Lifting my truck advice needed PLS.
Discussion in 'Hawaii' started by trdtacomahi, May 10, 2019.
  1. Jun 4, 2019 at 11:22 AM
    #201
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    It’s hard to find someone that can do any auto work up to a standard at times, let alone someone who routinely installs 6” lifts.
    Keep in mind that you’re gonna have one hell of a time:
    • Parking a Tacoma with a 6” lift on Oahu because of ceiling height in garages
    • Passing recon on Oahu
    I think they look badass, but it’s a ton of work and special needs.
    hacklerjason likes this.
  2. Jun 4, 2019 at 1:19 PM
    #202
    trdtacomahi
    trdtacomahi [OP] 2018 trd off road 4x4
    Hawaii
    Currently being upgraded One @ a time
    6 inch lift
    Bigger tires need to gear up or down
    Bit more expensive
    Garages problems
    3 inch
    It looks the same as a stock truck
    I think not much difference
  3. Jun 4, 2019 at 1:28 PM
    #203
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    If you think a truck with a 3” lift on 33s looks the same as OEM, you’ve made up your mind and shouldn’t be asking questions :rofl:
  4. Jun 4, 2019 at 1:45 PM
    #204
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    I can’t believe this thread is still going.
  5. Jun 4, 2019 at 2:05 PM
    #205
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Oh I can
  6. Jun 4, 2019 at 2:09 PM
    #206
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    :frusty::facepalm:
  7. Jun 4, 2019 at 2:41 PM
    #207
    HighCountryTacoma
    Colorado
    Apparently patience is a virtue you have.
  8. Jun 4, 2019 at 3:54 PM
    #208
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    I don’t think my truck looks stock at all with a 3” lift. :smokertransformer:
    hacklerjason and El Duderino like this.
  9. Jun 4, 2019 at 4:23 PM
    #209
    HighCountryTacoma
    Colorado
    That’s cause it doesn’t.
  10. Jun 4, 2019 at 4:42 PM
    #210
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Yeah, looks like something that rhymes with YETI :boink:
  11. Jun 4, 2019 at 5:07 PM
    #211
    El Duderino
    Jeremy
    HI->PNW
    Purple?
    seoulja99 likes this.
  12. Jun 4, 2019 at 5:08 PM
    #212
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    That color taste the best?:hungry:
  13. Jun 4, 2019 at 5:09 PM
    #213
    El Duderino
    Jeremy
    HI->PNW
    Fuck I’m not T Pain I can’t rhyme yeti like he did with mansion and Wisconsin
  14. Jun 5, 2019 at 11:09 PM
    #214
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    doing a 6" lift can get a little messy.
    cutting the subframe without a plasma cutter sucks...I actually haven't see anyone weld in a brace that works with the diff either to maintain some of the original support.
    more parts to install = time and the one truck with a 6" lift I worker on, getting the diff into position was not fun.
    the decision of "what" you want should be established so working out the "how" can be addressed.
  15. Jun 6, 2019 at 2:15 PM
    #215
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Cutting the rear cross member is actually easier with a long blade reciprocating saw. Makes a nice straight clean cut. It even worked really well on the BMC You be really surprised how thin and easy to cut these frames are.
    But yes the first step is deciding on what you want!
  16. Jun 6, 2019 at 2:23 PM
    #216
    toku58
    Mall Crawler!
    Actually Servco will take it in on trade like any other Tacoma. They just won't give you any extra for the parts.
    Dealers on the mainland actually sell 6" lifted Tacoma's. It's not a scary Frankenstien thing any longer. As people learn more about these lifts the misconceptions are being ruled out. If done correctly it's great!
  17. Jun 6, 2019 at 3:18 PM
    #217
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    YMMV. Servco obviously will take any Toyota they can get their hands on, but that’s isn’t the case back here. Dealers here actually asked a buddy of mine to return his truck to stock before he traded his 17 for a 19 (dude had a legit lemon).
    I guess it’s the only time Servco is easier:rofl:
    El Duderino likes this.
  18. Jun 6, 2019 at 3:18 PM
    #218
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    Lifting a truck is a bad idea. Words of advice
  19. Jun 6, 2019 at 3:21 PM
    #219
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    For some, especially if you don’t plan on going off road, know how to maintain UCAs, CVS, etc.
  20. Jun 6, 2019 at 3:28 PM
    #220
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    That depends more on the wheel size, not the tire. Especially the offset and backspacing of the wheels. My 275 wide tire is perfectly flush with the fender because I'm using a 17x8.5 wheel with 0 offset. That's with a 275 tire... those 12.50" tires equal about a 315. That's HELLA wide for these trucks dude. Made much worse by the fact that they're M/T (Mud Terrain) tires... AND that you're considering a cheap spacer lift. This is red flags left and right. There is no need IMO to go any wider than 285 with these trucks. You will quickly find out why if you do go bigger.
