Lifted Tacoma gas mileage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dkarmstrong, Jan 24, 2021.
  1. Jan 24, 2021 at 8:42 AM
    dkarmstrong
    dkarmstrong [OP] Member
    2021 double cab tacoma long bed
    3" lift, 35" tires, 17" rims
    Hello friends. I really appreciate all the help I got in my question about racks and tonneau covers. Here is my new question. We lifted my Tacoma 3” and put bigger rims and tires on it because we liked the looks. My gas mileage went from 18-20 mpg to 14-16 mpg. Is this what happens to everyone who has made these mods or am I special?
    How do you decide if it is worth it?
    AZYotes and Malvolio like this.
  2. Jan 24, 2021 at 8:48 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I'd say normal.
    You have added weight. You have increased wind drag.
    This takes fuel to haul this weight down the road and overcome the wind resistance.
    MaverickT883, Malvolio and RedWings44 like this.
  3. Jan 24, 2021 at 8:51 AM
    loltisadam
    loltisadam Member
    Adam
    San Diego
    2021 DCLB
    Definitely a standard to see a drop in mpg.
    It all comes down to practicality, are you actually going to go out and use your truck to it’s abilities as a lifted 4x4 or is it just a commuter? And ultimately is the drop in mpg because of a lift and bigger wheels something you can live with because the truck makes you happy
    MaverickT883 and Malvolio like this.
  4. Jan 24, 2021 at 8:54 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Normal,,, could be worse actually
    Everyone's situation is different- if you're inherently wealthy it doesn't matter. If you're in debt and living paycheck to paycheck, hell no! ,,,,, And everything in between. Hell, everyone's gas prices are all over too. Another factor: how bad do you actually need the lift and tires? They for cool, or do they get you to work everyday?
  5. Jan 24, 2021 at 8:54 AM
    dkarmstrong
    That is helpful. Thanks!
    Malvolio likes this.
  6. Jan 24, 2021 at 8:55 AM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    That’s a pretty typical situation really only two ways to fix that. 1) go back to stock or 2) regear to compensate for the larger tires.
  7. Jan 24, 2021 at 8:55 AM
    dkarmstrong
    Well that happiness factor is a big one. Thanks for pointing that out!
  8. Jan 24, 2021 at 8:56 AM
    dkarmstrong
    Good answer!
  9. Jan 24, 2021 at 8:57 AM
    dkarmstrong
    Good to know. Thanks! Guess Im glad it isn’t worse!
  10. Jan 24, 2021 at 8:57 AM
    dkarmstrong
    Thanks!
  11. Jan 24, 2021 at 8:58 AM
    Knute
    Yes, you need to be careful with modifications.
    Some are for added function.
    Some are for appearance.
    Me, I will only do a modification for added function. Appearance is secondary for me.
    Malvolio, hiPSI, Paul466 and 2 others like this.
  12. Jan 24, 2021 at 8:59 AM
    dkarmstrong
    I guess I can live with it. The lifted truck does make me very happy! I guess I just didn’t anticipate that much of a drop. Thanks!
  13. Jan 24, 2021 at 9:17 AM
    gnarlycaveman
    gnarlycaveman Member
    Greg
    19' Tacoma
    I have a 3 inch lift on 285's on a 18 inch wheel and i carry work equipment that weighs around 250 pounds and i average 15.5 on conservative days and as bad as 13 on moderate driving. I would like to know everyones mileage on a lift. I had a 2016 with a 3 inch on 275s on a 20 inch wheel and was getting like 18 to 21 normally. But i guess how knute said the width of tires and even if theyre mud terrains can impact gas massively than if you went with a radial and say a 10.5 inch tire instead of a 11.5 inch.
    TRDSport10 likes this.
  14. Jan 24, 2021 at 10:30 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Very true! If one has $$$ falling out of their butt, doesn't matter what you do to yer truck.
    If you like the lift and big tires and can afford to feed yer rig gas .. No BFD.
  15. Jan 24, 2021 at 10:38 AM
    ToyoProTaco
    ToyoProTaco Well-Known Member
    2020 Magnetic Gray Metallic Tacoma TRD Pro
    How are you checking your MPG? Larger tires will screw up the speedo and mileage giving you bad readings. If you didn't correct it, you will show much lower than it actually is getting.
    BMH, TRDSport10, Malvolio and 5 others like this.
  16. Jan 24, 2021 at 10:49 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Sounds normal. It’s the bigger/heavier tires that do the most damage, but it all contributes.
    People who claim big tires and lift resulted in “no major difference in mpg” are outta their minds.
    3” is a big lift on a taco. Lots of additional air resistance and turbulence under the truck. This is a bigger factor at speed.
  17. Jan 24, 2021 at 10:54 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Normal because... physics.
  18. Jan 24, 2021 at 11:04 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
  19. Jan 24, 2021 at 11:09 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    This is correct and often overlooked.
    TRDSport10 and Malvolio like this.
  20. Jan 24, 2021 at 11:09 AM
    exiquioloza
    exiquioloza Well-Known Member
    Jr
    San Francisco Bay Area
    2019 Toyota Tacoma TRD Sport 4x4
    Has anyone done a OV tune to help mpg?
