Lifting a newer taco! Must Read
Discussion in 'Suspension' started by toyo freak, May 22, 2010.
  1. May 22, 2010 at 9:28 AM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    So just stopped by local off-road shop, Truckin Up, and let me say he was very helpful. (Jrobson can relate). After hearing about j's truck he gave me alot of tips.
    First my truck is 2010 and has vsc. He said dont go over 2.25" b/c bad on cv angles even with diff drop. He said no 3" lift either cause bad cv damage. But if you decide to go 6" it voids your warranty. He also said I would have to get 18" wheels w/ lift for proper clearance b/c of the newer suspension geometry. So after all is said and done he convinced me to go with 2.25" readylift. This way with diff drop, no cv damage and still under warranty. Sorry for the long post but just wanted to help out anybody thinking of lifting a 2010 taco. Also Jrobson, your truck is gonna look sweet! According to Truckin Up, he almost blew a cv joint with the Toytec ultimate lift, ouch. Sorry jrobson for using your info, but I thought it was helpful
  2. May 22, 2010 at 9:50 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    No aftermarket option simply "voids" your warranty. If you go with readylift you will regret it, did the shop happen to mention the damage spacer lifts do to your suspension plus the horrible ride? I would continue your research.
  3. May 22, 2010 at 9:55 AM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    x2 better off paying for some c/o that way you can adjust them to the height you want with better ride
  4. May 22, 2010 at 9:56 AM
    blackphantom09
    blackphantom09 Newbie
    V.B., VA
    09 Double Cab TRD-Off Road SB
    TRD Exhaust, Black badges, Jason Rage tonneau bed cover, TRD S/C, OEM roof rack, Avid Light Bar
    I hear more praise about the Toytec ULK than the Readylift. What height did he put the Toytec lift to almost blow a cv joint?
  5. May 22, 2010 at 9:57 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Go with some King Coilovers. You get 1.7" of lift without an preload and if you want more just crank them down a bit to reach your desired 2.25" of lift. Youll get a super smooth ride compared to those spacers.
  6. May 22, 2010 at 9:58 AM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Wow you went to an Off Road shop and they recommended the Readylift? Wow, might want to look for a new Off Road shop somewhere away from the Mall.
  7. May 22, 2010 at 10:00 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yea he also said readylift was top spacer, not preload spacer so the ride isn't affected.
  8. May 22, 2010 at 10:00 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    ha ha he just blew smoke up your ass. i have a 6" procomp lift on my 09 with VSC. ive had no problems.
  9. May 22, 2010 at 10:01 AM
    IamJorgeEdward
    Jorge Edward
    Orlando, FL
    Completely stock
    haha prob going to charge 1200 just to install too!
  10. May 22, 2010 at 10:07 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    readylift...hmmm no thanks
  11. May 22, 2010 at 10:08 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Lets just help the guy out. He was obviously misinformed, and its not like he asked for that type of info. No need to flame.
    Original Poster [OP]: I believe you were misinformed about the spacer lift. Just about the only wortwhile advice that dude has was keeping CV angles low. Spacers suck and a 6" lift wont void warranty. Look around this site and see what you like/what best suits you.
  12. May 22, 2010 at 10:10 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    First off I was looking for a simple lift like 5100s because I dont do much off-road. I suggested some lifts and he said for 500 dollars he could install readylift, 1" block in rear and do an alignment!!! Is that alot?? The guy is very good just ask jrobson many others, not just a no name tryiing to make money!!
  13. May 22, 2010 at 10:10 AM
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    exactly ive talked to pro comp and all ther techs says that the 6'' kits wont affect the cv joints except from normal wear and tear it wont blow out the first day you drive it and i would never do a spacer lift at all compared to new shocks :headbang:
  14. May 22, 2010 at 4:00 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Don't 6" lifts require the cross member to be cut? Maybe that's what he meant by losing the warranty? :notsure:
    Check into a good coil over front suspension. I like ICON and Fox makes a good product too. This way you can lift the truck EXACTLY as much as you want and change things as you mod. I added a front steel bumper and skid plate and the front end dropped 1". I cranked up the coil overs 1" to compensate and that kept the CV angles just like they were before I added the bumper and skid plate.
    Also, all trucks have a lean toward the drivers side. You can crank the drivers side up more and level out the stance, can't do that with a standard spacer lift. Do a bunch of reading and don't skimp $$$ on the suspension components.
  15. May 22, 2010 at 4:20 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    If your not gonna Offroad much then I guess the spacer would be fine for a mall crawler. I'm not sure how much the spacer costs but the alignmnt comes in at $60-$90- and labor for front and rear, shouldn't be more than $200 in my opinion. I know there are two types of spacers and I would really look into both of them and people's reported experiences because, as he^ mentioned, it really sucks to blow money on something your not 100% happy with. I want to say that any spacer will create a harsh ride but don't quote me on that, just make sure you know what your gonna put your money into
    and once it's done, DONT FORGET TO POST PICS :D
  16. May 22, 2010 at 4:40 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    a ready lift spacer kit WILL NOT BE STIFFER. I know some one with a kit on there dakota and he said there is a lil differance and that is only when he put on the new tires.
    The readylift spacers do not go into the spring pack like most spacer kits. think about it. the spacer goes in between the strut and the frame. so it just makes the strut longer. the strut will act and feel the same as factory. the only disadvantage to the lift is that you u not be increasing your travel. but you will still have the same amount as stock and for a mall crawler thats fine.
  17. May 22, 2010 at 4:47 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    That's exactly what I was thinking. Now with the longer coilover one of two things has to happen
    1. Shock is compressed
    2. Lower and upper arms are more articulated to fit the longer shock in between
    and, in this case it's #2 right?
    In that case I would just go with the spacer. Unless you have money to
    blow. I'm which case I would still go with
    the spacer and send me the extra money.
  18. May 22, 2010 at 4:51 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    No, you are limiting your travel, making your ride worse.
  19. May 22, 2010 at 4:52 PM
    mgage10
    mgage10 Well-Known Member
    Salt Lake City, UT
    2010 White Tacoma TRD Sport Long Bed 4x4
    Bilstein 5100s with Add-A-Leaf 18x9 XD Addicts on 285/65R18 Nitto Terra Grapplers G2 TRD Skid Plate Gray Husky Liners Venture Shield Clear Bra TRD Sport Pedals Seat Belt Alarm Disabled LED Map Lights (Cool White) LED Dome Light (Cool White) LED License Plate Lights (Cool White) White Engine Cover White Toyota FJ Grill Badge Viper 2 Way Alarm System Debadged Tailgate Fog Light Anytime Mod Window Tint Black Mesh Upper Grillcraft Black Mesh Lower Grillcraft Black Mesh Grillcraft Triangles Raven Speed Antenna AFE Stage 2 Pro-Dry S Intake Doug Thorley Long Tube Headers
    I got my 3" Pro Comp Suspension Lift installed for $500. I love it. I don't off road that much but it's great for what I have done. I have a 2010 Taco and my CV Joints are more than fine. 4 wheel parts did the install for me.
  20. May 22, 2010 at 4:53 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    The ride isn't affected on the street because you won't miss the travel your losing.
    Take a top spacer lift offroad, and you're going to start breaking things very quickly.
