Lifted 2010 Metallic Gray DCSB
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Gabe911, Feb 3, 2014.
  1. Feb 3, 2014 at 1:36 PM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    I am selling my Tacoma: The truck is paid off and I have clean title in hand. This is a V6 2WD Prerunner with some great Stock features: *Rear view back up camera, *Push button Rear differential locker, TPMS system, Push button Traction Control Stability feature.
    Asking 24,500 or best offer
    Since owning the truck I have put the following additions on:
    * 3" OME Suspension Lift purchased new from Toytec Lifts including new gas shocks on all four corners. A side note on the lift: the truck was taken to Lipton Toyota for a rear leaf spring change out. The truck came with a 3 layer leaf spring and now has a 5 layer which includes the 1 from the lift kit and the new 4 layer from Toyota. The truck gets it lift from the new coils up front and added leaf springs in the rear. This is the correct way to lift the truck in my opinion .....not spacers! $800.00 plus install $200.00
    * 17' XD Addicts Matte Black with 285/70/17 Nitto Trail Grapplers with plenty of tread left $1800.00
    * New TPMS installed with tire package (Tire Pressure Monitoring Stems) These were synced with the truck by Plantation Tire Center
    * Bright White LED Map and Dome lights
    * Pocket bed lights with switch in bed (please see photo) I installed these and think its a great added feature.
    * Extended 2 way pressure relief valve from rear differential up thru where light switch is located (truck came from factory with a one-way valve).
    * Heavy duty floor mats with originals underneath
    * Front windows tinted
    * 3" muffler tip in Matte Black ( truck has stock muffler) I never liked the sound of a performance muffler on a V6
    * New Windshield Wipers
    * I have changed the oil 3 times or every 2k miles and have swapped out the rear diff. fluid to Mobil 1 synthetic.
    * I do not own a boat or trailer so its never been used in that capacity...just to and from work.
    * The truck has been aligned 2 times by Tires Plus since I've had it. With these tires and stock upper control arms its needed in order to save tire wear.
    * Truck was purchased with added warranty of 6 year 60,000 mile. So you still have 4 yr or 40,000 miles left bumper to bumper $1400.00
    * I have probably invested close to 4K into this truck which includes servicing, fluids, added equipment (lift, rims and tires)
    *** Only flaws*** When I purchased the truck Arrigo Dodge tried to fix dog scratch marks from original owner by the rear seat belt holder by putting some kind of putty on them well as you can see in the photos it dried a lighter shade of grey ***you never see it unless you look for it***, (2) a small scratch on upper driver side fender other than that the paint and body are near flawless.
    I am not in a rush to sell the truck. This is one great, well maintained truck with a great warranty still attached. Please do your research to see the value of the truck.....especially with all the added equipment and warranty. Please feel free to PM me or call my cell with additional questions. Ryan 954-478-7482 DSCN1277.jpg
  2. Feb 4, 2014 at 5:11 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
  3. Feb 4, 2014 at 4:48 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    In Fort Lauderdale, Fl
  4. Feb 5, 2014 at 7:54 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Cant beat the price......extended warranty and additions alone make it a great value. Let me know
  5. Apr 30, 2014 at 8:18 PM
    xx-griz-xx
    xx-griz-xx Member
    Montana
    06 tacoma 4x4 DC LB
    3" lift
    Gabe, any rubbing problems with the 3" lift and 285 tires? Thanks.
