Lifting a 2002 2WD 5-Lug Tacoma???
Discussion in '1st Gen. Tacomas (1995-2004)' started by wek120, Mar 19, 2011.
  1. Mar 19, 2011 at 11:16 PM
    wek120
    wek120 [OP] Well-Known Member
    Wes
    Greenville SC
    01 Tacoma V6 4wd Doublecab
    Ok so I was planning on lifting my 2002 RWD 2.4L XtraCab that is the 5-lug version. I took a look at the front suspension, and the only way it looks to lift it would be a spacer type ring like this one:
    http://cgi.ebay.com/ebaymotors/95-0...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Is there any other way to possibly lift it a little higher? after all that is only 1.5" and doesnt seem like it would be much...
    Also the back axle sits ON TOP of the leaf springs with a flat bottom plate welded on the round axle. putting a spacer would only make the axle higer aka lowering the tires. Can I Rotate the entire rear axle 180 degrees so the flat plates will be upward facing so I could mount them below the leaf springs? (see pics)
  2. Mar 20, 2011 at 12:27 AM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    get whats called a flip kit they make a kit to put the axle on the other side of the springs. then you can block it as needed its gonna lift it like 2 inches just flipping it to the other side of the springs
  3. Mar 20, 2011 at 8:20 AM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    yeah i would do a spring over in the rear, which is what mackattack07 said. It's actually pretty easy if you have welding experience. All you do is unhook the leaf springs from the axle, and move the spring perch from under the axle to on top of it, and reweld it on, jus make sure you have your pinion at the right angle when you do it and that the perches are welded in the same spot. You will probably need a longer brake line in the rear also along with shocks. But all in all it's pretty easy we did it on a friends of mine and we had it done in like 2 hours. Also if you want a little more lift (which i think if your springs are in good shape you should get like 3" maybe 4" of lift) you could get a new spring pack, or if you spring are a little bad just throw an aal in. I would stay away from blocks in the rear, they just prematurely dearch you spring and kill you load too.
  4. Mar 20, 2011 at 8:37 AM
    wek120
    Wes
    Greenville SC
    Is there a way I can do it without welding? because i was wondering if you could literally just rotate the entire thing 180 degrees like drawn in the pic so the flat parts face up instead of down. I dont really have access to a good welder and would have to pay to get the current pinion? (flat part welded on the round axle) cut off and rewelded.
    As for the front, there is no real mount for an AAL lift on the 5 lug? the spring is just sort of sandwiched between the control arms and the frame. It is not a bolt on shock and spring assembly on the top or bottom where you would be able to throw in those extenders. It looks like the only extension would be an extra little spacer ring between the frame and spring?
  5. Mar 20, 2011 at 4:26 PM
    mackattack07
    william
    go to the junk yard and buy a prerunner rear setup
  6. Mar 20, 2011 at 9:07 PM
    wek120
    Wes
    Greenville SC
    After a lot of reasearch, it seems rear lift is no prob. (though would still like to know if I could just rotate that axle 180 degrees)
    But the front is Impossible!! I took the wheel off, and the swingarm only goes down so far. Even with the 1" rubber stops off, it stayed put and did not go down any further! Seems only thing is a flimsy little 1.5" spacer or $400+ lift spindles...
    Any ideas as to modify the swingarm so it goes down further? would that be the shock or the swingarm bushing thats stopping it? (there was no other frame contact stopping it, only sway bar)
  7. Mar 21, 2011 at 9:52 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    No you cannot just flip the axle over, because then the rotation of the wheels would be backwards. You would have to put it in reverse to go forward.
    Did you unhook the suspension from the a-arm before you tried pulling it down? The shock is only gonna let the suspension droop so far before it stops. Spindles is the easiest way to lift the 2wd. Lift coilovers is the next easiest but I'm not sure if the 5 lugger has coilovers and I would not put a spacer lift on it.
