Lifting Question
Discussion in 'Suspension' started by bohunter1990, Oct 6, 2011.
  1. Oct 6, 2011 at 5:38 PM
    bohunter1990
    bohunter1990 [OP] Member
    Highland, NY
    06 Taco
    I am looking for a small lift on my 06' DBL Cab, if I go with a 3" AAL and Billy 5100's in front will I be ok? I am having Cooper AT3 265 70R 16's installed next week and would like to have a little more clearance. Thanks in advance! Joel
  2. Oct 6, 2011 at 5:42 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    3" add a leaf wouod be a bit much IMO. 1.5" in the back will level the truck. 265/70/16s are going to look really small with that liftl
  3. Oct 6, 2011 at 5:44 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I assume you'd be setting the 5100's to 2.5?
    even if you do, with 3 in the back your rear will be a good 2+ inches higher in the rear, so it might be a little much.
    isnt 265/70r16 stock?
  4. Oct 6, 2011 at 5:48 PM
    2011TacoBeav
    2011TacoBeav Well-Known Member
    Bret
    Oregon
    2012 Sr5 v6 auto DCSB
    Self made rear bumper Colormatched Bush Wackers CB Center console lock box Camo seat covers Weathertech Digi blk Bilstein 5100s set at .85 Eibach coils LR UCAs Rear 1.5" block
    Ok. Stock the truck has a nose low rake.
    The bisteins 5100s provide a 0-2.5" loft for the front.
    A 3" AAL. which I've never heard of would lift it mor than the possible 2.5" in the front.
    Mean if you put a 3" AAL in the rear at best you will lift the rear .5" higher than the front.
    If you want level the truck go with billies (bilstein) in the front at 2.5" setting if your running stock coils.
    Do some research bud, (on here from those with experience), and you will find the key to what you want. :)
    P.S. Everything I just stated is based of my own research... I have ordered but yet to instal my lift. (bilstein 5100 set at .85 with eibach coils, rear 2" AAL with billies)
  5. Oct 6, 2011 at 5:50 PM
    bohunter1990
    Highland, NY
    06 Taco
    So maybe go with 2" AAL in the rear? It came stock with 245 75R 16's
  6. Oct 6, 2011 at 5:51 PM
    2011TacoBeav
    Bret
    Oregon
    265 is in fact stock.
    I'll be running 265 duratracs with 3" lift up front with 2" aal in rear as I would like to maintain a wright rake and acknowledge my rear will settle more than the front
  7. Oct 6, 2011 at 5:51 PM
    TexasTacoma37
    You can fit bigger than 265/70/16 even without a lift.
  8. Oct 6, 2011 at 5:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get Dakars
    2 1/2 - 2 3/4 "
  9. Oct 6, 2011 at 5:53 PM
    TexasTacoma37
    265/70/16 is stock for TRD offroads. Base models come with 245/75/16
  10. Oct 6, 2011 at 5:56 PM
    2011TacoBeav
    Bret
    Oregon
    You LOVE your Dakars!! Always posting positive things about them....
    Makes me wonder if that's what I should be looking to when my 2" aal settles
  11. Oct 6, 2011 at 5:59 PM
    2011TacoBeav
    Bret
    Oregon
    This is true... Mine came with the 245s.
    Will be putting the TRD 16" rims and 265/70/16 fails on for a couple weeks before I put the 265/75/16 duratraks in my 16s
  12. Oct 6, 2011 at 6:02 PM
    larry2375
    larry2375 Well-Known Member
    honolulu
    2010 mgm prerunner sport
    upper mx grillcraft, flowmaster super 44,bilstein 5100 @ 2.5,toytec 1/4" spacer driver side,nitto terra grappler 285/70/17,17x9 xd addicts, undercover tonneau cover, wet okoles, weathertech mats, toyota door sill protector, toyota bed mat, 30% tint, black toyota oem tube steps, 14" shorty antenna, trd skid plate, most important, viper 5902 with remote start and two dual shock sensors
    Truck has 2.5" 5100 plus .25" driver side spacer and 2" aal. Looks pretty level
  13. Oct 6, 2011 at 6:06 PM
    bohunter1990
    Highland, NY
    06 Taco
    "P.S. Everything I just stated is based of my own research... I have ordered but yet to instal my lift. (bilstein 5100 set at .85 with eibach coils, rear 2" AAL with billies"
    I think this is the right approach for me. Thanks for the advice! I just dont want to have the tires undersized by the lift. P.S. this is my daily driver.
  14. Oct 6, 2011 at 6:07 PM
    2011TacoBeav
    Bret
    Oregon
    What kind of UCA are you running?
  15. Oct 6, 2011 at 6:09 PM
    TexasTacoma37
    They are going to look very undersized. Most people run tires 2" bigger (285/75/16) than that with their 2.5" lifts.
  16. Oct 6, 2011 at 6:15 PM
    2011TacoBeav
    Bret
    Oregon
    Yeah I was worried about my tires being undersized for the lift. In the end it came down to not wanting to trim my brand new Tacoma body parts, fuel economy, and over all look (I didnt want it to look like I stuffed the largest tires possible under my rig. Lol)
    Mine will also mostly be a pavement pounder... Maybe 5-10% off road. If I was looking for something more off road capable I'd go with (again based off my research and what guys have said on here) and OME lift as I hear it is a tougher system. It's drawback is a rougher ride...
  17. Oct 6, 2011 at 6:21 PM
    bohunter1990
    Highland, NY
    06 Taco
    What size tires are you running Larry?
  18. Oct 6, 2011 at 6:23 PM
    TexasTacoma37
    His profile says 285/70/17, same width and diameter as my previously mentioned 285/75/16.
  19. Oct 6, 2011 at 6:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    265/75r16 and 285/75r16 are the most popular for lifted trucks
  20. Oct 6, 2011 at 6:33 PM
    2011TacoBeav
    Bret
    Oregon
    So because your lift is 3/4" of an inch lower than the 2.5" cutoff your running 265s?
    What made you decide on your lift height and tire size?
