Lifting decisions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bamahoyt, May 31, 2010.
  1. May 31, 2010 at 11:30 AM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    NorCal
    2001 TRD 4x4 Xtra Cab
    Tires- 31x15x10.5 Cooper Discovery AT3
    I have been looking into lifting my truck or at least leveling it out and after doing quite a bit of research, I know alot more but still don't know what I want. My questions are. If I wanted to go with one inch bigger tires than my 265/65's up to 265/70's, should I just level out the front end with Bilstein 5100's and what should they be set at? I don't really want more than 2 inches of lift because then 265/70's will look crappy so what are some other options. Thanks guys
  2. May 31, 2010 at 11:45 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    PUt a big ass lift on that sum bitch!
  3. May 31, 2010 at 1:34 PM
    Bamahoyt
    Ted
    NorCal
    I would love to but don't have the money to throw any bigger tires on her everytime I need
  4. May 31, 2010 at 2:25 PM
    Tacofanatic05'
    Hunter
    Yea i understand, im in the same boat! I think you should just get some 5100's! You can leave it at stock height until you get enough money to buy some larger tires!
  5. May 31, 2010 at 2:51 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    5100's set at 2 inches would be ideal
  6. May 31, 2010 at 8:53 PM
    Bamahoyt
    Ted
    NorCal
    Would I just need the front billys set at 2 and no billys in the back to be leveled out? Can I clear 265/70's without any lift?
  7. May 31, 2010 at 9:02 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    5100's @ 2.5
  8. Jun 1, 2010 at 7:48 AM
    Bamahoyt
    Ted
    NorCal
    Just front 5100's though right?
  9. Jun 1, 2010 at 3:26 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    the 5100's are front adjustable shocks, with two inches of lift there will be a little bit of a rake but not bad you can throw a aal in the rear or a 1 inch block
  10. Jun 1, 2010 at 3:43 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I have the rear spring TSB, gave me about 1 inch lift in the rear.
    you could also do a 1 inch AAL
    I have the 5100s up front set at .85 to match the rear.
    I have 265/75R16 Duratrac's on my painted stock rims.
    Seeing the TSB was free, the paint, tires, and 5100s cost me under a 1000.00 dollars. So my whole set up was about 1300.00.
    I would have to say i got a great deal.
  11. Jun 2, 2010 at 12:27 PM
    toast
    toast Well-Known Member
    If I were to do 5100s in the front and rear 5100s with the TSB AAL, what would I need to set the front at to match the rear?
    Could I go 2.5" in the front without having to add a spacer in the rear (already have the TSB AAL)
  12. Jun 2, 2010 at 12:39 PM
    toast
    Guess I thought it was the same thing. '09 Prerunner AC, had 3 leafs, had the TSB done, now has 4 leafs.
  13. Jun 2, 2010 at 12:45 PM
    toast
    So do people actually add the Toytec AAL after the TSB? to go to 5? More or less I want the max lift for the $ with the 5100s..I'd like to go to 2.5" in the front if possible. I realize I might have to buy UCAs to keep it from drifting at higher speeds.
