lifting a 1987 pickup
Discussion in 'Solid Axle Suspension' started by Big Al 55, Jun 12, 2011.
  1. Jun 12, 2011 at 7:04 PM
    Big Al 55
    Big Al 55 [OP] Member
    87 Pickup
    6,000 pound warn winch, grille guard, tow hitch, cb radio, after market radio, took out the bucket seats and put in brand new bench seat
    i own a 1987 toyota pickup. it is very clean and looks brand new. (factory paint and chrome etc.) what do yall think about putting a 3 inch suspension lift on?
    It is a 4 cylinder automatic
  2. Jun 12, 2011 at 7:12 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  3. Jun 12, 2011 at 7:23 PM
    Big Al 55
    87 Pickup
    i was thinking bout it, but i dont wanna ruin the transmission, and i need something that gets good gas milage. but ill worry bout lifting it when i get enough money i just bought the truck so im broke now. do you have any specific lift you would use?
  4. Jun 12, 2011 at 7:25 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    4" susp lift with 33s don't sas it
  5. Jun 12, 2011 at 7:26 PM
    NelsonTacoma
    Tucson, AZ
    I always went with the more name brand. Trailmaster is what I had on mine. My dad also has an 87 turbo pickup and an 89 4Runner one with a rancho lift and the other with a trailmaster.
    The only brand I was ever sketchy about was the rough country lift, seemed too cheap for me.
  6. Jun 12, 2011 at 7:29 PM
    Big Al 55
    87 Pickup
    ok ill look into it thanks for the help. do you think its gunna mess with my transmision?
  7. Jun 12, 2011 at 7:31 PM
    paintdiddy
    shithead
    silver bullet
    My brother and I always ran trailmasters in all our trucks.we ran them on an 86 88 yota pickups and an 88 4runner.I ran a trailmaster
    on my 2000 dodge ram. Never had a problem.I'm not even sure they are even around anymore. I wouldnt cheap out on the lift.
  8. Jun 12, 2011 at 7:36 PM
    NelsonTacoma
    Tucson, AZ
  9. Jun 12, 2011 at 7:36 PM
    Big Al 55
    87 Pickup
    i want a lift that is good and will last. im not gunna get a cheap lift. ill find out bout trailmasters.
    nevermind that answered that
  10. Jun 16, 2011 at 3:48 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Why is this in the SAS forums?
  11. Jun 16, 2011 at 7:52 PM
    NelsonTacoma
    Tucson, AZ
    Good question. But we already helped the OP out with his concern about 4 days ago.......
  12. Jun 27, 2011 at 8:23 PM
    taco52
    taco52 Well-Known Member
    01 SR5 v6 5speed 4x4
    agreed
  13. Nov 18, 2012 at 2:13 AM
    RussellG
    RussellG Well-Known Member
    Russell
    Firestone
    87 DLX/00taco everything except the FJ bits
    Diamond Axle SAS, TRD FJ calipers and brembo rotors on all 4, FJ rear axle, 5.29's and elockers in both, 3rz swap and dual cases,4.7 rear case,00 taco dash, bobbed bed,soft topper,raceline beadlocks, fj cruiser steering wheel and clinometer, super white paint and 37'' kevlars. Much more but i will keep it simple.
    Im all for a lift but an 87 can run 33's with no lift. you can run a 33/10.5 on stock wheels with no lift. If anything a tiny trim of the plastic liner. Id say you can add a 1.5" ball joint spacer and relax the Tbars a little and put a longer shackle in the back if you want the height. Bracket lifts suck. I ran a trailmaster on my truck IFS and the only time it worked well was when i added the bj spacer and relaxed the bars. It was super soft. The bracket lift as close as it keeps everything to stock angles its not exact. The idler arm brakes more then it should. $300 for the TC unit makes the cost climb for reliability.
    My plan is to restore an IFS rig and do just as i listed. Balljoint spacer up front with a 1" longer shackle in the rear. Nice shocks and 33/10.5/15s on stock SR5 chrome wheels. I plan to gear the truck and add an elocker in the rear and call it good for a daily winter rig.
    EDIT: Because of the auto id think gearing higher. Some say 4:56 is plenty but 4:88's is the norm here. Im planning a little taller cause im in CO and plan to haul stuff.
  14. Nov 18, 2012 at 9:52 AM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    Why not SAS? With a lot of the springs out there you can make it ride nice and keep it low on 33's for a bad ass daily drive. Plus, the solid axle would be much stronger and more reliable.
