift is that?
  9. Jun 3, 2021 at 7:48 AM
    #1609
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    Current
    OME Lift Kit, 882 Coils, Dakar Leafs.
    Extended Travel CV Axles.
    Stock 2021 TRD OR Wheels.
    Falken WildPeak 235/85R16 (31.7").
    **Since this image, the stock back bumper was replaced with a High Clearance (Stout) bumper.
    Planned
    SPC UCA's. 34's planned. 33's at minimum.
    I like the skinny tires, so I'm hoping I can find a taller tire.
    Who knows, I may have to step up-to a 17" wheel.
    In Progress
    Rock Sliders w/kick-outs were ordered and should arrive any time.
    The stock front bumper is being replaced with a Chassis Unlimited "Octane" Winch Bumper. (Ordered)
    Miscellaneous
    In the back, is a matching spare, On-Board air, High-Lift jack and recovery gear.
    Carry Basket (or something) is planned for the top of the canopy.
  10. Jun 8, 2021 at 1:22 PM
    #1610
    Bobito
    Bobito Active Member
    So Cal
    1st Gen DCSB
    Small lift, Armor, Topper
    2002 DCSB Lunar Mist
    Deaver custom leaf pack
    SPC uppers and Sway a Way adjustable coilovers
    Custom Tradesman Aluminum Topper
    Sliders
    Relentless from plate bumper
    SCS Wheels with 285/70/17 BFG K02
    Always a work in progress...l
  11. Jun 9, 2021 at 7:08 PM
    #1611
    Markb574
    Markb574 Member
    Mark
    2004 Black Tacoma
    Bilstein 5100s and add a leaf from toytec
  12. Jun 9, 2021 at 7:15 PM
    #1612
    98_3RZ_NIC
    what coils and what setting are they on?
  13. Jun 10, 2021 at 5:28 AM
    #1613
    Markb574
    Markb574 Member
    Mark
    2004 Black Tacoma
    They are toytec coils and they are set at the bottom setting.
    This is the complete kit:
  14. Jun 10, 2021 at 9:34 AM
    #1614
    98_3RZ_NIC
    do you have side picture of your truck? How do you like the eibach coils on the 5100’s?
  15. Jun 10, 2021 at 10:54 AM
    #1615
    Markb574
    Markb574 Member
    Mark
    2004 Black Tacoma
    I don't have any pictures at the moment and the ride is really good feels better than stock for me.
  16. Jun 10, 2021 at 10:56 AM
    #1616
    98_3RZ_NIC
    I’m thinking of doing the 2881’s with extended top hat studs because I’m gonna put 1/4” spacer on passenger side and 3/8” spacer on driver side. Right now I have 2880 coils on bottom setting of 5100’s and I want like an inch higher in front.
    unstpible and Markb574[QUOTED] like this.
  17. Jun 10, 2021 at 10:57 AM
    #1617
    98_3RZ_NIC
    what lift you running nik?
    -Nic
  18. Jun 10, 2021 at 3:17 PM
    #1618
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    You can move the lower perch one notch and achieve that.
  19. Jun 10, 2021 at 3:21 PM
    #1619
    98_3RZ_NIC
    Middle setting with 2880’s?
  20. Jun 10, 2021 at 3:38 PM
    #1620
    98_3RZ_NIC
    but instead of me screwing with the coil and taking it off I can get all new 5100’s with 881 coils for $500 and sell mine for $380. So really I’m in it $120 and by the time I rent the coil compressor tool and my time, it’s cheaper to buy it new.
