Lifting my Taco
Discussion in 'Suspension' started by rmb_crew, Feb 17, 2009.
  1. Feb 17, 2009 at 10:46 AM
    rmb_crew
    rmb_crew [OP] My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Ok so i got the TSB done on my 09 and now the rear is 3 in higher than the front. So i want to level it out and also put in a AAL in the back. I was looking at toytech getting the 5100's for the front and setting them to 2.5 and than getting their AAL for the back. How close would that get me to level and what else would i need for the lift? I know UCA eventually but i dont want to spend the money on those yet. And also the left side is about a half and inch lower than the right side. Anyone else have the same problem with their TSB?
  2. Feb 17, 2009 at 10:56 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    The rear TSB leaf springs will settle so that your back end is about 2" or so higher than the front. I can go measure my truck for the exact height difference between front and rear of my truck if you like.
    Just a thought, but if your like me you want some rake (rear higher than front) for when you tow or have stuff back there it doesn't make the truck look like the rears sagging.
    The left of our trucks is always gonna sit lower than the right. There is more weight on the driver side. The battery and gas tank are all on the driver side. This lean has been refereed to as the "Taco lean" and is a characteristic of all Tacos.
  3. Feb 17, 2009 at 11:03 AM
    rmb_crew
    oh ok that makes sense. As for the lift will i need anything else besides the AAL kit and the 5100's?
  4. Feb 17, 2009 at 1:37 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Nope :D
  5. Feb 17, 2009 at 2:43 PM
    Cramer@Down-South
    Cramer@Down-South Cramerism
    San Diego
    Black '08 Tacoma PreRunner Lifted Beautifully
    Lifted with Fox 2.5 Black & Chrome coil-overs, rear has Fox 2.0 Black & Chrome piggyback shocks, KMC 17" wheels wrapped with 285/75/17 BFG All Terrains, Total Chaos upper control arm, Alpine DVD doubledeck, and Volant cold air intake.
    I think the 5100's are a great choice if you are looking to save some cash. I have a '08 Tacoma with a UCA and the Fox Racing Shox bolt in coil over lift. The shock is designed to work in direct relation with this upper arm so you get a shock and spring rate that match your vehicle. They are a bit more on the pricey side but definately a great investment if your looking to get the truck dirty!
