Lifting 5lug 4cyl 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco'nBoutYoMama, Apr 12, 2022.
  1. Apr 12, 2022 at 4:15 PM
    Taco'nBoutYoMama
    Taco'nBoutYoMama [OP] Member
    James
    2015 4cyl Tacoma Sr5/Base
    Stock
    Howdy yall.
    I am thinking about lifting up the taco a bit (2 inches +/-). I dont want to only life the front. If i do a lift i want it the same amount of inches all around. Im thinking about getting a new leaf spring set. any recommendations on what to add brandwise for the back and what to add for the front?
    Id prefer suspension upgrades for constant heavier weight opposed to the cheap block lift as i am planning on getting a camper top or towing a jetski on weekends.
    Any suggestions on suspension upgrades for a 5 lug 4cyl that adds a bit of a lift all around?
    Thank YOU!
  2. Apr 12, 2022 at 6:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Apr 12, 2022 at 7:27 PM
    yaboiwebster
    yaboiwebster Member
    Webb
    North Carolina
    Radiant Red 2006 Regular Cab 4x4 5-Speed Manual
    TEQ Customs TRD Grill TEQ Customs Retrofit Headlights ARB Bull Bar Bumper Coastal Offroad High Clearance Rear Bumper w/ Swingout 3rd Gen TRD Skid Plate Trail Gear Weld-on Sliders 285/75/R16 BGF K02s KMC 16in Enduro Wheels, 0 offset Badlands ZXR 12k Winch w/ Synthetic CaliRaised Ditch Brackets and Lights 4.10 Geared Rear ARB Airlocker ARB Single Air Compressor w/ custom mounting ARB DRLs and LED Fogs Bilstein 5100s Icon Add-a-leaf Alldogs Off-road +200lb Springs U-Bolt Flip SPC Upper Control Arms ECGS Needle Bearing Delete Bestop Soft Topper Bed Mounted Maxtrax and HiLift Jack JVC Apple Car Play Head Unit JBL Door Speakers and Tweeters Uniden Digital CB with 2ft Firestik AlphaRex Luxx Tail Lights
    If you don't offroad you could get away with rear leaf spacers under the factory ones, otherwise, I'd suggest an add a leaf under the factory for the back and the typical Bilstein 5100s paired with factory springs and some aftermarket ucas to fix your alignment. Check https://www.alldogsoffroad.com/ for some good suspension kits, they were super professional and helpful with questions when I got my lift. As far as I know, they make kits for 5 lug models, I highly recommend you check them out.
  4. Apr 12, 2022 at 7:28 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  5. Apr 12, 2022 at 7:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Apr 13, 2022 at 8:39 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    welcome to TW. Adding bed weight and towing is asking alot for a 5 lugger 4 cyl.
