Lifted Regular Cab Picture Thread!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeyD, Jan 10, 2010.
  1. Nov 20, 2012 at 5:46 PM
    #381
    TheRedTac0
    TheRedTac0 Just a Taco guy, both food & truck
    Christopher
    Las Vegas
    2006 5-lug Regular Cab Impulse Red
    BHLM, Black Housing Altezza Taillights, 3-piece billet grille, Fatbob's 2.75" Lift with AAL, 15x8 Ion Alloy Wheels wrapped in 31x10.5 Falken's
    I shall play!!!! I have a 5-lug lifted Regular cab running on 31's my street MPG is between 18-20. I Love having a reg. cab!!!
  2. Dec 30, 2012 at 9:46 PM
    #382
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    Anyone have any suggestions for leaving factory overload leaf in?
    I ordered and received 5100s for the front and Wheeler's 3 leaf 1.5" pack.
    I was planning on doing the fronts at 2.5" (and hoping for the best), but with the rear I'm not sure whether I'll want to leave my factory overload in. I have a camper shell and don't foresee ever taking it off. I'm looking to get things as level as possible, or the rear a tiny bit higher than the front.
    Thing that sucks, is that if I set the fronts to 2.5" and it rides super shitty or is unalignable, I'll have to drop it down a notch to 1.75... it seems like just adding the 1.5" AAL (from threads with no mention of overload) and fronts at 1.75 will leave the rear much higher, and higher still if I leave that overload in. I'm not sure how much the camper shell lowers the rear :|
    Eh, that was hard to explain - so if it didn't make sense..
    If you had a regular cab with camper shell always on, wanting a level truck, would you remove the overload leaf, install wheelers 1.5" 3 leaf pack, set the bilstein fronts to 2.5", and expect it level like that? Because if I did have to lower fronts to 1.75" for alignment issues, I would at least be *closer* to level and possibly a tolerable amount of rake without an added .5" from overload.
    I can lower the fronts myself, but the rear leafs I'd like to do right the first time ideally. Not many people mention the rear overload on regular cab lifts :confused: So idunno if they removed or kept.
  3. Dec 31, 2012 at 4:22 AM
    #383
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
  4. Dec 31, 2012 at 10:13 AM
    #384
    Frodellio
    Frodellio Member
    Dan
    Wilson, NC
    '07 Prerunner Reg Cab
    Aries Bull Bar w/ Hella lights, LED Smoke taillights, BFG A/T tires, CCFL Halo Headlamps, Bug shield, Vent visors, 15% tint all around, -Installed: Ipod cord, power locks, tow package... Red Calipers Deep Dish Land Cruiser Forged Rims
    My 2007 Reg cab....gotta love the look of a lifted reg cab.....
  5. Jan 18, 2013 at 5:40 PM
    #385
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    Merp. Finally can join in on this thread. Did fronts yesterday (had done them day before yesterday but we didn't do it quite right). Solo fronts with hand tools was pretty damn easy after learning how to do it the night before. Rears took maybe 3 hours combined, spent a lot of time using a dull hack saw trying to cut off factory leaf centering pin bolt cause I couldn't get a good grip on the circular thing on underside. Finally got it held tight enough with wire crimp/cut/strip tool of all things. Then had to use that same damn dull hack saw to cut off the excess on new centering pin bolts :rofl:
    Pretty much near level on perfectly level ground, I do have my camper shell on the back though and about 200 lbs between my new floor jack, stands, boards, old parts, and tools. Rides great, no noise or vibrations yet but I've only had it up to 50mph. Will get aligned tomorrow and take 'er on interstate. Bilstein 5100s up front, stock coils. Wheelers 3 leaf progressive with stock overload left on, stock shocks in rear (will upgrade soon but for now it rides fine? Guess I haven't tested to see if the shocks are at their limit with this).
  6. Jan 21, 2013 at 3:21 PM
    #386
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    Alright, so I got my alignment today.
    Cheapo setup: 5100's up front at 2.5" on stock coils, Wheelers 3 leaf progressive AAL on rear with stock shocks, overload leaf left on.
