Lifting a 2WD Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dr hydro, Nov 21, 2018.
  1. Nov 21, 2018 at 3:01 PM
    Dr hydro
    Dr hydro [OP] Member
    03 PreRunner
    Camper shell
    i am with Cajun Navy Relief and I need to lift my truck so I can get my boat to where the action is. I have a 2003 2WD Prerunner and I'm wanting to lift it 6to7 inches. I see a lot of 4WD kits but no 2WD. Thanks!!
  2. Nov 21, 2018 at 3:06 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    If your truck is a Prerunner (6 lugs on the wheel) all of the "4x4" lifts will work on your truck.
    None of the "2wd" (5 lugs on the wheel) lift kits will work on your truck.
    And just to get it out of the way now... there is no spindle lift for a 6 lug Prerunner.
  3. Nov 21, 2018 at 3:07 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    They are the same kits for the most part
  4. Nov 21, 2018 at 3:08 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    "2WD Prerunner" is redundant.
  5. Nov 21, 2018 at 3:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    Curious what a 6-7" lift will do for you in a 2wd truck in terms of capability.
    Are you thinking water coverage of paved roads?
    Other than that, your ground clearance is still somewhat limited by the centerline of the axles, and tire diameter is the only way to move that a little.
  6. Nov 21, 2018 at 3:10 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Getting 6 to 7 inch lift on a Tacoma is going to be a lot of work. The cheapest way to do it would be a drop bracket lift. (I, personally wouldn't do one of those)
    Suspension lift max would really be a 3 inch lift, then you could add an inch body lift. That would really be your best bet if you're looking for the lift you're talking about.
  7. Dec 3, 2018 at 2:39 PM
    Dr hydro
    03 PreRunner
    Camper shell
    Thanks for all of the replies. My computer died so I have to use my phone which is a pain in the butt. I guess I should have asked how high can they be lifted and still be safe to drive. I am going to be driving on flooded streets;no off road driving. Thanks again for all your help.
  8. Dec 3, 2018 at 5:29 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    I've read that going above 3" requires a lot of work, but I always figured that was because people were worried about CV angles and other 4x4 components I don't have. I'm not sure what issues you'll run into with a prerunner though.
    EDIT: Not to thread jack, but is it bad for the suspension to remove the engine? I feel like that would remove a lot of the front end weight and cause it to lift up much higher than normal (< 3"). I only ask because my OME suspension arrived today but I also have to replace my engine. Not sure if it's a big deal or not to do the suspension first and engine replacement after.
  9. Dec 3, 2018 at 5:40 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Yes, if your truck has no engine in it, that’s quite a relief of load on the front suspension. Your truck will probably sit 2-3+ inches higher than it normally would.
    So In theory, 3” lift with no engine = 6” lift :bananadance:
    It shouldn’t be bad for the suspension. Do them in whatever order works out best.
    MacGyvR[QUOTED] likes this.
