lifting my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vang Toua Moua, Aug 29, 2011.
  1. Aug 29, 2011 at 8:52 PM
    Vang Toua Moua
    Vang Toua Moua [OP] Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    well i have a crazy idea. wat i wanted to do is to relocate my rear shocks as in welding them on the axle, i want to know how much lift that will give me? then throw some add-a-leafs on that. then for the front i want to put on bilstein 5100 adjustables and add strut spacers with that. has anyone ever done this? i want to know if there would be a down side to this and wat else would i have to do besides these parts. i want to know before i start buying the parts. thank you.
  2. Aug 29, 2011 at 9:11 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Downside is that you will likely screw up the geometry of the truck in ways that are hard to explain likely resulting in some type of catastrophic failure by doing something such as re-welding the attachment point of the rear shock onto the top of the axle.
  3. Aug 29, 2011 at 9:20 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    I'm pretty sure your not supposed to use 5100's in conjunction with spacers
  4. Aug 29, 2011 at 9:23 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OP , why would you want to weld your rear shocks to the axle ?
  5. Aug 29, 2011 at 9:23 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    yeah i read on many other site that it gives problems so i wanted to know more if it would be possible. i havent bought nothing yet so all the help is appreciated.
  6. Aug 29, 2011 at 9:24 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    so i would be able to flip my u bolts around and have them not under the axle.
  7. Aug 29, 2011 at 9:25 PM
    OZ-T
    Peter North
    British Columbia
    Why not just do a U bolt flip and get AAL's and extended shocks ?
  8. Aug 29, 2011 at 9:27 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    this is just crazy talk.
  9. Aug 29, 2011 at 9:30 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    well i have the 5 lug and it does not look like if i were to flip the u bolt that i would be able to mount the shock back on.
  10. Aug 29, 2011 at 9:33 PM
    OZ-T
    Peter North
    British Columbia
    My bad , I didn't see you had a 5 lugger
  11. Aug 29, 2011 at 10:15 PM
    Vang Toua Moua
    Vang Bang
    Visalia, CA
    yep thats my biggest problem here. so i want some major help if i could lift it more than 3 inch and not put stress on the rest of the stock parts.
