lifting my 07 taco ???
Discussion in 'Suspension' started by Bigman_CP, Oct 13, 2007.
  1. Oct 13, 2007 at 10:32 AM
    Bigman_CP
    Bigman_CP [OP] Member
    Southern Illinois
    07 TRD Sport 4x4
    3" lift, tires, clear altezza tail lights; clear turn signal lights; vent visors; K&N air filter; all emblems removed; LED lic plate, reverse, dome, and map lights;
    I recently bought a 07 quad cab 4x4 TRD Sport and was wanting to lift it a little and put some wheels and tires. I am not sure how much lift I need though. I was thinking either 33" or 35" tires but not sure. Depends on how much lift needed for either one to clear.
  2. Oct 13, 2007 at 10:41 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    33's would need a minimum of 3" and the 35's would require a minimum of 6"
  3. Oct 13, 2007 at 11:43 AM
    motorheadgp
    motorheadgp New Member
    VA
    2006 PreRunner SR5 (PAID FOR)
    3" Suspenision lift with bilistien struts in front 2" spacers in the rear,285/75R16(32.8) Toyo AT Tires with Mickey Thompson 16x8, Air lift air bags in the rear with on board compressor, Manik brush guard, Go Rino nerf bars, K&N Cold air in take with Helix throttle body spacer, Autopage RS 1000 remote starte alarm.
    I got a 3" lift on my 06 Taoma quad and honestly wish I would have got a six inch lift if I were you I would go with the six inch also considering that you do have 4X4.....I think it looks bad ass.
  4. Oct 13, 2007 at 12:53 PM
    john3:16
    john3:16 Active Member
    simi valley
    06 Double Cab TRD OFF ROAD 4x4 Debadged
    TRD Catback Exhaust, TRD Cold Air Intake, Eclipse AVN 6620
    i recently talked to some guys at toyota and they said that a 6" lift can be dangerous changing the center of gravity for this particular truck, they said that reccommended would be 2.5-3.5 maximum
    somthing i forgot to ask was would it make sense to get tires and wheels before i got the lift? or would it just make sense to get them all together? what would the maximum tire size be for a taco before it rubs on stock suspension?
  5. Oct 13, 2007 at 1:20 PM
    The_Hodge
    SC
    well...depending on the size of the rims/tires, they might rub w/o the lift...so i'd either get them together or put the rims/tires up until u get the lift...
  6. Oct 13, 2007 at 5:58 PM
    john3:16
    simi valley
    lets just say that, ill have to get wheels first before the lift cause thats all that my income lets me... what size am i looking at before i rub? and will i still be able to use those wheels/tires after i lift? or will i end up getting a new set
  7. Oct 13, 2007 at 6:11 PM
    The_Hodge
    SC
    are u planning on a 3" or 6"?
  8. Oct 14, 2007 at 3:39 AM
    motorheadgp
    VA
    ok with a 3" lift I got 16X8 wheels with 285 75R 16 tires (33") which did require some body be cut away, nothing really noticable and still does slightly rub the frame. But I would wait to get any tires before you get you lift cause thier is no way you can fit a 33 with out having a lift just save up and get it done all at once .
  9. Oct 17, 2007 at 5:38 AM
    Critter
    Critter Well-Known Member
    What about Warranty issues will it void warranty? I'm an avid surf fisherman and the 245/75 16 really don't cut it. I'm thinking of replacing them with 275/70-16's will 3' lift let me do that. If I just go with 265/70-16 can I put off the lift till warranty runs out? Running sandy beaches you want to air down to 20 lbs and spread tire foot print . I don't want my under carriage dragging sand. Any feedback helpful.
