Lifted Regular Cab Picture Thread!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeyD, Jan 10, 2010.
  1. Sep 19, 2015 at 8:33 PM
    #661
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    I can't wait to see it. I have the same truck and came very close to going with the Classic III in Black. Now I'll get to see what it would look like.
  2. Sep 20, 2015 at 10:23 AM
    #662
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Spitfire, nice truck and plans! But being you have a six lug, you have 4.10 gears. 4.88s will be a more appropriate upgrade IMO. Just FYI.
  3. Oct 2, 2015 at 10:02 PM
    #663
    Spitfire72
    Spitfire72 Member
    Dave
    2014 White Tacoma 4x4 Standard cab
    Toytec 3" Coil-overs, Total Chaos UCA, front diff drop, Boss 2.5" lifted rear springs and shocks.
    Part 2
    Howdy...I'm back with a bigger truck!
    The Toytec lift was an absolute joy to install. Everything fit the way it was supposed to and for the most part I am very pleased with the end results.
    When I was originally dialing in the front coil overs after initial installation for an equal 2.75 inches of lift I struggled with the drivers side. It did not lift like the passenger side, 1/4" of threads were equal to 1/2" of lift or visa-versa…it was very predictable. On the drivers side however I had to adjust some, put the wheel back on it, drive it for a minute, jack it back up, take the wheel off, re-measure and then do it all over again...this went on for hours because the measurements never became predictable. It was all over the chart…with the tiniest of adjustments it would pop up like an 1” and then of course the large adjustments would barely yield a change….frustrating as hell!
    Finally I said screw it and drove it back to Seattle 300 miles as is...guess what I'm doing tomorrow? Yanking the wheels off and lowering it 3/4" because it's sitting to high according to Toytec techs. Oh ya, by the way their over the phone measuring process is sure as hell easier than the method they put in the instructions…good grief.
    The reason I called the Toytec in the first place is because when I go over a speed bump or hit a small pothole the front suspension bangs extremely loudly on the rebound. They said lower the truck some and to call them back if the problem persists.
    Also I had trouble with the rear axle degree shims fitting the new Dayton leaf springs that came with the lift, Toytec immediately sent out the right parts, which I’ll be installing this weekend as well.
    Another issue I'm dealing with is the bushings on the new leaf springs squeak so bad that it’s driving me crazy. Crazy enough to rip it all out and start from scratch bad. When installing them I was very careful to not over torque anything back there and everything just fell right together…no force fitting whatsoever. Talking with the techs they recommended I disassemble everything, lube it up with white lithium grease and then reassemble. This will also be a project of mine tomorrow as well. Sure would’ve been nice to have the knowledge in the beginning though.
    The Total Chaos UCA were simple to install and I couldn’t be more pleased with them either. I did have to bend some sheet metal to remove the large bolt, which when reading the reviews and comments this sounded like it was going to be a real nightmare or possible hack job…not even! If I wanted to I could’ve bent everything back, but it’s in a spot on both fender wells where it’s not visible at all…there is zero reason to fuss about this if you are considering installing these on your truck.
    The general ride of the lift is down right impressive. The front end is stiff, not mushy and has very little roll when cornering, but sucks up the road bumps just as well as the stock suspension did. At highway speeds on roads with ruts the steering doesn’t try to dart from side to side at all.
    There is a mild harmonic vibration that comes on at 30 and goes away after 40 mph, but this could be due to the fact the 3° axle shims are currently installed backwards…haha…long story, and another project for tomorrow as well.
    When comparing the OEM spring pack to the new Dayton spring pack I was thinking this is going to be a rough riding buckboard type of old school Toyota lift, but I was totally wrong. The lift requires a 100-mile break in period and then you have to re-torque everything, which I did on North Idaho back-country washboard style dirt roads. The rear end of the truck did not bounce around and skate from sided to side, as one would expect as well. The new springs are amazing and if it weren’t for the nightmarish squeaking it would be perfect.
    Usually when you lift a truck you compromise something, but in this instance the lift and Total Chaos’s UCA actually enhanced the suspension system. Oh ya one thing that I've never seen mentioned...after this lift I need to have extended parking brake cables made. When the rear of the truck is on a jack they are compromised.
    I can’t forget the wheels and tires. The wheels are 17x8, I think anything bigger and the truck would start to loose it’s tough and durable look. The tires as mentioned in my previous post are 265/70R17 Goodyear Wrangler Duratracs, and I’m really pleased with these tires. They don’t rub at all, they make very little road noise and cruise down the freeway at 80 without issues.
    Yes the bigger tire size zapped what little torque to the rear wheels was originally available and basically turned the truck into a gutless 4 speed with a really tall 5th gear. So a re-gearing is definitely in the works for this RC taco of mine.
    “BDL5589” I certainly appreciate your comment/info about my stock ratio and to be honest I thought I had a 3.58 gear ratio. Honestly from the beginning the truck has been way too high geared so I’ve been looking forward to re-gearing it before installing this lift. I just want to make sure I don’t end up with a truck that turns 3400 RPM at 80mph.
