Lifting 2wd Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by csmurray1, Feb 25, 2015.
  1. Feb 25, 2015 at 5:46 PM
    csmurray1
    csmurray1 [OP] Member
    I have a 2013 2wd Tacoma I recently purchased and I would like to lift it, I would like to avoid a body lift. Any suggestions or comments?
  2. Feb 25, 2015 at 6:23 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    5 lerg or 6
  3. Feb 26, 2015 at 5:20 PM
    csmurray1
  4. Feb 26, 2015 at 5:21 PM
    csmurray1
  5. Feb 26, 2015 at 5:25 PM
    TXAggieTRD
    TXAggieTRD Well-Known Member
    Andrew
    TX
    '11 Pre-Runner V6 TX TRD Package
    Spacer lifts typically stiffen the ride, but aren't too bad. I'm currently running a 2.5" Pro Comp Spacer in front and a 1" block in rear. But I'm about to upgrade to a 4" Maxtrac Spindle and Bilstein 5100s. Depending on how high you're trying to go, here's a few suggestions:
    <2" : Bilstein 5100s all around
    2"-3": Spacers (least recommended)
    4"< : Spindle Lift with combinations of AAL, Shocks and/or blocks
  6. Feb 26, 2015 at 5:26 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Spindles work with 5 lugs?
  7. Feb 26, 2015 at 5:39 PM
    csmurray1
  8. Feb 26, 2015 at 6:03 PM
    PSU Taco85
    optional
    That toytec lift won't work on the 5 lerg. I think the fat bob's stuff is the only thing offered for them
  9. Feb 26, 2015 at 6:10 PM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    X2
  10. Feb 26, 2015 at 6:18 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    ICON has some rear shocks for the 5 Lug. Also check out all the gear Total Chaos makes
  11. Feb 26, 2015 at 6:22 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    I just did Billy's all around from DSM. I have a 2007 dblcb 4.0 l TRD sport prerunner. I set the front at the top adjustment. The front sits at 38 1/4 and the rear is at 37 1/4. Its a little bit stiff up front. I will be lowering to the lower clip(3rd) from the bottom and see what happens from there.
  12. Feb 26, 2015 at 6:23 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Bilstiens wont work on the 5 lug unfortunately.
  13. Feb 26, 2015 at 7:09 PM
    TXAggieTRD
    Andrew
    TX
    sorry i didnt see it was 5 lol
  14. Feb 28, 2015 at 4:48 PM
    csmurray1
    i went ahead and bought the one from fat bobs, im not looking for majoring gains or anything just trying to give my little taco, a beefyer look....Im still new to owning a tacoma, any other suggestions of anything i could do to it?
  15. Feb 28, 2015 at 6:18 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Just a heads up you will fall in love with it and want to spoil it and buy it nice pretty things. Not really a suggestion though
