Lifted Regular Cab Picture Thread!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeyD, Jan 10, 2010.
  1. Jan 21, 2021 at 12:27 AM
    #1041
    Prezzzv
    Prezzzv Member
    Phx, AZ
    ‘08 Tacoma Reg Cab 4x4
    Ditched the spacer and tossed in the ome’s and an aal over the weekend. Gave a lot more lift than I was expecting, but I like it. Only thing is the 265’s are starting to look pretty small to me
  2. Jan 21, 2021 at 8:46 AM
    #1042
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    are those the Rock Trix wheels? i was looking at those for a little, but went in a different direction. but they actually look kool on the reg cabs!
  3. Jan 21, 2021 at 9:00 AM
    #1043
    Mastiff37
    Mastiff37 Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    What's the next standard tire size up from 265/70R16 in this crazy metric designation? I believe the 265/70 is 30.6 x 10.4. I think I could fit 1-1.5" more tire with my modest lift, so maybe as much as 32" diameter. Would like to keep the 16" wheel size.
    I got 1.5" of lift from 3rd gen TRD take offs:
    SSTacomamama, JRYTacoma and bluezzy like this.
  4. Jan 21, 2021 at 9:28 AM
    #1044
    Maxx
    Maxx Well-Known Member
    I used to run 255/85R16 Toyo MT's on my '13 regular cab when I had it. Fit the truck really well and barely rubbed when the tires were new. I miss that truck a lot.
  5. Jan 21, 2021 at 12:06 PM
    #1045
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    You could go to 265/75/16 (approx 1" taller) or 275/70/16 (approx .5" taller). If you go to a 17" wheel, you can get 275/70/17 which is about 1.5" taller.
    Mastiff37[QUOTED] likes this.
  6. Jan 21, 2021 at 8:39 PM
    #1046
    Prezzzv
    Prezzzv Member
    Phx, AZ
    Yeah they are. Really impressed with the quality considering how affordable they are. Very happy with them
  7. Jan 22, 2021 at 6:14 AM
    #1047
    SixtyDashOne
    Collegeville, PA
    Thats awesome man. Thank u.
  8. Jan 31, 2021 at 8:31 PM
    #1048
    Mastiff37
    Tucson, AZ
    Do you guys think I can fit 32" tires (265/75R16) with my 1.5" lift? The ones on there measure about 30", though the converter says 30.6".
    whatstcp and bluezzy like this.
  9. Jan 31, 2021 at 9:16 PM
    #1049
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
  10. Feb 1, 2021 at 7:56 AM
    #1050
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    Don't measure the tire with the truck on the ground, the weight compresses it a bit so you lose .5-1" of overall height. And not all brand tires measure out to the same dimensions as the calculators so try to look up the individual brand tire and size specs. If you go to tirerack.com you can see the true size under the specs area.
    ontarioyota likes this.
  11. Feb 1, 2021 at 8:10 AM
    #1051
    Mastiff37
    Tucson, AZ
    I've been reading the threads on P vs LT. The trails are all pointy rocks and stuff around here, so I'm hesitant to stay with P even though I'm expecting to be 98% pavement. There does appear to be some confusion in the threads regarding load rating vs P/LT too. I think people are getting rough rides because they get E load rating and have them pumped up to 60+ PSI. Maybe if I get aluminum wheels to replace the steel I can offset some of the weight gain in the tire and not get too bogged down with my little engine.
    Here's one candidate, though I don't have a weight on it (Toyo):
  12. Feb 1, 2021 at 6:59 PM
    #1052
    Mastiff37
    Tucson, AZ
    So I've been looking at wheels a little. I think my stock steelies are 7" width with 30mm backspacing. Most aftermarket options want to be 8" with 0 backspacing. If I'm thinking about it right, that'll push me out like 2". Do most guys go this route, or limit themselves to wheels with factory backspacing? Incidentally, anyone know the weight of the factory wheels?
  13. Feb 1, 2021 at 7:48 PM
    #1053
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    The difference is closer to being pushed out 1.75" farther than stock. My truck had some 16x8 with 0 offset (4.5 backspacing) on it when I first got it. With 285/75/16 tires, they didn't really stick out that much. With narrower 265 tires it will stick out a little less.
    Especially compared to the 305 tires on 17x8.5 with -10 offset that are on the truck now.
  14. Feb 1, 2021 at 8:38 PM
    #1054
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    These are 8" and zero offset.
    Mastiff37[QUOTED] and bluezzy like this.
  15. Feb 2, 2021 at 6:33 AM
    #1055
    Mastiff37
    Tucson, AZ
    What tires are those? Also, cool topper.
    Bikinaz[QUOTED] likes this.
  16. Feb 2, 2021 at 8:37 PM
    #1056
    Bikinaz
    Hey You!
    Phoenix, AZ
    Thanks! Pirelli Scorpions MT in 265/75R16. I'm due for new tires this year just based on age. I may try the Yokohama M/T or maybe another set of the Scorps. Or maybe 255/85r16? :deadhorse:
    I've been real happy with the topper. Best Craigslist find ever.
  17. Feb 3, 2021 at 6:45 AM
    #1057
    Mastiff37
    Tucson, AZ
  18. Feb 3, 2021 at 2:33 PM
    #1058
    Bikinaz
    Hey You!
    Phoenix, AZ
  19. Feb 3, 2021 at 2:44 PM
    #1059
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    That's interesting I was looking at a set of the 235/85-16 (31.7") Scorpion MT's at my local discount and it says they have them online. I wonder if it's just their remaining stock.
    265/70-16 Pathfinder ATs - OME 884s/90021 up front & Medium Duty Dakar pack/60091 in the rear
    rcn and Yotabilly like this.
  20. Feb 3, 2021 at 7:56 PM
    #1060
    Bikinaz
    Hey You!
    Phoenix, AZ
    Yeah I didn't see the 265s on DTC web site, but I bet they could order them for ya. At the very least DTC could install them for you if you can find them online.
