lifting 2012 double cab toyota tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wesphalia, Feb 17, 2017.
  1. Feb 17, 2017 at 1:04 PM
    wesphalia
    wesphalia [OP] New Member
    I am going to lift my tacoma with bilstein 5100s. If I install them in the front and the back with the front at the 2.5 setting how can I ensure the truck will be level?
  2. Feb 17, 2017 at 1:05 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
  3. Feb 17, 2017 at 1:05 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It won't be level.
    Use a measuring tape to determine what lift you need to be "level."
    Measure from the center of the hub to the bottom edge of the fender, and do it on flat ground.
    moondeath likes this.
  4. Feb 17, 2017 at 1:07 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Measure the front and rear of truck. Center of hub to wheel well. What ever the difference from the front to rear is what you need to level. The rears aren't adjustable. You'll have to use a leaf kit to lift the rear.
    T4RFTMFW likes this.
  5. Feb 17, 2017 at 1:19 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Keep researching here on TW before making a final decision. You don't want to have your front billies set to 2.5" for several reasons. Keep them at 0 (or .85" at most) and buy the proper coils to give you your desired lift. Seems like you want 2.5 - 3" so you'll need a new leaf pack in the rear as @moondeath states