    After it was all complete the truck with the lift and larger tires achieved 4" of lift in the front and 5” in the rear.
    Super happy I found this forum and now have a place to talk about all this stuff. As in my real life I don’t know any 4 wheelers and especially RC taco enthusiasts here in the Seattle area and for that matter probably don’t want to :)
    Next projects coming up for me and this truck are going to be finding a welder to weld on these 4xInnovations rock sliders I have sitting here in my apartment and finding the balls to rip apart my dash to install this Rostra Cruise CTRL.
    As always I’m totally interested in what anyone thinks about any of this stuff…so please feel free to comment with all your advice, experience, ideas and opinions...thanks to you all!
    The finished product.
    See you cant see that any sheet metal has been bent can you? And on the other side the battery box is covering it as well.
    Here you can see the transfer case lowering kit has been installed, which took about 10 minutes total to complete.
    The shiny metal hockey puck like spacers and longer bolts plus the hardware to lower the skid plate is what it consisted of.
    17x8 Mickey Thompson classic 3 wheels with 265/70R17 tires. That little front mud flap had to be removed d/t a sharp turn while backing up rub.
    Here is what stock rims and tires 245/75R16 look like on the truck after the the lift was installed.
    My N. Idaho pit crew kept me entertained for most of the day :)
  4. Oct 2, 2015 at 10:18 PM
    #664
    Dmesser92
    Dmesser92 Well-Known Member
    Dylan
    Easley, South Carolina
    2023 Tacoma SR AC V6 4x4 | 1991 Toyota Pickup 4x4 DLX V6
    Really love the look of these, great looking truck!
  5. Oct 2, 2015 at 10:24 PM
    #665
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I love it! Looks like the 2nd gen version of mine.
    PS: I think your axle shims are installed correct.
    Dalandser and ancient11 like this.
  6. Oct 11, 2015 at 10:07 PM
    #666
    5power
    5power Member
    Spitfire72 wow its looks great!! Keep us updated RC are the best..
  7. Oct 12, 2015 at 9:50 PM
    #667
    TJLILMAN
    TJLILMAN Well-Known Member
    Colorado Springs
    '08 Prerunner
    Cruise control is an easy mod. Best thing I did for my truck
  8. Oct 28, 2015 at 7:22 PM
    #668
    trogdon23
    trogdon23 Active Member
    Stock base model 4x4 2012 taco reg cab
    Long shot but what kind of setup do you have? Fo you still like it?
  9. Nov 1, 2015 at 2:03 PM
    #669
    avenger44
    avenger44 New Member
    Shakopee mn
    13 tacoma 4x4
  10. Nov 1, 2015 at 2:03 PM
    #670
    avenger44
    Shakopee mn
    13 tacoma 4x4
    It's getting there
  11. Nov 1, 2015 at 3:50 PM
    #671
    Yotabilly
    The Bluegrass
    My truck is "gettin there" . Yours is there. That thing is nice. What bumpers are those?
  12. Nov 4, 2015 at 7:39 AM
    #672
    trogdon23
    What are you geared? How bad is mpg?
  13. Nov 10, 2015 at 5:06 PM
    #673
    Red_Taco33
    Red_Taco33 Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    Hey, I have the Rough Country 6 inch lift. I wouldn't recommend it though man. The block lifts ruin the rear leafs, especially because Toyota springs in the first place aren't too strong.
    trogdon23[QUOTED] likes this.
  14. Nov 23, 2015 at 6:21 PM
    #674
    BlackBetty11
    BlackBetty11 BlackBetty11
  15. Nov 23, 2015 at 6:25 PM
    #675
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    5d5b2c7f1993f7e4dd3e552b8299d40c_09e739ffcdd1661bb458ce2c8b1ca80d41349233.jpgb75acac32f4fe200043421f009bfce42_78dfd522e66d8933b3a2277a317328b22d12f37f.jpg64670fabc4fa9a84c0fbf7ab6b30b061_c9d326eed18186d1449ac27ac2d729937df79858.jpg1568b730d2614dc893fd75558f8de5c3_e8d0edbc212f3b3d27cbd98f6fec6dfdc3f3a666.jpg
    My pile
    Dalandser and tacoburrito like this.
  16. Nov 24, 2015 at 3:36 PM
    #676
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    very clean looking!
  17. Nov 24, 2015 at 3:37 PM
    #677
    tacoburrito
    boston
    2013 regular cab
    nice moth! how do you like the ARB bumper
    Mothman[QUOTED] likes this.
  18. Nov 24, 2015 at 3:50 PM
    #678
    Mothman
    Advance
    single cab
    It's a quality bumper for sure.. but ill probably end up with a hybrid tube plate bumper at some point
  19. Nov 24, 2015 at 4:06 PM
    #679
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    the black on black looks good!
  20. Nov 24, 2015 at 4:12 PM
    #680
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    Just gave her a bath.
