lifting my tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman81, Jun 10, 2014.
  1. Jun 10, 2014 at 7:49 AM
    tacoman81
    tacoman81 [OP] Member
    Daniel
    Arkansas
    13 tss 4x4 tacoma
    Hey I'm about to lift my 2013 tss 4x4 tacoma. I'm going with a 3.5 inch in the front and 1.5 inch add a leaf in the back and will run 295/70r17 nitto trail grapplers. My question is will I rub on my A-arm assembly if i stay with my stock tss wheels? They are the five star design gun metal color aluminum alloy wheels. Any help/advice will be gratly appreciated.
    Thanks
  2. Jun 10, 2014 at 8:14 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    Not sure about rubbing but I would stay at 3" or below, unless you are planning a DB lift. At 3" you should probably get new UCAs as well.
  3. Jun 10, 2014 at 8:15 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    How are you going to lift 3.5 inch in the front?
  4. Jun 10, 2014 at 8:37 AM
    tacoman81
    Daniel
    Arkansas
    13 tss 4x4 tacoma
    It's a 3-3.5 inch leveling kit
  5. Jun 10, 2014 at 8:39 AM
    tacoman81
    Daniel
    Arkansas
    13 tss 4x4 tacoma
    Depending on the offset of my wheels I've been told i may have some rubbing issues
  6. Jun 10, 2014 at 8:39 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Your CVs wont last more then a few months at 3.5. You want to be between 2.5 and 3. And you wont be able to run anything bigger then a 265 on stock rims without rubbing stock UCAs. You could get wheel spacers but then you will rub the Cab mount bad.
  7. Jun 10, 2014 at 9:10 AM
    tacoman81
    Daniel
    Arkansas
    13 tss 4x4 tacoma
    What are UCA's sorry im not real experienced in parts or lifting trucks
  8. Jun 10, 2014 at 9:25 AM
    KMitch
    Colorado
    Upper Control Arms. Check out the suspension section; there's tons of info you can research so that you make an informed decision.
  9. Jun 10, 2014 at 9:32 AM
    tacoman81
    Daniel
    Arkansas
    13 tss 4x4 tacoma
    Will do thanks for taking the time to help
  10. Jun 10, 2014 at 9:34 AM
    Mademan925
    Nick
    Discovery Bay, CA
    What you research will show is you will want to run a 3 inch coil over kit with 285s. You can replace your Upper control arms or get new rims with a different back spacing.
    Goodluck.:)
