Lifted Regular Cab Picture Thread!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeyD, Jan 10, 2010.
  1. May 18, 2012 at 10:50 AM
    #341
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Me? Mine are the factory clear non smoked. It's a little jarring in person and would look better if they were smoked. Someday, I may do a BHLM or projector retrofit with BHLM.
  2. May 18, 2012 at 11:10 AM
    #342
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Seems like an odd thing to be proud of (from sig a few up). :confused:
  3. Jul 6, 2012 at 12:24 PM
    #343
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    late SUB'D
  4. Jul 6, 2012 at 12:43 PM
    #344
    GEORGE STRAIT
    Da Magic City, AL
    dude needs an AAL or TSB bad
  5. Jul 6, 2012 at 12:56 PM
    #345
    friction
    Charleston, SC
    '08 4X4 RC SR5
    It is a 5 lug.
  6. Jul 6, 2012 at 1:01 PM
    #346
    GEORGE STRAIT
    Da Magic City, AL
    My baddddddd
  7. Jul 9, 2012 at 8:02 AM
    #347
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    anyone have any first hand experience with these?
    http://www.autopartswarehouse.com/de...97TCR515S.html
    my truck has a broken leaf spring. i really didnt want a lift but this is the smallest one i could find that still has the overload leaf. ideallyl, i'd like no lift but if i have to i'll do the 1.5"
  8. Jul 9, 2012 at 8:17 AM
    #348
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
  9. Jul 9, 2012 at 9:32 AM
    #349
    danteisme
    South Western PA
    i picked up a 3 leaf pack that only had 1800 miles on it. it was froma double cab. i assumed since there was one part number for the TSB springs, that all the leaf springs were the same on each truck. the double cab springs appear to be coming up short....
  10. Jul 9, 2012 at 9:40 AM
    #350
    danteisme
    South Western PA
    well this leaf pack is from a pre-runner double cab so its a 6 lug, and my truck is a std cab 6 lug.
  11. Jul 9, 2012 at 9:52 AM
    #351
    danteisme
    South Western PA
    i havent got that far yet. i was measuring from eye to eye the best i could with the stock flat busted leaf packs still on the truck. i could be off just from that though now that i think about it. there is a lot of stuff to wiggle a tape measure through. i was coming up about an inch longer compared to the double cab springs. they are just the stock 3 leafs, so they should keep me at stock height. i may measure again, actually lay the tape measure on the leaf it self and not go from eye to eye. they could be throwing me off too, just because the "new to me" leafsprings are off the truck and fully arched.
  12. Jul 9, 2012 at 3:16 PM
    #352
    danteisme
    South Western PA
    alright, i measured both. i'm not sure exactly what this will mean tho in terms of will it fit at the same ride height.
    my standard cab 6 lug:
    the overload leaf measures about 31.5 inches roughly
    the 2nd leaf measures 48.5 inches roughly
    and the main leaf measures 54 inches
    the double cab 6 lug
    the over load leaf is 30 inches roughly
    the 2nd leaf is 47 inches roughly
    and the main leaf is 54 inches
    i dont want to put these on my truck and it squats in the rear as soon as i'm done. any ideas as to what the difference could be in the double cab's 2 leaves coming up about 1.5" shorter than on my standard cab, or why it is shorter?
  13. Jul 9, 2012 at 3:56 PM
    #353
    danteisme
    South Western PA
    true true. i just dont want to spend all this time installing them to find out that now i may have leafs that arent broken, but now the a$$ end sits lower than the front lol. i can't imagine it would though, generally double cabs weight more than single cabs right? they have a little more weight to distribute over those leaf springs.
  14. Jul 9, 2012 at 6:10 PM
    #354
    danteisme
    South Western PA
    eh, i'll give it a shot. i'll have them just install the double cab springs and hope for the best. if it sags, i'll save up for an AAL and down the road get that installed. i'd hate to re-use any part of the springs that already have 90K miles on them.
  15. Jul 9, 2012 at 6:25 PM
    #355
    danteisme
    South Western PA
    well, being in the north east everything has rusted and kind of become one fused piece. after scoping it out, i think every bolt will probably snap as soon as i start this project. i just don't want to run into a situation where i attempt it on the weekend, then everything busts and breaks and then i'm out of luck for a way to get to work on monday. i've done clutches and motor swaps before at my old garage, but i'm not as equipped at this one lol.
  16. Aug 21, 2012 at 7:39 PM
    #356
    WVToyota3214
    WVToyota3214 Active Member
    Tyler
    West Virginia
    Silver 08 Reg. Can 4x4
    Glass pack, Dick Cepek rims new tires, that's it for now
    Got the lift waitin in the tires
  17. Aug 21, 2012 at 7:49 PM
    #357
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    I've been all up inside gertrude lowerzd and raised
    Are you meauring the non install versus installed. IE measuring leafs with weight on them versus measuring leafs with no weight on them. That will give you different measurements.
    It is possible but I do not see Toyota going that far to engineer a seperate leaf pack per chassis configuration. If I am not mistaken all 6lugs have similar if not the same towing capacity per weight. If this were also true we would not just be looking for 6lug leafs we would be looking for chassis specific. Yet everyone just gets 6lug leafs and still get 1.5" of drop. It can not be coincidence that we all ended up with single cab leaf packs.
    If you are looking for only an inch or two of lift why not just get a pack off of a 5lug? Reverse concept used to lower 5lugz.
    BTW whit at the moment. Soon though she will be going in the opposite direction.
  18. Aug 21, 2012 at 10:39 PM
    #358
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
  19. Aug 22, 2012 at 7:54 PM
    #359
    mkuenzli
    mkuenzli Well-Known Member
    Max Kuenzli
    Chattanooga
    11 4x4 2dr. 5-speed manual
    6' pro comp stage 1 with 35' km2s. stereo, 30% tint, 5% tint bar, 8" sub woofer, plasti dip on fenders and bottom of truck. Monroe struts, moogue tie rods, best top soft top camper top.
    i need to go with 285s should i do it now or wait and re gear it when i can, i have a 3" lift with 265s which mean i have so much clearence in the wheel well
  20. Aug 23, 2012 at 12:55 AM
    #360
    671taco
    Guam
    twenty-ten rc
    same here..after i put my 885x's on it made my 265s look small.
    285s and wheel spacers are next on my list.
