Lifting my truck advice needed PLS.
Discussion in 'Hawaii' started by trdtacomahi, May 10, 2019.
  1. Jun 13, 2019 at 7:32 AM
    #261
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Well I personally think it’s a better idea to get them. As for need???
    I can’t say it’s a “need”.
    But I do know that your suspension is dynamic and making the assumption that it’s fine without the diff drop while the truck is not in motion isn’t taking all the variables into consideration.
    I would agree that the amount of angle decrease you get from a diff drop is minimal, I feel any bit that helps you NOT have to change my boot prematurely is a plus.
    But again you’re correct it is Not a NEED.
    I would highly recommend it.
    But time will tell? I was changing my CV Boots ever 8-10 months so I know from first hand experience that it Sucks!
    All CV Boot will eventually wear out and need replacement. If there is anything you can do to prolong their life? Why not???
    Just remember that the people recommending Not to get it. Are not going to be around when they Blow and you need to replace them! Ask "King" if they will warranty you CV Boots??
    But it's up to you?
    Good luck!
  2. Jun 13, 2019 at 1:31 PM
    #262
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Know a good way to not wear them out? Don’t lift.
    You don’t need, and shouldn’t do, a diff drop for a 3” lift.
    OP has had every logical option listed in these 14 pages and still hasn’t decided, which is borderline comical. At this point, I’d suggest he go to a local truck meet and great to visually see different lifts vice asking opinions here.. and then driving straight to an installer before he changes his mind :)
    Zion, seoulja99, gotblika and 3 others like this.
  3. Jun 13, 2019 at 1:58 PM
    #263
    trdtacomahi
    trdtacomahi [OP] 2018 trd off road 4x4
    Hawaii
    Currently being upgraded One @ a time
    Neve rmind forget it
    This is getting really annoying to me now
    Opions varies here
    Now qe have cv boots to worry too
    It doesnt seem all worth lifting it
    Just i made up my mind something comes up again to worry about
    Wheres the delete button on this thread
    Forget lifting it
    Just get a better off road tires and wheels
    Ok no more nothing to worry
    Soo frustrating
  4. Jun 13, 2019 at 2:04 PM
    #264
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    There's a lot to putting big tires on a truck, can't just bolt on and go. Put a drop bracket lift and 37's.
    El Duderino likes this.
  5. Jun 13, 2019 at 2:34 PM
    #265
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    :bananadead:
    seoulja99 likes this.
  6. Jun 13, 2019 at 2:45 PM
    #266
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Changing stock parts will naturally stress other oem parts. There’s no way around that. We were trying to tell you that from the beginning that if your not good with preventive maintenance and not willing to have to trim and change parts early due to wear and tear that lifting isn’t worth it. Go spacers and blocks it’s so much easier and way less maintenance. You will fit your 33’s you’ll be happy. Put a good set of AT tires on and your truck is plenty ready stock for what every thing Oahu has to throw at it(minus peacock flats and donkey trail).
    seoulja99 and toku58 like this.
  7. Jun 13, 2019 at 4:04 PM
    #267
    toku58
    Mall Crawler!
    Just trade your truck in for a corolla.
    Buy an offroad video game and have fun!
    That way when issues arise you can just hit reset and start all over! Nothing will ever be perfect. So if you don't enjoy tinkering and modding your ride then just leave it well enough alone.
  8. Jun 13, 2019 at 4:09 PM
    #268
    trdtacomahi
    Hawaii
    Lol now its inserts and blocks
    I thought they said itll be bouncy
  9. Jun 13, 2019 at 4:43 PM
    #269
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    with blocks yes, your ride will suck.
    the Kings setup you posted will be fine for your stated intentions, which may need occasional check-ups and service over time. a cab mount chop may be needed due to the width of 12.5 wide tires and your alignment as you turn the wheels in relation to your suspension compression.
    diff drop will affect your ground clearance and skid plate installation for protection of the underside...I never used on since adding the 4wd 5-6 years ago, and never had a cv boot fail from the lift, though I have replaced a few cv axles over for opportunistic maintenance while doing other work (replace LCA bushings, shock upgrade,etc)
    the oem stock cv axles with no lift will probably last at least 6-8 years depending on the boot rubber quality and driving environment...never assume any part on these trucks or other cars will last.
    at least when parts do break or need to upgrade, better aftermarket solutions are available, and more than enough capable members across this forum that have probably dealt with that issue.
  10. Jun 13, 2019 at 5:21 PM
    #270
    El Duderino
    Jeremy
    HI->PNW
    Perfectly said
  11. Jun 13, 2019 at 8:19 PM
    #271
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    I can't imagine those tires just for street.
    It's too frickin heavy. It'll be like pulling a trailer.
  12. Jun 13, 2019 at 8:55 PM
    #272
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    pua ting
    hacklerjason and El Duderino like this.
  13. Jun 19, 2019 at 12:22 PM
    #273
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    Shetty
    kakwvu[QUOTED] likes this.
