Lifting at 4” or more
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cleeh24, Dec 16, 2019.
  1. Dec 16, 2019 at 12:00 PM
    Cleeh24
    Cleeh24 [OP] Active Member
    04 Tacoma Dblcab prerunner
    Double din stereo/backup camera/ speakers
    I was considering going with a 4 inch lift on my 04 prerunner. Will I have to upgrade anything so nothing breaks? Like maybe UCR, break lines or anything else. Kinda new to lifting
  2. Dec 16, 2019 at 12:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Stick with 2" at most.
  3. Dec 16, 2019 at 1:11 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    First thing you need to answer is why do you want a lift?
    What is a UCR, by the way? Do you mean UCA (upper control arm)?
    Are you after the Hawaii Bro look, or are you wanting to thrash this thing off road?
    With a prerunner, at least you don't have to worry about CV angles, so you can "get away" with larger lifts than for a 4x4, but that really just means there are fewer things to contend with when lifting it.
    However, anything over 2.0-2.5" and you typically run into alignment issues and need aftermarket UCAs to correct for the geometry. Front brake lines are probably fine if you're only messing with the control arm angles (no bracket lift). For a bracket lift, I'd hope that would be accounted for in the kit, but knowing the quality of a lot of the bracket lifts out there, probably not... You'll need a rear brake line for sure.
    Most 4" lifts are bracket style lifts, like the 6" ones, and are just cheap-o spacers and blocks. Honestly I'd stay away from those unless you are looking PURELY for looks (even then I wouldn't run out and stand in line for one, lol). 3" is about the max you can expect to get out of just messing with control arm angles, and really, is as high as you really need to go for off-roading anyway. More lift doesn't make fitting 35's any easier, and just makes your truck's center of gravity higher (bad for wheeling).
    Plus, with most of the bracket lifts you have to cut out the crossmember, which means you can't exactly go back without a bunch of fabrication. I see lot of posts from people who end up wanting to revert back to stock or go with a true performance oriented lift system for off-roading, and that's hard to do when you're now missing your crossmember.
    If you want something to fit some larger tires to go offoading, you're WAY better off to stick to 2-3" and put that money into better shocks, a good set of 33's, and hammering the pinch weld (and *maybe* a little cutting).
    Now, if you're just looking for looks, I would just advise you to not go out and get the cheapest kit on the market.
    jubei and Kwikvette like this.
  4. Dec 16, 2019 at 1:16 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Another option would be new Spindles since 2WD
  5. Dec 16, 2019 at 1:18 PM
    02hilux
    Planet: EARTH
    I don't think that applies to first gen
  6. Dec 16, 2019 at 1:26 PM
    Blacktacoma23
    2011 Mall Crawler
  7. Dec 16, 2019 at 1:33 PM
    jbrandt
    Justin
    Spindles alone I don't think are going to get you 4" of lift. I think most are 2.5-3".
    That's definitely a way to go though.
    I don't have any experience with spindles, but I'd imagine some fabtech spindles (3") and a good set of coilovers (or even just some 5100's set on the middle setting) would do nicely.
    Out back, however, that's a little different. If you want to match the 4", longer shocks are needed (5100's are not long enough), and ideally you'd get an entire leaf pack that's designed for 4" of lift, which I don't think there are many out there. Most are 3" or less. The 6" bracket lifts make up the difference with blocks and add-a-leafs. You might be able to get a 3" leaf pack, then get a 1" lift shackle. I know with a stock height leaf, 1" lift shackle works pretty well (it's what I have), but the geometry of a 3" lift spring is pretty different, so not sure that would work the same on a set of 3" lift springs.
    Kwikvette likes this.
