Lifter Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rob_Swoboda, Sep 16, 2022.
  1. Sep 16, 2022 at 6:47 PM
    Rob_Swoboda
    Rob_Swoboda [OP] Member
    02 tacoma trd 6 cylinder 4x4
    Help!!! not a stranger to getting my hands dirty under the hood. with that being said, this would be a big project for me and especially without my dad. When getting into this project what are some of the biggest things i need to pay attention to? What should i be expecting when embarking on this? I absolutely love this truck and don't want to destroy it. It has had a sticky lifter for about 2 months. Is that too long to leave this problem unaddressed? What other potential problems could arise if untreated? Am I overthinking this too much? Please help me save my truck
  2. Sep 16, 2022 at 8:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm pretty sure the 3.4L doesn't have hydraulic lifters, it uses solid buckets and valve clearance is adjusted with shims.
    Is it making noise or why do you think you have lifter problems?
    Nessal likes this.
  3. Sep 16, 2022 at 8:28 PM
    Rob_Swoboda
    yes it is making noise, its a slight tick when the engine warms up. sometimes its present during acceleration and sometimes it's present when it's idols. I put some rosline in it and it helped but obviously never going to be a perfect fix. First tacoma btw
  4. Sep 16, 2022 at 8:28 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    You need to inspect this immediately. But what makes you say it has a sticky lifter? Noise? Noise is OK.
  5. Sep 16, 2022 at 8:31 PM
    MadNachos
    This doesn't sound too serious but the noise under acceleration is not what I would expect from a lifter. Sounds more like an exhaust leak maybe? Make a video and post a link.
    Smokestacks and Dm93 like this.
  6. Sep 16, 2022 at 8:31 PM
    Rob_Swoboda
    yes noise, and what should i be looking for?
  7. Sep 16, 2022 at 8:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Tacoma engines tend to be noisy, the 2nd (4.0L) and 3rd gen (3.5L) v6 engines always tick.
    You could post a video, I'm sure the guys here could tell you if it's normal or not.
    MadNachos likes this.
  8. Sep 16, 2022 at 8:33 PM
    Rob_Swoboda
    ill post a vid tomorrow dont have time or good lighting rn
    Dm93 likes this.
  9. Sep 16, 2022 at 8:35 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    :thumbsup:
    You will need to post it to a video sharing site like youtube and post the link here, you can't post videos here directly.
  10. Sep 16, 2022 at 8:38 PM
    Rob_Swoboda
    ok will do thanks for the heads up:thumbsup:
  11. Sep 16, 2022 at 8:39 PM
    MadNachos
    A clip will tell all. You probably have a couple noises going on and it just takes experience to identify them easily. And even then it isn't always easy.
  12. Sep 16, 2022 at 8:52 PM
    verlaryder
    verlaryder Well-Known Member
    The ticking noise is likely either an exhaust manifold gasket leak, a cracked exhaust manifold or one or more intake valves with excessive clearance that can be fixed by installing a slightly thicker puck like shim on top of the valve lifter bucket. Toyota dealers sell the shims.
    Dm93 and MadNachos like this.
  13. Sep 17, 2022 at 8:15 AM
    Rob_Swoboda
    https://youtu.be/mzMLmzg5XSg
    Here’s a vid of exhaust sounds, and open engine bay. Both head covers, firewall, and front of engine sweep with throttle manipulation
  14. Sep 17, 2022 at 8:20 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Almost sounds like it might have a loose spark plug on the drivers side.