    Drives straight as an arrow. Feels fine on the road. No strange noises at any speed thus-far. No vibrations. Guess I lucked out :eek:
  7. Mar 3, 2013 at 1:03 PM
    #387
    btipsword
    btipsword Well-Known Member
    Ben
    Illinois
    12' Reg. Cab 4x4
    Billys at 1.75,1" Block in rear for now,16x8 Pro Comp 7089,265/75/16 Duratracs,Aftermarket Tow Hitch, Tint 30% front 2 15% rear
    Cleaned her up....
    IMG_20130302_102224_zps13fb3d73_c20b365be49353a9b1497264567f15d972470d34.jpg2013-03-02_10-23-12_943_zps8a443c47_9b9f91cac64fbd83a38378954bf444371733bded.jpg2013-03-02_10-21-53_11_zps99cb17bc_6c2204e6df97981cc4a4b445ca1e63abae33bc16.jpg
  8. Mar 3, 2013 at 5:29 PM
    #388
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    18-20.... The best i ever got was 16 on 32s... Now i get 21-22
  9. Mar 3, 2013 at 6:23 PM
    #389
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    I love Regular Cabs:rasta:
  10. Mar 3, 2013 at 6:51 PM
    #390
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I gotta say, lifted regular cabs are the best looking tacomas!
    To me anyway. I just wouldn't be able to live with one.
  11. Mar 4, 2013 at 3:39 PM
    #391
    THEBEARDEDTACO
    THEBEARDEDTACO Bearded and Tatted
    Lake Havasu
    07 Single Cab 4cyl
    Coilover Spacer 265 70 16 Flow master
    Here's mine new to this forum but not a noob
  12. Mar 17, 2013 at 9:32 AM
    #392
    Neeper17
    Neeper17 Member
    Nick
    Port Matilda, PA
    05 reg cab Tacoma
    Trd rims, all pro rear bumper, custom exhaust, Satoshi grille, BHLM, ATO front bumper, wheel spacers, bilstein 5100's all the way around, OME 884 coils
    Billies all the way around with front set at 1.75 and OME 884 coils. Also got a 2 inch add a leaf.
  13. Mar 19, 2013 at 8:40 AM
    #393
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    Maxtracs
  14. Mar 19, 2013 at 8:42 AM
    #394
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    do you prerunner guys like riding with your nose up like that? i wouldnt be able to..
  15. Mar 19, 2013 at 8:46 AM
    #395
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Helps while jumping, gives more up travel in front suspension so you don't bottom out on everything, keeps front end lighter in sand for the rear weight distribution while on the throttle, just to name a few.
  16. Mar 19, 2013 at 3:45 PM
    #396
    Neeper17
    Neeper17 Member
    Nick
    Port Matilda, PA
    05 reg cab Tacoma
    what size tires are you running?
  17. Mar 19, 2013 at 4:03 PM
    #397
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    33s, going to 35s this month
  18. Mar 23, 2013 at 4:58 PM
    #398
    roadtared
    roadtared Well-Known Member
    Ed
    South Point, Oh
    5-lug 4 Cyl reg cab
    Tirse and drop-in K&N so far.
    Here is my '12 Taco, new tires and rims. 5 lugger and wanting to wait til I can afford a desert-style lift due to reports I'm reading about control arm issues from 5 lug Ready Lifts...any suggestions!
    You all have some sharp trucks! The regular cab is by far the toughest/sharpest looking Taco there is! Side question, the Tacoma emblems, are they held on by adhesive or bolted on?
  19. Mar 23, 2013 at 7:49 PM
    #399
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    adhesive.
  20. Mar 24, 2013 at 9:07 AM
    #400
    roadtared
    Ed
    South Point, Oh
    5-lug 4 Cyl reg cab
    ^^^ Hey Bullwinkle, thanks! Weather's warming up so I'll get out and get it off. I want to do the 'Toy Taco' and prime and paint it flat black. BTW, I enjoyed your seat mod thread. You're right about the seats, I had to get the same type supports for my low back. Anyway, thanks for the response!