  8. Dec 16, 2019 at 1:37 PM
    jbrandt
    Justin
    I doubt that's what the OP is looking for, lol. I don't believe those are lift spindles anyway. They do widen the track by 2"
    Fabtech makes a 3" spindle, too, for like $400.
    https://www.4wheelparts.com/p/2004-Toyota-Tacoma-FabtechFabtech-3-Inch-Lift-Spindle-FTS4130-7/_/R-BKBN-FTS4130-7?gclid=EAIaIQobChMI5MTxqYy75gIVCYiGCh2cQgTCEAQYASABEgLM3PD_BwE&ecmp=s:google_1749763888_65275301221__aud-320825497387:pla-670066724636_Fabtech_FABFTS4130-754827_YMM_US&utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&utm_source=google&utm_medium=cpc&sc_intid=FABFTS4130-754827&ef_id=EAIaIQobChMI5MTxqYy75gIVCYiGCh2cQgTCEAQYASABEgLM3PD_BwE:G:s&s_kwcid=AL!7836!3!340663032463!!!g!670066724636!&utm_source=google&utm_medium=cpc&utm_campaign=SC Shopping - NTM Desktop&ecmp=s:google_1749763888_65275301221__aud-320825497387:pla-670066724636
    Obviously not the same quality, and doesn't include bearings, etc... But iirc, you can't just use those solomotorsports spindles, they require uniball UCAs and are geared for the dudes with long travel, i.e. people who spend $10k on their front suspension.
    EDIT: I don't know what the hell is up with the happy faces in that link but it works....
    Blacktacoma23[QUOTED] likes this.
  9. Dec 16, 2019 at 1:47 PM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    SAS
    chrispchicken9 likes this.
  10. Dec 16, 2019 at 1:53 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Fabtech spindle is only for 5 lugs
  11. Dec 16, 2019 at 1:56 PM
    jbrandt
    Justin
    Blame 4WheelParts if that's true, they say it's for Pre-runners.
    I do remember something about 5 lugs and spindles, though. I don't see a lot of lift spindles for the 4x4's. Seems like the hubs on 4wd/prerunner spindles are already pretty low.
    Looking at the fabtech site, looks like the spindles are mostly for the 5 lugs,
  12. Dec 16, 2019 at 5:06 PM
    Cleeh24
    All these answers are great. I’m mainly going for look and ride quality. Considering it’s 2wd, not much off-roading unless it’s to get to some favorite camp spots. Looks like I’ll go 3 and probably stick to the 5100’s with an add a leaf in back. And yes I meant UCA hah misspelled
  13. Dec 16, 2019 at 5:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    In what condition is your leaf pack?
    I ask because if your leaf pack is shot, you may as well forego an AAL and just replace your pack with an aftermarket setup for height and flex.
    Bilstein 5100s are favored around here and are a great value.
  14. Dec 16, 2019 at 5:24 PM
    Cleeh24
    They’re almost flat. I was also looking into a leaf pack just because I can get the additional inches for the lift without an AAL
  15. Dec 16, 2019 at 10:55 PM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    3inch suspension lift and 1inch body lift for your 4inches
  16. Dec 26, 2019 at 1:57 PM
    Zoocoma
    Zoocoma Active Member
    PNW
    Fodofomohoes
    Yooo 4wheelparts are the biggest legal scam artists around. I have no idea how they are in business. Avoid these clowns! Sorry for the off topic post. AVOID LIKE THE PLAGUE
  17. Dec 27, 2019 at 4:42 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Don’t mean to hijack here, but I’m looking at some 5100s paired with the eibach coils to lift my front slightly. What would I need to then even the rear out? I’m new to lifting, but same as op I’m mainly going for looks to fit larger tires do little off-road unless it’s to a camp site being I’m 2wd.
  18. Dec 27, 2019 at 11:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shackles or AAL.
    AAL can help with supporting a bit more payload.
    You'll want 5100's in the rear as well as they're extended travel compared to your stock shocks; you may not need the shocks as you said you don't off road but it'll be nice to know that shocks won't be your limiting factor.
    austinsdad99[QUOTED] likes this.
  19. Dec 27, 2019 at 11:40 AM
    PureWhiteYotee
    PureWhiteYotee Well-Known Member
    2015 White TRD Sport Long Bed
    You can go cheap and get a block to lift, but AAL is a better option.
  20. Dec 27, 2019 at 12:55 PM
    austinsdad99
    1999 prerunner 3.4
    I’m def not wanting blocks. I believe I can do the AAL myself.
