lifted4bangahhelp
Discussion in '4 Cylinder' started by Hinanomon, Oct 4, 2011.
  1. Oct 4, 2011 at 8:45 PM
    Hinanomon
    Hinanomon [OP] Member
    Pukalani
    2011 4cylinder 2wd 5 lug
    tints, sounds
    i have a 4x2 4 cyl. 2011 single cab tacoma. im looking for that lifted look rather then that street look. but i think my engine may be too small. i wanted to just keep it stock and put 31" tires on it. would this effect it in a bad or good way?... sorry, im new at this
  2. Oct 8, 2011 at 11:27 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    5 lugs or 6 lugs on the truck?
  3. Oct 9, 2011 at 2:22 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i think you should be ok, i am lifted and put some armor on this, put 285 heavy tires on mine and i have lost alot of get up and go but i can still wheel the piss out of this.
  4. Oct 9, 2011 at 8:14 PM
    Hinanomon
    Pukalani
    tints, sounds
    5 lug..
  5. Oct 10, 2011 at 6:57 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    well you have pretty limited options, but you have basically three. spacer lift, mid travel and long travel. the last two are produced by Total Chaos Fabrication. the spacer lift is down to two options. Fatbobs or Readylift. Most everyone goes for the fatbobs kit, because it comes with longer rear shocks. you can do 30s, but it will be alittle slower. your gonna need a regear for 31s
  6. Oct 11, 2011 at 3:29 AM
    Hinanomon
    Pukalani
    tints, sounds
    how much do you thinkk itll cost to regear? i think im gonna go with a 2.75 suspension lift and a 3 inch body lift now. i like the lifted look better hah.
  7. Oct 11, 2011 at 7:35 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I know you can get a used 4.10 ring and pinion set off of east coast gear supply for about $145. not sure what else you'll need though. i just started looking into getting the stuff for a regear
  8. Oct 11, 2011 at 10:38 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    I'm pretty sure most members here will discourage a body lift.
  9. Oct 12, 2011 at 7:23 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I second that. I'm going to get a full midtravel lift and install some fiberglass fenders for that prerunner look, along with acouple other things. It won't be cheap, but it will definitely handle being a daily driver and a week of great camping.
  10. Oct 12, 2011 at 12:14 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Depends if you can find gears specific to the 5 lug's rear end carrier for starters. It cost me $476 for ring/pinion and master rebuild kit. Then $125 for the re gear but I brought the third member to the shop.
  11. Oct 12, 2011 at 12:27 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I would (did) go with the "mini" rebuild kit for a 2011 . Those bearings are basically new.
  12. Oct 12, 2011 at 4:01 PM
    Hinanomon
    Pukalani
    tints, sounds
    why is that? it has the look i want. but how does it affect the truck/ride?
  13. Oct 12, 2011 at 4:36 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    I have yet to see a body lift for the truck we have. from what i've seen body lift not done correctly on a truck looks weird. like the body has been twisted.
  14. Oct 12, 2011 at 5:56 PM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    I think it hurts the ride... And I've seen people here say how it's dangerous... I know there's a guy on here now that's having MPG problems and thinks it's his body lift. I'm also pretty sure body lifts take like days to install.
    Though honseslty I don't know much about them... But I'd want my lift to be usable.
    I just know that there's a right way to lift and a wrong way to lift. Check the 5 lugger forum, I know a few guys there have lifted trucks...
  15. Oct 13, 2011 at 3:06 PM
    Hinanomon
    Pukalani
    tints, sounds
  16. Oct 13, 2011 at 3:22 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    body lifts are just not good on any vehicle especially a 3"
    adds leverage to the body mounts and there are a few photos around of cabs ripped off the frame
    its not always about looks. i would never run a body lift on my junk
  17. Oct 14, 2011 at 7:19 AM
    Euphorbia
    Euphorbia Member
    Saltair,Cascadia
    06 2x4 Access Cab, paid for, under 130k km...
