Lifted Tacoma gas mileage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dkarmstrong, Jan 24, 2021.
  1. Jan 24, 2021 at 11:13 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    don't get your hopes up lol, best way to get your mileage back is a re gear. Have both and i get 13mpg, gas isn't something i worry about its something you'll always have to buy...
    exiquioloza[QUOTED] likes this.
  2. Jan 24, 2021 at 11:15 AM
    exiquioloza
    exiquioloza Well-Known Member
    Jr
    San Francisco Bay Area
    2019 Toyota Tacoma TRD Sport 4x4
    Yeah I agree. I lifted my truck and installed bigger tires because it makes me feel good about my truck. My truck isn’t my daily driver so I’m not worried about 16 MPG I get.
    how much does a regear cost? Parts and labor? Have you gone it?
  3. Jan 24, 2021 at 11:24 AM
    Dirtridercrf250
    From ECGS w/o front locker + new bearings was a lil shy of $1500 and retaining the OEM locker Rear $2400 with a solid spacer and Koyo Bearings. I didn't have to pay labor..
    I'm glad you like the truck i do to, for maximum drivability i recommend the OVT and re-gear it completes the truck and feels the way it should.
  4. Jan 24, 2021 at 11:27 AM
    exiquioloza
    Jr
    Yeah that’s about what the lift and wheels and tires cost. Hmmm something to consider but I will hold off right now. I bet you have more power huh?
  5. Jan 24, 2021 at 11:30 AM
    Dirtridercrf250
    lil bit more get up and go, no more pre detonation under load. I have the black widow muffler with a exhaust reroute with mandrel tubing for better flow it. I did everything complete package 100% better than it was when it rolled off the lot.
  6. Jan 24, 2021 at 11:31 AM
    exiquioloza
    Jr
    Very nice.
  7. Jan 24, 2021 at 11:43 AM
    Dirtridercrf250
    goes good. the Mag supercharger looks good.. I can 1UZ for less or SAS both are in its future.. F- MPG
    SatlyPartiot408 likes this.
  8. Jan 24, 2021 at 11:55 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol regearing will not magically improve your mpg back to stock.
    The hammer, Chew and WHITE LONGBOI like this.
  9. Jan 24, 2021 at 12:00 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Changing ONE thing may result in negligible fuel mileage loss. But you did several things and they add up
    The lift increases wind resistance.
    Taller tires make the engine work harder to turn them.
    Wider tires increase rolling resistance.
    More aggressive tread increases rolling resistance.
    Doing any one of those things might not reduce fuel mileage enough to be noticeable. But if each one cost you 1 mpg then that explains things.
    exiquioloza and Aqualoon like this.
  10. Jan 24, 2021 at 12:28 PM
    WHITE LONGBOI
    WHITE LONGBOI Well-Known Member
    White 21 DCLB OR 4x4
    The larger and heavier your wheels are, the less efficient it will be. No gearing or tuning is going to fix that. It will always be worse. That being said, gearing and tuning could possibly help improve it slightly but that's a big expense and not worth it for MPG alone
    zoo truck likes this.
  11. Jan 24, 2021 at 1:51 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Exactly what I was thinking. A Quote my Dad would tell me! RIP DAD
  12. Jan 24, 2021 at 2:08 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Normal,Tacomas have bad gas milleage too begin with,lifting them makes it even worse,my 94 Ford 4x4 F 350,460 v-8 gets the same gas milleage as Tacoma.
    71tattooguy likes this.
  13. Jan 24, 2021 at 2:17 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    Ya definitely not I guess a little disclaimer is help on that point haha but it helps in some regard.
    hiPSI[QUOTED] likes this.
  14. Jan 24, 2021 at 2:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Your 94 4x4 f350 with a 460c.i. gets same mpg as your tacoma? I do not believe that.
    Is your taco stock?
    The hammer, hiPSI and Chew like this.
  15. Jan 24, 2021 at 4:58 PM
    #35
    Myles G
    Myles G Well-Known Member
    Myles
    I get 10-14 on 4 inch lift and 35s
  16. Jan 24, 2021 at 6:42 PM
    #36
    AZYotes
    AZYotes Well-Known Member
    Glendale, AZ
    '20 TRD Sport Previous - '14 Prerunner Access Cab
    I'm right there with you. My range is exactly the same, 14-16.
  17. Jan 24, 2021 at 6:58 PM
    #37
    MuleyCrazy13
    MuleyCrazy13 Well-Known Member
    My tundra gets 13-14 mpg. And I’m running 295s (34.5”) tires. I can’t believe the tacos are getting similar mileage when lifted. I used to own a 05 Tacoma with the 4.0 and I ran 285s on it and I used to remember getting 16-18mpg out of that truck. I miss that old 05.
  18. Jan 24, 2021 at 7:28 PM
    #38
    4wdmurph
    4wdmurph Active Member
    LA
    2016 Tacoma TRD Off Road
    Interesting. Older model has better gas mileage o_O
  19. Jan 24, 2021 at 7:41 PM
    #39
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    If your driving operation requires it, then it's a no brainier. Better lose the mileage than truck damage. If It's just for looks and joy factor, it gets more complicated. You then need to factor in an uncomfortable ride, noise, additional maintenance and repairs too.
    Hope that helps
    71tattooguy and Junkhead like this.
  20. Jan 25, 2021 at 12:15 AM
    #40
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    I did OVtune and MPG went up from 13-14 to 16+. I've got 33s and stock gears, aftermarket skids and sliders.
