Lifted, Frustrated, and Need Help...Rumble Strip Effect
Discussion in 'Suspension' started by BearintheWoods, Jun 28, 2018.
  1. Jul 3, 2018 at 3:08 AM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Nice! All is well in Toyo land!
  2. Jul 22, 2018 at 7:07 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Could someone post a pic of installed shims?
  3. Jul 23, 2018 at 12:08 PM
    alimjr
    alimjr Well-Known Member
    Almar
    Southern California
    2018 Magnetic Grey Tacoma TRD Sport
    -TRD Pro Grill -TRD Shift Knob -OEM Side Steps -BakFlip MX4 -FN FX Pro Wheels -Toyo OpenCountry AT2 265/70/17
    I have a similar problem. I’ve already ordered the ECGS to see if that stops my vibrations when accelerating and decelerating at 20mph. Going to order shims just incase as well.
    Does anyone have a video on how to install them?
  4. Sep 3, 2021 at 9:22 AM
    CrunchyBeefTACO
    CrunchyBeefTACO Active Member
    South Florida
    2013 Pyrite Mica
    OME 2.5, TRD bead lock wheels,
    https://youtu.be/VBJfwGaZhB4
    So I’ve been scouring the threads to find some “ah-ha” moment regarding my issue. My 2013 had been having some slight vibrations at slow speed decelerations…which became progressively worse then the loud rattle started.
    I have a 2.5 OME lift with the Dakar medium duty leafs, it was installed with the carrier bearing drop. Upon reading the threads I was sure it was a u-joint or carrier bearing issue due to the lift. I took the drive shaft to a shop had new ujoints and carrier bearing installed. Didn’t help at all. Then I added a 2 degree shim to the rear leafs, didn’t help.
    It definitely only happens off the gas and coasting or breaking at slow speeds. My tires look good. I’m not getting any extrme vibes at higher speeds…only slow speeds about 15mph to stop. I took a selfi stick and got a video if anyone has experienced this I’d really appreciate the insight!
