Lifted front 2.5 inch Bilstein 5100 series
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssjostrom1980, Sep 18, 2010.
  1. Sep 18, 2010 at 8:11 AM
    ssjostrom1980
    ssjostrom1980 [OP] Taco Love
    Phoenix
    1998 SR5 4x4 v-6 5 speed
    I have put a K&N Air intake, 1500 series bilstein shocks set at 2.5, with a procomp add a leaf to the rear springs giving 1.5 inch lift to the rear. Kenwood Excelon Deck with USB Port 4.0 V Pre Outs! Infinty Ref 4 channel amp for mids and highs Infinity Kappa Perfect component 6.5 in the front and kicker 6.5 two way in the rear. Alpine mono amp for 2 kicker 10 inch competition Subs in a custom Tacoma box. Gold Plated battery Terminals. BFG All Terrain 31's.
    I lifted the front suspension by setting bilestiens 5100 series at 2.5. I didnt however lower the front differential. After driving about 6 months I notice that there is a lot of grease that has oozed out from the axel boots. So I ordered the front lowering kit. I am going to lower the front differential 1 inch. Do you think I need to replace my front axels now or just regrease them?
  2. Sep 18, 2010 at 8:12 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    probably just a cv boot that needs to be replaced. have you noticed any vibes?
  3. Sep 18, 2010 at 8:36 AM
    ssjostrom1980
    Phoenix
    Not really I think it feels alright. Just worried about all the grease I saw. My friend seems to think I need to replace the axels.
  4. Sep 18, 2010 at 10:11 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    How many miles on the truck, got any pic's of the cv boots?
  5. Sep 18, 2010 at 10:22 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^
  6. Sep 18, 2010 at 5:59 PM
    ssjostrom1980
    Phoenix
    140,000 miles on the truck. No I dont have any pics right now I can get some later though.
  7. Sep 18, 2010 at 6:20 PM
    malander
    max
    01 limited trd 4x4
    probably dont need to replace the whole cv half shafts its most likely just the boots have ripped due to the increased angle. if the cvs were bad you would get high speed vibes
  8. Sep 18, 2010 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Maybe. Or they might just fail. There isn't that much grease in there and they are rotating all the time. It depends on how long and how much.
    OP, in all likelihood you are looking at needing to replace your axle that has a torn boot.
  9. Oct 16, 2010 at 9:41 AM
    ssjostrom1980
    Phoenix
    So I decided on just replacing the axels they are only 100.00 after you give them the core. Anyone done this before? Is it a tough job?
  10. Oct 16, 2010 at 10:03 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