    Do what you want, but I am not a fan of the ball joint spacers. My friend had them on his 94 4runner before he finally SASed. He could never get the alignment just right, so it wore out a brand new set of 33x12.5 MTZ's in no time. When we would go wheeling he would have to bring two spare idler arms because he was going to break one, guaranteed
  15. Nov 18, 2012 at 12:14 PM
    RussellG
    Russell
    Firestone
    Thats weird, I never had the issue with a BJ spacer. with the bracket lift i had problems like crazy. alignment was always off, never could get it to track right. I not a lot of people know with that spacer you need to relax the T-bars so i wonder if that had anything to do with it. When i lift my daily im not looking for a set amount of lift i just want a little more movement out of the front and the spacer allows for a nicer ride due to the relaxed tbar. the shackle is just to combat sag if it has any. Add a leaf would make it stiffer and i dont want that for daily use.
    A SAS would be a better lift option. By the sound of the OP's post it sounds like the truck is mint and he likes it that way. Some people are not able to cut those up...I wouldn't be able to either. A SAS would be the way to go if you want usable offroad lift. Ride quality is not as good up front as the IFS in most cases but its not way worse. I daily drove my SAS truck for 3 years. I still drive it about 50% of the time cause i enjoy the truck and feel much safer in it with all the armor then my car.
    my truck backwith the IFS bracket lift and the BJ spacer. 36/12.5/15 TSL's
    And now with the SAS and 37's.
  16. Nov 18, 2012 at 8:40 PM
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    His may have been improperly installed, I don't know. It just seemed to give me a fit.
    That's a sexy yota sir! Any specs?
  17. Nov 19, 2012 at 12:01 AM
    RussellG
    Russell
    Firestone
    Thanks...
    Specs:
    87 dlx longbed- bobbed a foot
    Solid axle swap with 4" leafs all around
    Diamond front axle 67.25 wheel mount surface to wheel mount surface.
    TRD FJ calipers, Brembo rotors with FROR brake caliper conversion
    Trenuin bearing eliminator kit
    High steer
    Hydro assist going on anyday with TC pump
    14" hoops and 14" 5125 shocks. Replacing all the shocks this week with Fox remote res.
    5.29's with elockers front and rear
    FJcruiser rear axle, brembo rotors
    4" leafs
    12" shocks 5125's
    all the shafts are chromo all the bolts are ARP, 8.8 on small stuff and 12.9 where i can.
    Motor is a 3rz from a 00 tacoma
    K&N intake for tacoma and borla cat back
    Tacoma dash- everything works a/c and all
    FJ cruiser steering wheel with stereo controls
    FJ clinometer
    Corbeau flofit seats and wedge engeneering brackets.
    TRD floor mats,
    Power windows added. Made from 01 taco motors, 86 4runner regulators and 01 switches. Panels are not finished but all the switches are in 90's pick up panels and a custom speaker enclosure in the bottom.
    Stereo stuff
    Alarm/remote start
    Dual cases all 23 spline and 4.7 gears in the rear case.
    120 wall shafts
    TG sliders
    Addicted front bumper
    Rear bumper i built. 120wall tube, bumper and supports are 1/4 and carrier is 3/16's using iron pig hinge...built to hold a 42
    Raceline beadlocks and 37/12.5/17 MTR kevlars.
    Super white paint
    There is more i just cant remember. I also have more planned. I have a once car garage full of stuff for it still.
    I am about to respray it, have the interior wrapped and make some small changes. I planned on a 1gr-fe swap but after buying everything I figured out i needed to change a few things and so im going to sell it all. It was my first ever build of a truck so i am learning as i go still. I have built cars forever but offroad is way different then street cars.
  18. Nov 19, 2012 at 2:42 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    That would look stupid. A 4 inch clears 35s will plenty of room. If you can see it my avatar is a 4" and 35s.
    To the OP. If staying ifs do bj spacers and 33s and take some load off the torsion bars to allow more travel. If you have the skills to you can fit 35s on ifs with no lift. Honestly just save up and sas it, can be done for pretty cheap for these things if you stay with all toyota parts.
  19. Nov 19, 2012 at 2:46 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    if you're going to run 32s-33s then why lift it more than an inch or two? I don't understand a lift if there is no need for larger tires. Your pickup will run 33s with no lift and some cutting so why not get some reliable suspension under you and if it brings you 1-2.5" of lift then so be it, no need for any more unless you do some serious wheeling and need 35+ inch tires. at which point your suspension is only one factor to what you'll be modifying.
