Lifting a 2002 2WD 5-Lug Tacoma???
Discussion in '1st Gen. Tacomas (1995-2004)' started by wek120, Mar 19, 2011.
  1. Sep 7, 2020 at 12:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    Went from 215 75 to 235 75 on OE 15" wheels. Gained 1" real ground clearance.
    My '13 only has 32k. But its an access cab, so while not interesting to you, I love it. Does all I want and more.
  2. Sep 7, 2020 at 12:58 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm not sure I would just use shackles to lift the rear end 3". That's a lot for just a shackle. There is an ideal relationship between the length of the leafs, and the position/length of the shackles. You essentially want the shackle to be at about a 45 degree back angle at ride height. If you make it too long, which makes the shackle more vertical, you risk doing weird things like inverting the shackle when the suspension articulates.
    As for new shocks, yeah, you'd definitely want new shocks when you lift it.
  3. Sep 7, 2020 at 6:42 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Long ago there was talk of long shackles on hot rods as dangerous and leading to loss of control when they inverted.
    I never gave it much thought until an interest in truck lifts was established and idea was revisited.
    Really, old timers blamed high speed accidents on shackles a LOT. I suppose a swerve was what was being discussed.
  4. Sep 8, 2020 at 4:24 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    U can leave rear stock after the 3 inch spindles in the front and itll be level. If u want rake like stock then do the 2 inch shackles and the 3 inch spindles. Ive got 235s too on the stock 15s and they've done well too as mentioned
  5. Sep 8, 2020 at 4:25 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Aal is known to be too stiff for 5 lugs unless u tow alot or use toppers. Kyb is a good cheap option for shocks on Amazon
  6. Nov 4, 2021 at 7:23 PM
    Dan_Does_Nothing
    Dan_Does_Nothing Member
    ONF
    2002 base reg cab , 93 240sx coupe, 2025 MDX
    So I got a base unmolested reg cab. Thinking it's time to lift it after 5 years of DD it bone stock and just feeling like an old man.
