Lifting 2nd gen Tacoma 5 lug
Discussion in '5 Lug' started by Nazareth7, Oct 31, 2022.
  1. Oct 31, 2022 at 8:20 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hello Tacoma community,
    I have question I tried lifting the front of my 5 lug 2nd gen Tacoma , and there’s rust that makes the bolts of control arm and sway bar not to loose at all, is there another easy way of getting the strut out without doing those? Thanks like maybe compressing the spring does that work? Thank you the lift is 2.5”
  2. Oct 31, 2022 at 8:37 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Unfortunately both of those bolts are going to need to be removed. Not sure what tools you have on hand but you could always soak the bolts over night with a penitrant like wd40. In the morning if you don't have an impact put the socket on and wack the ratchet with a hammer. Also leverage is your friend like a pipe something to give you more. It sucks when there's rust good luck man.
  3. Nov 1, 2022 at 5:52 AM
    Nazareth7
    2007 Tacoma 2x4
    thank you so much and btw I like your name HHaha 5 lug fury
    5 Lug Fury[QUOTED] likes this.
  4. Nov 14, 2022 at 8:58 PM
    tmors424
    tmors424 Member
    Tom
    2010 Tacoma Base Regular Cab 2.7 Sand Pearl
    Ready lift leveling kit, 235 75 15 BFG KO2 tires, KMC black alloys, black headlights, black fog lights, black grill, tonneau, new OEM recalled frame and suspension, emergency LED lighting package
    Try using PB Blaster, liquid wrench, or make your own rust penetrant mixing 50/50 transmission fluid and acetone. I mix my own and it works great. Also get yourself a hand held propane torch and try some heat after letting it soak. Good luck!
    5 Lug Fury likes this.
