Lifted 2019 error messages
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cwarner272, Apr 27, 2019.
  1. Apr 27, 2019 at 8:39 PM
    Cwarner272
    Cwarner272 [OP] Active Member
    Casey
    Huntington Beach, CA
    2012 tacoma trd off road 4x4
    @project_relentless 2012 Tacoma TRD Offroad 6" Rough Country suspension lift 315/75 Toyo Open Country M/T 16" MB wheels 1.25" wheel spacers Westin Pro Traxx steps Plasti-Dip badges, bumper, and grille Pioneer touch screen stereo 1500 watt amp 12" subwoofer Flowmasters 2.5" exhaust Snugtop camper shell Custom built headlights: DDM tuning projectors LED concepts colormorph halos Black headlight mod
    Hi guys I just did the maxtrac 6.5 lift on my truck (2019 TRD sport) with the fox upgrade, and now I’m getting 2 error messages
    1 precollision system malfunction
    2 check vehicle stability control system
    I’m wondering if anyone has any info on how to fix this? Please help
  2. Apr 27, 2019 at 8:46 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    6.5” lift?
    Skydvrr, JCOOR and Junkhead like this.
  3. Apr 27, 2019 at 8:49 PM
    gamerunner
    gamerunner Well-Known Member
    2018 TRD OR
    TRD Pro grill
    That's a pretty big lift, you may have to have the PCS re-calibrated but be prepared if the dealer won't do it for free since you lifted the truck. Not sure about the stability control system.
    Junkhead likes this.
  4. Apr 27, 2019 at 8:51 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    This gonna be goood:pccoffee:
    Skydvrr, Stocklocker and 4drtaco03 like this.
  5. Apr 27, 2019 at 8:57 PM
    tcjacado
    tcjacado Well-Known Member
    The stability control needs to be recalibrated. Sometimes during install they can get knocked out a degree one side or the other (driver/passenger ).
  6. Apr 27, 2019 at 9:00 PM
    tcjacado
    Cwarner272[OP] and DavesTaco68 like this.
  7. Apr 27, 2019 at 9:02 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    An error message is gonna be the least of his problems
  8. Apr 27, 2019 at 9:02 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    PCS= $ or SOL
    Stability control needs to get recalibrated for its new zero point or have the sensor shimmed to give the sensor the factory rake angle.
    Cwarner272[OP] likes this.
  9. Apr 27, 2019 at 9:03 PM
    Cwarner272
    Casey
    Yeah it’s a 4” spindle with fox lifted coil overs 2.5”
    Stocklocker[QUOTED] likes this.
  10. Apr 27, 2019 at 9:04 PM
    tcjacado
    Why that much preload on the coil over. Go to a longer stiffer spring.
  11. Apr 27, 2019 at 9:06 PM
    JCOOR
    TRD Burglar
    Shoulda just used a 6.5” spacer
  12. Apr 27, 2019 at 9:08 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Sounds legit. 6.625” is the challenge point. It’s Friday in Australia, right?
    Junkhead[QUOTED] likes this.
  13. Apr 27, 2019 at 9:09 PM
    Stocklocker
    17TRDORDCSBAT
    Ok....I’ll bite:
    The TSS is likely shooting off into space, so cannot “see” the road. That will be your 1st error to deal with.
    The vehicle stability control looks for vectors using the abs sensors and an accelerometer (wheel spin vs direction of travel). Is there a chance some wiring got stretched?
  14. Apr 27, 2019 at 9:10 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Stacking lifts is generally a bad idea especially when each lift is maxed out.
  15. Apr 27, 2019 at 9:11 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
  16. Apr 27, 2019 at 9:11 PM
    gamerunner
    2018 TRD OR
    TRD Pro grill
    I would not have done this to a 2 wheel drive truck :facepalm:...good luck op
  17. Apr 27, 2019 at 9:14 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Pictures please.
    :worthless:
    DrFunker and JCOOR like this.
  18. Apr 27, 2019 at 9:14 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
  19. Apr 27, 2019 at 9:20 PM
    Cwarner272
    Casey
    I had to remove the brackets for the abs to get more length to attach to the new spindles. Don’t think I put too much stress on them during install. They’re not stressed now
  20. Apr 27, 2019 at 9:22 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I thought so, yes.
