Lifter tick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Balbadore, Aug 31, 2022.
  1. Aug 31, 2022 at 6:55 PM
    Balbadore
    Balbadore [OP] Member
    Ron
    Base 2014 4x4 Taco
    4 inch Rough Country lift, 33 inch Nitto Trail grappler tires, XD series negative offset wheels
    Ok i have a lifter tick on my 14’ 4.0L 4x4 base Taco. I am worried about spending 100’s on parts that Im not sure will fit, also, i have not been able to find any videos on how to do it. I want to see how it is done to know what parts I need to do the repair myself. I can use the lift at my work, but it has to be done in one day.
  2. Aug 31, 2022 at 6:56 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    You don't have lifters.
    reallifedog and AJKlug1 like this.
  3. Aug 31, 2022 at 7:03 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    the 4.0 is also known for being quite noisy on the valvetrain side of things due to its "lifter" set up. It is commonly referred to as the "Taco Tick." It does mimic a lifter noise but it is completely normal for our engines. Post a video of your sound as we can help you tell if it is the tick.
  4. Aug 31, 2022 at 7:06 PM
    Balbadore
    Ron
    Base 2014 4x4 Taco
    I can get a video up tomorrow. The engine has 67k miles, and this tick is fairly new. Ive heard some quite ticking since i bought it (obviously injectors) but the new sound is moderately loud, i can hear it from in the cab. My first thought was exhaust leak, but its not coming from the manifolds.
  5. Aug 31, 2022 at 7:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The 4.0 doesn't have variable valve lash or variable valve lift (VVL), but it does have variable valve timing (VVT) on the intake cam.
    It has solid shim under bucket "lifters" with no hydraulic lash adjustment thus it is an inheretly noisy engine because there is always a slight amount of clearance between the buckets and the cam.
    Jimmyh likes this.
  6. Aug 31, 2022 at 7:11 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    It seems that the tick can start at any time. When was your last oil change? It can get louder coming up on your interval. Is it louder on the driver side of the vehicle? FWIW I doubt it is injectors that you have been hearing and rather the usual valvetrain noise. Only reason I say that is because you usually can't hear injectors over the valvetrain. Do you have any other symptoms or just the noise?
    SR-71A likes this.
  7. Aug 31, 2022 at 7:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Balbadore[OP] likes this.
  8. Aug 31, 2022 at 7:14 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Shoot you've got me. I work for chrysler and all of the pentastar V6's are VVL's and Ive been dealing with a couple gladiators that have been having issues with them. I got confused because they are both kind of loud. I'll edit that post...
    Dm93[QUOTED] likes this.
  9. Aug 31, 2022 at 7:15 PM
    Balbadore
    Ron
    Base 2014 4x4 Taco
    I did an oil change about a week or two ago and added lifter tick additive to the oil. No other symptoms, but i have other issues that me be covering them.
  10. Aug 31, 2022 at 7:17 PM
    Balbadore
    Ron
    Base 2014 4x4 Taco
    I work at a Chrysler dealership across our heavy line guy. I see new engines replaced on our 3.6L shitboxes all day.
  11. Aug 31, 2022 at 7:17 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
  12. Aug 31, 2022 at 7:18 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea I'm not aware of any Toyota engines that have VVL, heck many of them like the 4.0 didn't even have hydraulic lifters.
  13. Aug 31, 2022 at 7:19 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Yup. They wipe the cams out all day long. Can't forget the plastic oil coolers in the valley that warp every 30k
    Balbadore[QUOTED][OP] and Dm93 like this.
  14. Aug 31, 2022 at 7:21 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Man, I am really embarrassed I mixed those up lol. I think I need to send Toyota an apology for associating chrysler garbage with our awesome trucks
    SR-71A and Balbadore[OP] like this.
  15. Aug 31, 2022 at 7:22 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    If you are referring to that youtube video that isn't the OP's truck
    Dm93 and Balbadore[OP] like this.
  16. Aug 31, 2022 at 7:22 PM
    Balbadore
    Ron
    Base 2014 4x4 Taco
    I dont have any complaints about the 5.7L except space in the engine compartment. The 3.6L cause problems and the 2.4L should not exist.
  17. Aug 31, 2022 at 7:23 PM
    Balbadore
    Ron
    Base 2014 4x4 Taco
    No its not my truck, my manifolds have mud permanently baked on them, lol
  18. Aug 31, 2022 at 7:24 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I would never own a Chrysler product, I see so many issues with just about everything in their lineup on some pretty low mileage stuff from electrical gremlins to engine failure.
    DG92071, Jimmyh and AJKlug1[QUOTED] like this.
  19. Aug 31, 2022 at 7:24 PM
    Monkeybutt2000
    When I first got my 15',it bugged the shit outta me. Whats weird is,once I put it in gear,the sound pretty much goes away. I've pretty much forgotten about it by now.
    AJKlug1 and Dm93 like this.
  20. Aug 31, 2022 at 7:25 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    All the 2.4's around me seem to come with head gasket seepage from the factory lol. yeah the 5.7s are decent if the oil changes are kept up with but they usually aren't and then cam and lifters go. Also can't get past manifolds on those things. With the steering shaft, dipstick, and parking brake cable on the driver side you get like 5 new cuts every time you do one...
