Lifting a 2020 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by noah_sobel, May 8, 2025 at 11:19 AM.
  1. May 8, 2025 at 11:19 AM
    noah_sobel
    noah_sobel [OP] Member
    Thursday
    Noah
    Army Green 2020 Toyota Tacoma TRD Pro
    What’s the best lift kit for a trd pro? Are spacers ok to get and if so any recommendations?
  2. May 8, 2025 at 11:23 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You have a lot of research to do on here. Search here or google for millions of posts of ideas. "Best" means a lot to different people. I offroad heavy so best to me is a lot different than someone who just wants looks.
    Spacers are a bad idea. You will spend at least a grand for an okay lift. 4 to 5 grand for a good quality lift including installation.
    Chew likes this.
  3. May 8, 2025 at 11:27 AM
    noah_sobel
    Thursday
    Noah
    im just looking for a 2-3 inch lift I’ll do some off roading but I’m not going to bouldering
  4. May 8, 2025 at 11:27 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    The easiest is halfway decent option is going to be the Eibach lift spring and/or the Westcott perch spacer. These allow you to keep the stock 2.5 Fox coilovers instead of buying new.
    This also assumes your current shocks are in decent shape, and if not they're rebuildable which would still be cheaper than something new.
    If you're not offroading hard just a block or AAL in the rear will suffice. As noted above 'best' means very different things to different people.
    TartanEagle likes this.
  5. May 8, 2025 at 11:29 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    As someone who owns a 2020 Pro and has done some research. ^^^^ THIS!
    https://eibach.com/eps-search?pf=PR...acoma+TRD+Pro&submodel=DOUBLE+CAB+3.5L+V6+4WD
  6. May 8, 2025 at 11:30 AM
    noah_sobel
    Thursday
    Noah
    my bushings in my fox shocks are blown. I’m going to most likely replace the whole thing since the bushings themselves are
    Almost impossible to find. I figured I might as well lift it while I replace with new trd fox shocks. I’ll be off-roading it but no bouldering
  7. May 8, 2025 at 11:57 AM
    BabyBilly
    Billy
    2020 TRD
    Fox has a rebuilding service and could likely put in new bushings at the same time.
    If you decide to get new stuff I'd recommend talking to someone at Accutune. They can valve the shocks based on your use case and give recommendations for springs based on your weight.
  8. May 8, 2025 at 12:25 PM
    noah_sobel
    Thursday
    Noah
    I wish I could take it to Fox but I live in California and there isn’t a Fox location near me. Id have to taken them off mail them to Fox and then have them mailed back which I can’t do
    BabyBilly[QUOTED] likes this.
