Lifted access cabs only!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskanTaco, Jan 15, 2012.
  1. Apr 23, 2019 at 7:41 PM
    #401
    benbenww
    benbenww Well-Known Member
    Washington
    2014 Tacoma 4x4 AC
    Some squeaking after 8 months. Every time I got out of the truck I would hear it a little bit and it drove me crazy. I read up on all the solutions, but I didn’t want to disassemble the leaf pack to put the various liners in that would eventually wear out.
    The squeak is common across any vehicle that uses leaf springs and I followed a solution recommended on a Ford forum. I bought some aerosol Tri Flow and sprayed my leaf pack and let it sit overnight. The squeak went away and it has been several months squeak free. If that’s the only maintenance required then I’m happy with it.
    Something else to consider: the front settled more than the rear. Here were my post-lift center of hub to fender numbers and my 10 month numbers:
    Post Lift
    DF: 22.5”
    PF: 22.5”
    DR: 24.5”
    PR: 24.5”
    10 months later
    DF: 22”
    PF: 22”
    DR: 24.5”
    PR: 24.5”
    It gives it a little more rake than I was hoping for. If I were to do it again, I would consider just getting an add-a-leaf. The medium duty Dakars feel great with a small load, but are pretty stiff with an empty bed.
    WSMFP likes this.
  2. Apr 23, 2019 at 7:44 PM
    #402
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I stumbled across this file in another thread and wanted to share it here too. It's a TSB from ARB for Dakars, and how to fix the squeaking. It's good info.
    WSMFP and yeos like this.
  3. Apr 26, 2019 at 4:07 PM
    #403
    Tempest151
    Tempest151 Well-Known Member
    Joseph
    Fresno CA
    2006 Tacoma 2.7 4x4
    6” procomp. Large coil springs. Cold air. Port and polished head and throttle body. Exhaust. Positraction. Shaved and reinforced tailgate. Camper shell. Piaa fog. 5% tint all around. Stereo 2-12” 2-6x9” 2- 5 1/4” 4400 Watts 20 ferrets. Much more
    No not at all. I had just installed a 1”
    BassAckwards[QUOTED] likes this.
  4. Apr 27, 2019 at 5:33 PM
    #404
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
    Installed my lift in the truck yesterday took 6 hours for all four corners. Went with 5100’s all around and 884 OME Springs and AAL in the back. Put the 1/4” spacer for the taco lean in also. Gained about 3”. New wheels next.
    sanchez, lo2hi, PacTac and 11 others like this.
  5. May 16, 2019 at 2:26 PM
    #405
    Cocolocobean
    Cocolocobean Well-Known Member
    Corrina
    Reno, NV
    05 Tacoma TRD OR 6 speed
    4” lift on 33x12.5x20
    I was having squeaking with my leafs and I sprayed some fluid film on them around 2months ago and haven’t heard a peep. It’s temporary but it cost $11 and I can’t complain.
    FastEddy59 likes this.
  6. May 16, 2019 at 5:04 PM
    #406
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    2B91624F-D377-431C-9395-1BAB36130951.jpg Ok fellas, this is a “before”. Bone stock. The plan is a deaver 1.5” AAL and 5100s all around fronts at 1.75. Is this a reasonable idea? Bear in mind that this truck is my daily, and the only off pavement driving I do is as shown.
    lo2hi, Coolerman and BassAckwards like this.
  7. May 16, 2019 at 5:06 PM
    #407
    Sudsman44
    Abington PA
    Got to be my favorite color.
    TWENTYCO[QUOTED] likes this.
  8. May 16, 2019 at 5:09 PM
    #408
    Sudsman44
    Abington PA
    “Like” for the moniker.
  9. May 16, 2019 at 5:28 PM
    #409
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  10. May 16, 2019 at 6:12 PM
    #410
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    Yup, this will be a great setup for you
  11. May 16, 2019 at 6:28 PM
    #411
    4T3Underhill
    4T3Underhill Well-Known Member
    Dustin
    smogland
    2012 Tacoma TRD Pyrite Mica
    New photo of the method 701’s on the truck
    sanchez, iRep8OH8, lo2hi and 10 others like this.
  12. May 16, 2019 at 8:05 PM
    #412
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    compared to stock geom, truck sits 1/1.5" in front over stock and the rear is around 2-3" depending on loads
    Zbrkf-mBUEsSjAL8diRbMJ0MKM6asqQF6GscVKIa_8890e60a4d60715f31cecca2f55a9b8a3a044a87.jpg
    sanchez, iRep8OH8, lo2hi and 5 others like this.
  13. May 16, 2019 at 8:37 PM
    #413
    erdub54
    erdub54 Well-Known Member
    Erwin
    '05 Tacoma AC 4x4
    Does anyone else make an access cab roof rack besides prinsu? That will be my next mod
    sanchez, lo2hi, PacTac and 4 others like this.
  14. May 16, 2019 at 9:42 PM
    #414
    inesshell
    front runner
    eezi awn has a half rack option for those running habitats
    any rack option will require drilling for the feet
  15. May 16, 2019 at 10:25 PM
    #415
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    nice rig dude, looks like a fun spot
    erdub54[QUOTED] likes this.
  16. May 17, 2019 at 5:03 AM
    #416
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
  17. May 17, 2019 at 6:26 AM
    #417
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    38127AEF-96D1-4873-85A2-08844D291BF3.jpgHeadstrong progressive AAL. 2in front spacer(i know,i know). Installed myself and running 265/70/16.
    lo2hi, PacTac, TRDOBSESSED and 2 others like this.
  18. May 17, 2019 at 7:27 AM
    #418
    erdub54
    Erwin
    '05 Tacoma AC 4x4
    Cool thanks man. Yeah drilling will suck but I’ll be extra careful
  19. May 17, 2019 at 7:27 AM
    #419
    erdub54
    Erwin
    '05 Tacoma AC 4x4
    Thanks man. Yeah it’s a really fun trail in Sedona and not that tough either. Go for the views
    ripcalifornia[QUOTED] likes this.
  20. May 17, 2019 at 8:35 AM
    #420
    Minitaco
    Minitaco Well-Known Member
    Derek
    Santa Rosa, CA
    2012 Tacoma V6 4x4
    ARB, OME, 9.5k Winch, LEDs, Marathon Seat Covers
    Great looking truck!