  8. Mar 21, 2011 at 1:16 PM
    mixaro
    maine
    yeah you def. can't just rotate you rear axle, well unless you want to put reverse cut gears in it, which is way more work then just moving the perches to the top of the axle. And what Southern01Taco said, did you unhook the shock when you tried to see how much down travel you could get, and spindles are the easiest and best way to lift a 2wd by far.
  9. Apr 16, 2011 at 11:31 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    dont do lift coils on a 5 lug unless you get a custom lower ball joint bracket(the weakest part of the suspension in these trucks. spindles are your #1 choice by far.
  10. Apr 17, 2011 at 2:38 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    X2
    5 Lug do a spindle in the front. Anything else without a new lower arm is asking for trouble. Ive broke plenty of those things before I ditched the stock crap.
    For the rear look at the Deaver AAL pack, Lift Shackles, or whatever. I actually have a bunch of rear lift stuff for sale right now if your interested. It was a great set up, loved it on the truck but it wasnt permanent in the plans for my build
  11. Apr 17, 2011 at 4:20 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I used spindles in the front and shackles in the back. Shackles are super easy and cheap for lift in the rear. there's a link to the build in my sig.
  12. Apr 18, 2011 at 7:36 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Yes if you lift it only do a spindle lift up front and a shackle in the rear. The spindles run anywhere from $300-$400 and the shackle should be under $100 Beefedtaco here has the shackles so shoot him a pm.
  13. Apr 18, 2011 at 8:45 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    x3 spindle in the front, shackle in the rear super cheap $400 max and easy to install.
  14. Apr 18, 2011 at 6:22 PM
    MowTaco
    Kansas
    I paid $104 for my shackles from beefed and $389 for my spindles (Fabtech). I also did the install myself and I am really no master mechanic.
  15. Jan 29, 2014 at 8:55 PM
    Card1
    Card1 Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    I have the doetsch spindles on mine, thats the only way out unless you feel like sas'ing it or giving it a long travel kit.
  16. May 6, 2015 at 8:36 PM
    Puerto Rico Tacoma
    Puerto Rico Tacoma New Member
    2015 access cab 5 speed manual sitting on some 235-70-16. Future: Rear lift, 31"-32" wheels on 15" rims or still don't know, custom avid light bar, led light bar, bed cover, etc...
    I have a 2wd access cab and I was wondering if I could go to a junk yard and buy a spring over rear differential and place it in my truck with no problem. would that be possible.
  17. May 6, 2015 at 10:13 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Theoretically, you could buy the entire rear axle and suspension setup from a PreRunner or 4x4 Tacoma of the same type as yours and swap it over. I don't know what years would fit your vehicle, as this is the 1st gen forum ('95 - '04), and your truck is a 2nd gen (or possibly 3rd, who knows). There are aftermarket SUA (spring under axle) setups that provide lift for the rear end, if that's what you're looking for. Try posting in the 2nd gen forum to see if anyone else has tried this approach:
    https://www.tacomaworld.com/forums/2nd-gen-tacomas.5/
    Alternatively, check out the long-travel suspension forum, those seem to be the guys who run SUA most commonly:
    https://www.tacomaworld.com/forums/long-travel-suspension.113/
  18. Sep 7, 2020 at 8:36 AM
    Jagsfan
    Jagsfan New Member
    02 Tacoma 2wd 5lug
    I know this is an old thread but has been very helpful. I'm putting 3" lift fabtach spindles on the front and shackles on the back. Just curious if any of you changed your rear shocks while doing this? The stocks ones are pretty much maxed out and they are worn out anyway.
  19. Sep 7, 2020 at 8:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    You'll find good info in the 5 lug forum.
  20. Sep 7, 2020 at 11:37 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I like 5 lugs. My freference is stock or lowered but I think if i were trying to raise one I'd body lift, put a taller tire under it and leave it at that.
    No one is going to want it afterwards if not returned to stock. I'd love to find a low mile reg cab not monkied with.
    Clearwater Bill likes this.
