lifting 5 lugs
Discussion in '4 Cylinder' started by bigguywes, Sep 23, 2010.
  1. Sep 23, 2010 at 8:47 AM
    bigguywes
    bigguywes [OP] Active Member
    Wes
    Fullerton CA
    Toyota Tacoma 4 cylinder 5 lug
    a/t tires
    ok so i put a 2.75 lift on my truck from fatbobsgarage.com its pretty awesome it comes with spacers add a leaf and rear shocks but what i was wondering was if i can stack another spacer on top of the other spacer in order to make more of a lift?
  2. Sep 23, 2010 at 10:11 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    That's not a good idea. Your suspension is already in an altered state with the single spacer. If it was safe to lift it more with spacers, they would already make some that height. It is generally thought (although some like to argue) that spacers are not the best way to lift a truck, although they are cheap (I have the same lift as you).
    They already alter the suspension in ways that can put more stress on other suspension components given the right scenario, ie. wheeling, and cause things to break. Adding another spacer would probably only make this worse. I'm not even sure you could fit another spacer. Probably wouldn't be able to get your alignment in spec either.
    If you want more lift get the TC long travel kit but be prepared to spend some $$$.
    Just my .02
