Lifting 22 TRDOR 4x4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LetsGeauxTaco, May 16, 2022.
  1. May 16, 2022 at 2:08 PM
    LetsGeauxTaco
    LetsGeauxTaco [OP] Member
    Todd
    2022 TRDOR
    N/A
    Hey guys
    I know this is probably beating a dead horse for some of you, but I am at a loss; I've read so many threads on here about lifting the Tacoma, my eyes are seeing double now.
    My brother in law has a 2018 2wd and had the dealer install a lift right after he bought it, referring to it as a 3/2 lift, his truck looks pretty good in height. I inquired recently about having the OEM lift installed (called 3 dealers local to me / South Louisiana) and all 3 have stated they do not install them on the 22's as they are having issues recalibrating the TSS or whatever. I call BS, but it is what it is. I do not do any hardcore offroad as there is none around here, will be light. I do however pull a 22' boat with a tongue weight of 400 - 600 lbs. I added sumos to help with the squat, but, I am looking to better the suspension / increase the tire size and all around have a better equipped truck. I do not, but will entertain dealing with the UCA's if need be, but am interested in a similar "3/2" lift as the broinlaw has, albeit, his appears to be a front spacer and a rear block, I do not want to go this route as so many on here are against.
    Please, please, please, help a fella out and advise best route with a $2000, maybe a little more budget..
    Thanks
  2. May 16, 2022 at 2:10 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  3. May 16, 2022 at 2:16 PM
    Gmarch49
    Gmarch49 Well-Known Member
    2020 Quicksand TRD OR
    The typical (but pretty solid) setup is usually Bilstein 5100s with either stock springs or aftermarket (usually Old Man Emu) with an add-a-leaf.
    I personally have 5100s with OME 888 springs and a Deaver 2" add-a-leaf. Absolutely love it.
    The step up from that would be a Bilstein 6112/5160 setup. For towing a boat, sumo springs are great, if you want better performance while towing you might benefit from a full leaf pack.
    Just my .02
    clownkillerloaf and TnShooter like this.
  4. May 16, 2022 at 2:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    3/2 is
    3” lift front
    2” lift in rear
    That pretty much puts the truck level.
    Any weight on the back, like your boat, will have you squatting in the rear.
    I say stick to 2.5” or less of lift. Unless you want to buy UCA to achieve a decent alignment.
    trilogymac likes this.
  5. May 16, 2022 at 3:52 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Deaver springs read about ones for guys who tow?
  6. May 16, 2022 at 3:59 PM
    Lava-road
    2019 trd-off road
    Also look at Supreme Suspension RAS - Roadmaster Active system? I want one too , but NOT sure if for off roading?
    Aloha
  7. May 16, 2022 at 4:06 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I plow snow in winter and haul or tow 23’boat/trailer in summer.
    I went with Bilstein 5100’s , as well as Timbren SES on all 4 corners. Front shock settings are 2”, rear has a 1” Eibach block. So 2/1 lift/level. Ive had no reason to change springs in front, or use different leaf-packs in the rear. If my needs change I can always go higher/add more leaves.
    I do 95% on road driving, 5% mild off road. No issues with TSS, or needle bearing ,Ive had this for 12 mos so far on my ‘21 Sport. Also had an identical setup on my ‘09 OR . That lift gave me 10 years of trouble free operation when I sold the truck.
  8. May 16, 2022 at 4:08 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    For $2000, the best option in my opinion would be the bilstein 6112/5160 combo and a heavy leaf pack in the rear. I would say medium, but it’s not enough. I have a camper shell and 2 dogs in the back and it’s already feeling that weight.
    I have the ome rear leaf pack. Lot of people don’t like them, but I’m not sure why. I bought mine $400 used on Craigslist
  9. May 16, 2022 at 4:54 PM
    LetsGeauxTaco
    Todd
    2022 TRDOR
    N/A
    Thanks for the replies thus far fellas
  10. May 16, 2022 at 9:38 PM
    motox379
    motox379 Active Member
    Sean
    MA.
    2017 TRD Off Road
    Another great choice is Icon Vehicle Dynamics lifts, you can get a stage 1 or 2 for around $2000 give or take a few bucks.
    pahaf likes this.
  11. May 17, 2022 at 9:18 AM
    pahaf
    paul
    NorCal
    The only thing to also consider is the valving of the shocks. Wish I did my research…..the bilstein and icon and digressive valving which are more firm for daily driving. Fox and kings are progressive.
  12. May 17, 2022 at 4:04 PM
    EFG
    EFG Well-Known Member
    Eddy
    New England
    2022 Tacoma TRD Sport
    factory lift kit, Stinger Off Road Stereo, Customized leather interior, Backflip X4S Tonneau,
    How does lifting the truck affect the front back and side cameras?
  13. May 17, 2022 at 4:33 PM
    pahaf
    paul
    NorCal
    There is a sensor in the front grill in the tacomas. It monitors the cars in front of the truck. It is supposed to be at a certain height. Once you lift the truck, you have to recalibrate it.
  14. May 17, 2022 at 5:27 PM
    EFG
    Eddy
    New England
    Is this something anyone can do?
  15. May 17, 2022 at 5:37 PM
    Bigmatt503
    Bigmatt503 Well-Known Member
    I just installed the Eibach pro kit and it's fantastic. I got it for $691at wheelers offroad.
  16. May 17, 2022 at 5:45 PM
    EFG
    Eddy
    New England
    How high?
  17. May 17, 2022 at 5:52 PM
    pahaf
    paul
    NorCal
    No. You need the dealer to re program it
