Lifted trucks and towing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by newdles, Dec 2, 2019.
  1. Dec 3, 2019 at 7:58 AM
    Bigfsur
    Bigfsur Well-Known Member
    Don
    2017 White 7559 A/C 4X4 MT
    Clazzio seat covers Oem bed mat $35 china pro grill Snugtop Cab High W/ Yakima racks OME 886 suspension kit 3” Pelfrybilt steel front bumper/1200lb Smittybuilt winch Baja designs lights Switch pros 9100 Method 701 wheels CBI rear steel high clearance bumper
    Until you need to use reverse.
  2. Dec 3, 2019 at 8:04 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    You can tow what you are comfortable towing but but don't suggest the tacoma is not made to tow what they are rated for. It is absolutely made for it provided you have electric brakes and brake controller. An F-150 which weighs only 500 lbs more than a tacoma is rated to tow 12,000 lbs. Not sure how the fuck they justify that though.
    The hammer and GreyBaldTaco like this.
  3. Dec 3, 2019 at 8:12 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    How you put your load makes a BIG difference
    GreyBaldTaco likes this.
  4. Dec 3, 2019 at 8:38 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Feelings.
    If a truck is rated for 6800lbs, it's a conservative bet that it will tow it. It can do it safely. What may not be safe is the way the driver drives the truck with that much weight behind it.
  5. Dec 3, 2019 at 8:48 AM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    Key line, it can do it safely. Can't regulate stupid people.
    The hammer, TacoManOne and abodyjoe like this.
  6. Dec 3, 2019 at 8:51 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    I don't know. It depends on what you are towing and what hitch set up you have . if loaded properly. Like I said my travel trailer is around 5000 pounds. I use a husky WDH with anti sway built in. Never had that push me around and it's been out and about on some windy days.
  7. Dec 3, 2019 at 8:57 AM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    I went to school to drive semi trucks, I can back a 40+ foot trailer, this wasn’t a big deal to back up.
    TacoManOne and GreyBaldTaco like this.
  8. Dec 3, 2019 at 10:01 AM
    Bigfsur
    Don
    I'm referring to the lack of torque the 3rd gen Tacoma has in reverse. I was backing up a hill yesterday with not enough power to move. I've also noticed 4wd high is pretty worthless on a hill.
  9. Dec 4, 2019 at 5:36 AM
    96carboard
    96carboard Well-Known Member
    Your experience is due to a combination of your inexperience, and screwing up the vehicle's balance by mucking with the suspension. There is NO issue with pulling FAR FAR more, safely, than what the sticker says... as long as you are competent and don't compromise the vehicle.
  10. Dec 4, 2019 at 5:38 AM
    96carboard
    Ok, Shemp. Maybe find someone else to load your trailer for you.
  11. Dec 4, 2019 at 5:40 AM
    96carboard
    Its very simple how they "justify" that. The vehicle is NO MORE CAPABLE of handling the load than Tacoma is, but they lobby (bribe) the US government in order to allow them to bend the rules in their favor.
  12. Dec 4, 2019 at 5:42 AM
    96carboard
    Try low.
    That gives you an extra 2.54:1.
    And a small amount of ingenuity can allow you to trick the 4wd ecu into leaving the front ADD disconnected, which results in 2WD-Low.
  13. Dec 4, 2019 at 5:47 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Thats because vehicle weight isn't even close to the only determining factor when they test and come up with tow ratings....
    abodyjoe and The hammer like this.
  14. Dec 4, 2019 at 6:47 AM
    The hammer
    "These specs can vary greatly depending on what engine, axle ratio, cab, and drive your truck has. For example, a 2014 F-150 4x2 regular cab with a 3.7 V6 and 3.55 axle ratio has a maximum loaded trailer weight of 5,500 pounds.
    A 2014 4x4 SuperCrew with a 3.5 EcoBoost V6 and a 3.73 axle ratio has a maximum loaded trailer weight of a whopping 11,300 pounds"
    HP, torque, axle ratio, brakes, tires are just more of the things that count into the towing capacity rating and the Ford F-150 is a beast and just getting started in their lineup.
    abodyjoe and GreyBaldTaco like this.
