lifted, wheel spacers, still running my 33 inch tires
Discussion in 'Suspension' started by wes colunga, Sep 15, 2015.
  1. Sep 15, 2015 at 11:21 AM
    wes colunga
    wes colunga [OP] New Member
    2006 tacoma prerunner 2wd
    I recently installed a add a leaf kit that added 1.5 inches to the front and 2 inches to the rear. On top of that I added 1 inch wheel spacers and upgraDed to a bf Goodrich all terrain 33inch tire.
    So how the hell can I stop it from rubbing?
    New bumper? New fenders? Get custom and hack it?
  2. Sep 15, 2015 at 11:22 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  3. Sep 15, 2015 at 11:23 AM
    la0d0g
    running for the hills
    For crawling not hauling
    How does an add a leaf raise the front of an IFS truck?
    moe2o4 and geekhouse23 like this.
  4. Sep 15, 2015 at 11:23 AM
    wes colunga
    So u r referring to cutting the fender behind the tire yes?
  5. Sep 15, 2015 at 11:24 AM
    wes colunga
    The kit came with blocks for the front and leaf for the back
  6. Sep 15, 2015 at 11:25 AM
    la0d0g
    Ah, spacer lift, got it. I would cycle the suspension and see where you're rubbing. Depending on where, you can take action. Most remove the front mudflaps, maybe a CMC is needed. You won't know till you get under there and look.
  7. Sep 15, 2015 at 11:26 AM
    geekhouse23
    Either lift it more or cut..either way you have to cut.
    I removed front mudflaps, plastic near the mudflap mounts, flattened the pinch weld, and a CMC
    wes colunga[OP] likes this.
  8. Sep 15, 2015 at 11:28 AM
    wes colunga
    Thanks for your advice fellas, much appreciated .
  9. Sep 15, 2015 at 5:41 PM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    Most people run 3" lift up front as well to keep 33"s rubbing to a minimum.
  10. Sep 15, 2015 at 7:31 PM
    la0d0g
    2.75" with 35s. It's all good.
