lifting my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kolt nelson, Apr 1, 2012.
  1. Apr 1, 2012 at 7:50 AM
    kolt nelson
    kolt nelson [OP] New Member
    kolt
    greencastle IN
    06 trd sport
    i have the 2006 trd sport and im getting ready to lift it and put new wheels and tires on it. im going to get the roughcountry 3in lift. i was wondering if you guys knew if the 16in ion wheels and the 285/75/16 tires i was planning on getting would all work together?
    im knew to all of this so im kinda clueless when it comes to lifts and things like that. i have kinda jus been looking this up as i go but i can never get a forsure answer on everything
  2. Apr 1, 2012 at 6:14 PM
    kolt nelson
    kolt
    greencastle IN
    06 trd sport
    does anybody know if the 3in rough country lift is anygood?
  3. Apr 1, 2012 at 6:16 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    depends on the backspacing of the wheels. 285's are gonna rub if you offroad too
  4. Apr 1, 2012 at 6:18 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Depends on the kit. Is it a spacer lift? Or is it new shocks and an add-a-leaf. Are you using stock wheels?
    Spacers lifts are ok for on-road use and light off-road use. If you plan on off-roading a lot you need to go with 5100's and an add-a-leaf kit. If you are using stock wheels and 285's you will rub the upper control arm, so you either need new wheels or wheel spacers.
  5. Apr 1, 2012 at 6:58 PM
    kolt nelson
    kolt
    greencastle IN
    06 trd sport
    thanks guys
    ya the roughcountry lift is an add-a-leaf with new shocks and spacers on the front
    the ionwheels are 16x8 bolt pattern 6x5.50
