lifted with bilsten 5100s and aal
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98Tacoma, Dec 31, 2010.
  1. Jan 1, 2011 at 3:01 PM
    98Tacoma
    98Tacoma [OP] Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    oh ok i cant really notice it unless im concentrating on it. yea i know its a truck not going to ride like bmw.lol
  2. Jan 1, 2011 at 4:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Man, the truck looks really good. Very nice job.
    For your low speed vibe (0 to 20 mph), try lowering your rear driveshaft carrier bearing a little bit. The AAL has probably increased the rear diff angle just a bit. The mounting bolts for the CB are long enough to use with spacers or washers to space it down. Lowering it a 1/4 to 1/2" is a good place to start and very easy to do and undo if it doesn't correct the vibe.
  3. Jan 3, 2011 at 3:01 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    im going to check on that because if it is causing some vibrations im sure that it is not good for it. im going to check that tomorrow thanks man.
  4. Jan 5, 2011 at 6:17 AM
    Dlead
    Dlead Well-Known Member
    Daniel
    North carolina
    1998 toyota tacoma ext cab
    Bilstein 5100s with old man emu coils and 2 inch body and 33s and cold air intake and throttle body spacer.
    Hey man u might also want to make sure carrier bearing isnt bad i looked under mine and my driveshaft was flopping and thats what was causing the vibration on my truck so just make sure the driveshaft doesnt move up and down in the carrier bearing too while your under it.
  5. Jan 6, 2011 at 12:03 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    well i got under the truck today and i guess it is from the lift but im able to see a clean spot on the part that connects from the drive shaft the the part that connects to the diff not sure of the name of it is. i may have to take a pic of it to clarify exactly what it is. not exactly what a carrier bearing is also?
  6. Jan 6, 2011 at 8:48 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That part of the second section of the driveshaft, the part right before the rear diff u-joint is called the slip yoke (among other names). It is designed to move in and out a little as your rear suspension flexes, hence the "slip" in the name. The clean area is likely the difference between now and before the lift. Make sure you grease this when you grease your u-joints. It has its own zerk.
    The carrier bearing is where the two piece rear driveshaft is suspended in the middle. It looks like a metal hoop about 3-4 inches in diameter that surrounds the driveshaft. Here is a thread (with pics) that will help explain dropping the carrier bearing.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/89276-carrier-bearing-drop.html
  7. Jan 6, 2011 at 1:30 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    98 tacoma did you have a good amount of clearance from ucas and spinle?idk whether or not i should buy spacers for the front
  8. Jan 7, 2011 at 9:39 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Don't waste money on the 33's... Just do some cutting and research and get 35's. You will be MUCH happier. :D
  9. Jan 8, 2011 at 9:02 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i am running 32s right now and i have about an inch away fro the uca and the tire i cant notice it rubbing anywhere. i bought new wheels and they seem to have a pretty good amount of backspacing so hopefully it wont hit anywhere. you should be fine without getting wheels spacers unless what ever wheels that you have are factory back spacing or less.
  10. Jan 8, 2011 at 9:05 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    haha i may just stick with the smaller tires. i just sold my nitto mud grapplers cause they were a crazy heavy tire. if i throw in a v8 ill put the 35s on. and ill give you my address if you want to buy me some and ship them to me i know 35s are a little pricey.lol
  11. Jan 8, 2011 at 9:05 AM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    SUPRA TT what year supra do you have?
  12. Jan 8, 2011 at 9:49 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    Looks awesome man!!!
  13. Jan 8, 2011 at 9:52 AM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    lookin good. got my billies and AAL sitting in my garage just waiting for some warm weather to get 'em on
  14. Jan 8, 2011 at 1:11 PM
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i forgot to get tat pic for u ill try and post one tomorrow
  15. Jan 8, 2011 at 1:12 PM
    #35
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    yea it freezing down here so i did mine in our garage that had some heat. coundnt wait till warmer weather was to excited
  16. Jan 8, 2011 at 3:51 PM
    #36
    Supra TT
    Eric
    Indiana
    I've just been a huge fan of the Supra. MKIV. However I prefer the BMW E46 M3 Anyday :D
  17. Jan 12, 2011 at 1:36 PM
    #37
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    i have a 88 mk3 but ive always wanted a mkiv
  18. Jan 12, 2011 at 1:59 PM
    #38
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    has anyone had problems with alignments after installing there 5100s. im able to get my toe to spec. but im not able to realy change my camber and caster much. the encentris just wont move it much at all.
  19. Jan 15, 2011 at 6:47 PM
    #39
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    well i got my new wheels and tires installed today
    15x10 mickey thompson beadlocks
    and 33x12.50x15 goodyear duratracs
  20. Jan 16, 2011 at 10:42 AM
    #40
    98Tacoma
    adam
    V.A.
    1998 V6 xtracab
    any other first gens running duratracs?
