Lifting 1989 toyota pickup 4x4
Discussion in 'Wheeler's Off-Road' started by mac424205, Jul 26, 2012.
  1. Jul 26, 2012 at 8:25 PM
    mac424205
    mac424205 [OP] Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    What is the best kit that I can get for an 89 toyota pickup 4x4. 3.0 l v6 automatic trans. I don't want the 4" lift kits with blocks that I have been finding and I don't want to spend more than a couple hundred. I can install myself and go from there. I prefer new leaf packs and something up front where I don't have to crank the torsion bars too much....
  2. Jul 26, 2012 at 8:29 PM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    Your choices for the front are: ball joint spacers for 1-2 in of lift, torsion bar crank, or drop bracket for 4 in of lift. Or, SAS it. :D
    In your price range... Go for the ball joint spacers. You'll be able to run 33s with them.
  3. Jul 27, 2012 at 4:44 AM
    mac424205
    Mathew
    Chelsea
    ok. what about the rear?
  4. Jul 27, 2012 at 6:23 AM
    H Bomb
    For the rear you can do blocks, add a leaf, lift shackles or a new leaf pack. I have 2in lift shackles and a 4in block. My factory leafs are flat though, so I'm going to replace my blocks with a new 4in lift leaf pack soon.
  5. Jul 27, 2012 at 9:59 PM
    mac424205
    Mathew
    Chelsea
    I don't like the stress that blocks put on leaf packs. Plus mine are flat anyways, so I am going to see if I can find someone to build me a pack for 2.5-3 inches of lift. I am going to go ahead and do the ball joints spacer for the front.
  6. Jul 27, 2012 at 10:00 PM
    H Bomb
    Sounds like a pretty good plan to me!
  7. Jul 27, 2012 at 10:02 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Yeah ball joint spacers are easy to install and pretty cheap.. If you want some really nice and fairly cheap springs for the rear you could try buying some used chevy 63 inch springs.. You can take a leaf out if its too high
