Lifting my 1999 Toyota Tacoma
Discussion in 'Wheels & Tires' started by petquack77, Aug 30, 2019.
  1. Aug 30, 2019 at 2:14 PM
    petquack77
    petquack77 [OP] New Member
    jason
    1999 Toyota Tacoma
    I was planning on doing a 3 inch lift on my 1999 Tacoma. I really want to purchase rims with an aggressive negative offset. I want to know if anyone here drives a Tacoma with a 3 inch lift with pretty high negative offset? Do they rub when turning? Did you have to cut or trim any metal to prevent rubbing? I really don't want to go any more higher than a 3 inch lift.
    I plan on putting on the following tires and rims.
    Rims: Moto Metal 0962 OR 0970 20X10 -24 offset
    Tires: Nitto Terra Grappler G2 265/50 R20
    Anything helps. Thanks guys
  2. Aug 30, 2019 at 4:04 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Probably not a look most guys on here go for. That’s May one of those buy them and see if they fit. That wide and that offset is where the issue will come from, the tire size is fine its basically a 30x10.50. I’m assuming the truck is a prerunner or 4wd.
  3. Apr 18, 2020 at 8:34 PM
    cowboybrax
    cowboybrax Member
    Tacoma TRD 2015
    Hey men,
    Did you buy that 20x10 neg.24 ? And lifted it 3"?
    How was it on just curious looking to so the same on my 2015.
    Thanks.
