Lifting my truck advice needed PLS.
Discussion in 'Hawaii' started by trdtacomahi, May 10, 2019.
  1. May 11, 2019 at 3:22 PM
    trdtacomahi
    trdtacomahi [OP] 2018 trd off road 4x4
    Hawaii
    Currently being upgraded One @ a time
    For lift maybe 1500
    Installed?
  2. May 11, 2019 at 3:23 PM
    trdtacomahi
    Hawaii
    Perfectly align with the black fender trim would be awesome
  3. May 11, 2019 at 3:29 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    My recommendation is save up a bit more and get a kit like this from headstrong
    https://www.headstrongoffroad.com/store/p402/Coil/Bilstein_5100_Kit_w/_Dakars_(HS16BK-1-Dakar).html
    Honestly you don’t want to throw blocks and spacers on your new truck. Do it the right way and things last longer. I would call or email Marie @HeadStrong Off-Road and she will get you set up with a proper kit. Contact @hacklerjason for pricing on installs and can mount chop to fit the 285s.
  4. May 11, 2019 at 3:34 PM
    El Duderino
    Jeremy
    HI->PNW
    Me personally I went all out the first time. Buy once, cry once for me. My whole set up with installation was around 4100 for the hardware(got a great deal from headstrong) and another 750 for install and cmc I’m a big fan of doing it right the first time.
  5. May 11, 2019 at 3:41 PM
    trdtacomahi
    Hawaii
    That 2k is that a complete set already?
    Just the installation
  6. May 11, 2019 at 3:44 PM
    trdtacomahi
    Hawaii
    Im guessing the whole thing costs 8k?
  7. May 11, 2019 at 3:46 PM
    El Duderino
    Jeremy
    HI->PNW
    That will be about for everything including install. It will be a few hundred more if you go above 2.5” in lift cause then you will need UCA’s to keep the truck in proper alignment
  8. May 11, 2019 at 3:51 PM
    trdtacomahi
    Hawaii
    With this set up
    What size tires would i be able to use then?
    Sorry guys for all this questions
    I know nothing about all this
    I just like how those trucks look
    Maybe then i can follow you guys to kaena point
  9. May 11, 2019 at 3:53 PM
    El Duderino
    Jeremy
    HI->PNW
    285/75R16
  10. May 11, 2019 at 4:03 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You're in Hawaii?
    Then you gotta do a drop bracket lift.
    With that set up, he still wont fit 285s without chopping the cab mount.
  11. May 11, 2019 at 4:05 PM
    El Duderino
    Jeremy
    HI->PNW
    Yup already mentioned. And we are trying to curb those dB lifts here through education. Lol
    seoulja99 likes this.
  12. May 11, 2019 at 4:06 PM
    trdtacomahi
    Hawaii
    With this set up itll be a soft ride
    I heard the leveling kits is a rough ride
    El Duderino[QUOTED] likes this.
  13. May 11, 2019 at 4:07 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol :thumbsup:
  14. May 11, 2019 at 4:11 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Leveling kits... (meaning lifting with leveling spacers) can give a rough ride. Also lifting with Bilstein 5100 by moving the clip up and pre-loading the springs will give a rough ride.
    You want to lift the front by using lifting coil springs. Thats the best way to get height without sacrificing too much ride quality.
  15. May 11, 2019 at 4:14 PM
    #35
    El Duderino
    Jeremy
    HI->PNW
    This
  16. May 11, 2019 at 4:23 PM
    #36
    trdtacomahi
    Hawaii
    I really need to think this through
    Will it be worth it with all that money spend
  17. May 11, 2019 at 4:25 PM
    #37
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It's all a matter of personal opinion.
    I lifted this truck for my buddy... probably 4500 bucks in the Kings, leafs, Upper Control Arms etc.
  18. May 11, 2019 at 4:29 PM
    #38
    trdtacomahi
    Hawaii
    Man that looks good
    Kings prices are up there
    Im guessing thats the full set?
  19. May 11, 2019 at 4:30 PM
    #39
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    All four corners adjustable and resi.
  20. May 11, 2019 at 4:37 PM
    #40
    El Duderino
    Jeremy
    HI->PNW
    Honestly if you’re doing it for looks and the occasional keana point run it’s not. Especially with the laws here and the prices for parts. A good set of AT tires you’ll be fine. If I wasn’t moving to the mainland I wouldn’t have lifted my truck and keep the stock suspension. I’ve done keana many times on a stock suspension and you’ll be fine.
    Oscarjr808 likes this.
