Lifting question
Discussion in 'Suspension' started by dirtytaco2010, Aug 31, 2010.
  1. Aug 31, 2010 at 9:46 PM
    dirtytaco2010
    dirtytaco2010 [OP] Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    Not to sound dumb cuz I know theres a hundred threads but im confused. Will the Bilstein 5100's alone give me the 1-2.5'' lift? Or are they used with a coil over lift? Can I use them front and rear? Is there another cost efficient option?
  2. Aug 31, 2010 at 9:55 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Yes you can use your stock coils with the 5100's. You can have 5100's for the rear but, they alone wont add any lift. you will need an add a leaf or block.
  3. Aug 31, 2010 at 9:59 PM
    dirtytaco2010
    SR5 TRD Sport LB
    so basically the shock gives lift the block keeps it up? and for the front the coil obviosly creates the front end lift? New to building
  4. Aug 31, 2010 at 10:00 PM
    dirtytaco2010
    SR5 TRD Sport LB
    that sr5 decal is crip by the way
  5. Aug 31, 2010 at 10:06 PM
    sb_mech22
    sb_mech22 yo quero taco's?
    WTF is "crip" LOL...sorry not following the "slang" I guess.
    To clarify the "block" is for the rear only. It is inserted between your axle and the bottom of the leaf spring thus pushing the body of the truck higher in the air. which creates the lift. The rear 5100 shock will not lift your rear end.
  6. Aug 31, 2010 at 10:07 PM
    senor taco
    Monterey Bay, Ca
    Thanks Blood:cool:
  7. Aug 31, 2010 at 10:11 PM
    dirtytaco2010
    SR5 TRD Sport LB
    crip is "sweet" "sick" otherwise meaning cool in santa cruz CA yeah ive gotten that reaction about everywhere else ive even been in the world i figured since senor taco was from monterey he'd get it. ha.
    well thanks for the info guys really clarified things im getting on it this week thx
  8. Aug 31, 2010 at 10:15 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    The 5100 front shock was designed as a "leveling" shock to reduce or eliminate the factory built-in rake (low nose). It is specifically designed to do this with the stock coil springs. Check out the attached document, it explains it all.
    The rear 5100s are just a regular shock that pairs with the rate/valving of the front shocks and provides additional length (travel) to work with lifts up to 3" I believe. But to lift the rear, you need to do an AAL (add-a leaf), block (not recommended), or new leafpack.
    Have you read the lift FAQ yet? this will help you get your head around things a bit better:
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
  9. Aug 31, 2010 at 10:17 PM
    senor taco
    Monterey Bay, Ca
    haha, never heard it used that way before. sounds like something my buddy Octavio would say.(he is from SC)
  10. Aug 31, 2010 at 10:20 PM
    dirtytaco2010
    SR5 TRD Sport LB
    thx scocar ill check that thread ive seen so many not sure if i saw this one yet or not..
  11. Sep 1, 2010 at 11:09 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Springs provide lift. Shocks provide dampening. In the case of the Front 5100s the shock simply moves the lower spring seat to a higher location on the shock body to provide lift. For the rear, the shock and the spring work independently. So you need a block, shackle, or AAL to provide lift for the rear.
  12. Sep 1, 2010 at 11:35 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    what is the highest you can set the billies without causing issues? I will never go off road with it, so is a 1 inch block okay in the back? Downsouth obviously sells these sets. But besides the shocks what else is needed?
