lifting an 03 with torsion bars
Discussion in 'New Members' started by Razo, Dec 16, 2013.
  1. Dec 16, 2013 at 8:51 PM
    Razo
    Razo [OP] Member
    alright guys. I really need to know how to lift my truck. I have an 03 standard cab 2.4L. I don't want to level it. I want a lift kit. but since I don't have coil springs, how do I lift it and where would I find this type of lift kit.
  2. Dec 16, 2013 at 8:54 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Huh?
    2 wheel drive 5 lug?
  3. Dec 16, 2013 at 8:57 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    No coil springs?
  4. Dec 16, 2013 at 8:58 PM
    Razo
    Razo [OP] Member
    nope. just torsion bars.
  5. Dec 16, 2013 at 8:59 PM
    Razo
    Razo [OP] Member
    yes. but an 03 2.4L.
  6. Dec 16, 2013 at 9:01 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    What's a torsion bar? I only know it as the thing also called a strut tower brace...
  7. Dec 16, 2013 at 9:02 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I didnt think 5 lugs had torsion bars :confused:
  8. Dec 16, 2013 at 9:02 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :facepalm: im sorry but if you have even looked at the front suspension of your truck you would know its not a torsion bar
    toyota trucks have not had torsion bars since pre 95
    your suspension is differnet than the 6 lug suspension and lift kits will be few and far between
    on the 4wd trucks we have a one piece coilover strut. you have a shock inside of a coil that sits in a coil bucket and on the lower control arm. to lift it you need taller coils in the front and a leaf pack with a shit ton more arch for the back since you are spring under.
  9. Dec 16, 2013 at 9:05 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    its what a lot of older trucks use instead of a coil over in IFS. the shock absorber is where our coil over is and the torsion bar goes from the lca to a cross member and the torsional (twisting) resistance of the bar stuck in the cross member is what hold the weight.
    on older trucks you could lift or lower the front by cranking them one way or anther...but these trucks do not have them
    they arent
  10. Dec 16, 2013 at 9:08 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Cool. Learn something new every day!
  11. Dec 16, 2013 at 9:12 PM
    Matic
    Tricky Dick
    Easley, SC
    Best place for 5 lug lifts I believe is fat bobs. Am I correct?
    Also I might be wrong but aren't 5luggers spring under in the rear? You could do a spring over and gain lift.
    I'm sure there is more than one thread on lifting the five lugger.
  12. Dec 16, 2013 at 9:29 PM
    Razo
    Razo [OP] Member
    I'm pretty sure it's all torsion bars guys. I've looked and done plenty of research. I just haven't really found a lift kit for it.
  13. Dec 16, 2013 at 9:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Take a picture of your truck's suspension and point out to us what you think is the torsion bar.
  14. Dec 16, 2013 at 9:31 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    im sorry :laugh:
    ill paypal you 20 bucks if you show me where the torsion bar is on an 03 tacoma...
    and were you planning on installing this lift yourself when you found it
  15. Dec 16, 2013 at 9:33 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Troll?
    T-bars, as stated above, are on Toyota Pickups (95 and earlier) and not on 2003 Toyota Tacomas.
  16. Dec 16, 2013 at 9:34 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    unless you have a trailmaster lift with their weird mcpherson strut thing
  17. Dec 16, 2013 at 9:35 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    sadly i dont think so
    that wouldnt even be in the general area
  18. Dec 16, 2013 at 9:35 PM
    Razo
    Razo [OP] Member
    well since y'all are more experienced than I am, how exactly would I lift my truck then?
  19. Dec 16, 2013 at 9:39 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    how much do you want to spend?
    in the end though its not a very fruitful effort. you will spend the money, go through all the work, maybe get some 30-31" tires...and be at the same height as a stock 6 lug (4wd) tacoma
    the 5 lugs were just not meant to be lifted of wheeled
  20. Dec 16, 2013 at 9:39 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    OP, does your fronts look like
    or like
