lifting 02 mini tacoma
Discussion in '5 Lug' started by plupo5591, Mar 14, 2013.
  1. Mar 14, 2013 at 11:35 AM
    plupo5591
    plupo5591 [OP] Member
    Paul
    CT
    02 5 Lug
    hey guys I've been reading for a bit and want to do a small lift just to get a little bigger tires on my 02 tacoma reg cab 2.4.
    I was thinking about putting in some v6 coils with a 1.5" spacer lift just to get enough clearance to fit 235/75/15's or 30's.
    I dont offroad except to go out camping or through a field to my buds fire pit. Would this lift work? Thanks for the help ahead of time
  2. Mar 16, 2013 at 10:44 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    with a tire that size your gonna rub pretty good while turning. you need 3"
    + last i saw spacers and v6 coils is still only a 2" lift when you lift these trucks via springs without addressing the weak points it will break. save your money and get yourself a set of 3" lift spindles and an aal or shackles and call it a day.
  3. Mar 17, 2013 at 5:12 AM
    plupo5591
    Paul
    CT
    02 5 Lug
    alright thanks I was planning on doing the spindle lift in the summer anyways, I appreciate the help. Do you know if I'd have to change my wheels because of the backspacing with the spindles or can you keep them stock?
  4. Apr 9, 2013 at 10:17 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    stock wheels will work
